OVER UNITY (here)
OVER UNITY (here)
uhaweb.hartford.edu/Nettleton/RV-Test.mpeg
i have all my parts now to replicate the RV, and 60 minutes australia/ the abc the university are ready and waiting to evaluate it.
ill post mine showing some radiant flow vibrating magnets and other coool shit proberly next week.
ow and that im writing a ZPE course for uni, ill be teaching kids hopefully.
ps here is some more.
http://217.159.169.126/~creator/public/ZPE/videos/
RV-1kwBulb_XVid.avi 2.47 M
RV-Test_XVid.avi 6.7 M
RV_1kwbulb_WMV.wmv 1.56 M
also hopefull georg will get the rupferer to me asap, i have set some funds aside to replicate and show the university, but might not get there in time, i will wait georg has my loyalty and respect.
also i have virtual back infomation on magnatism, new experiments can be done to prove we know nothing of it, and its behaviour.
for virtual back ups only (georgs)
i do not trust many here at this forum.
re: OVER UNITY (here)
hey jim, your on dial up,
here bro
Videos re-encoded with WM9..
Not a fan of wmvs but know lots of cats with dial up who need to see this shit..
http://www.geocities.com/fuknwithdabeats/RV_test.wmv
http://www.geocities.com/fuknwithdabeats/RV_1kwbulb.wmv
http://www.geocities.com/fuknwithdabeat ... ot_act.wmv
here bro
Over unity is where?
Are the meter readings of 116 VAC and 4 AMPS both on the standard mains input side? If so, then where are the meter readings (volts, amps, freq, waveform) for the output load side? Surely you're not just assuming output is 1000W because that is the bulb rating - are you???
You're right Bill, Epi may not be thinking that, but the video makes it clear that they do. If you give them the benefit of the doubt though, there is still the possibility that it's inductively linked to wiring in the wall, nearby radio stations, or power lines, completely without their knowledge.
>new experiments can be done to prove we know nothing of it, and its behaviour.<
Might I be one of the trusted few?
okay guys ill ask hector and get his response, ill be in the auto electricans shop prberly next week, its a shame im not in tassy then bill can come in and de bunk every thing hehe.
valid questions, its been a while.
ofcasue you can jonathan, dont use my hotmail account
use this email to email me
ashtweth@gmail.com
ashtweth@gmail.com
It's true, I hate bunk. I think if you lived in Tassie I'd have a full time job on my hands :P
Hey Epi,
I'm not far from you, maybe I can act as an official Aussie "BW debunker", is that a fair thing?
Cheers,
Smithy.
Cheers,
Smithy.
"He who makes no mistakes......makes nothing"
as long as you have bills attitude (dont take any shit hehe)
okay guys here is hectors response, bill if there is any thing you need /want me to clarify in testing please let me know asap mate, just drop me a mail if you need to ill do all the specified tests.
Its 3 videos, FIRST one got the LC VOLTAGE and CURRENT that was
LOADED to bulb second one got Input third got bulb readings but that
video is Lost, need to find it.
But anyway you GOT Input with bulb Violet shift color in bulb tells
it was Overloaded this is frosted type self ballasting 1000W 220 VAC
bulb if it does not have optimal voltage it does not even turn on ..
Needs minimal 5Amps 200V to start (1000W),,,
remembers this is to DEMOSTRATE virtual LC power is real power
this bulbs are POWER wasters ... as filament 1000W ones I got also
a Rare 10KW bulb i lighted using resonance but that is on storage
for special project ..
bill, is there any solar place in tassy which you think might be interested in solar co generation demos? i can advertise them on 60 minutes and in the university jornal for free, in exchange for using their eqiupment one off. in non profit and for saving the planet so i expect hand outs in return for advertising hehe.
what about your university? do you have any experience with them.
i ahve the universioty here intersted in georgs principles (in brisy) but i need a prototype first.
not as easy as you think mate to get.
bill also (and every one else) the Rv is described to be able to give OU to any low lenz generstor kone head just did it
no more bull shit, cats out of the bag guys. read and weep.
its using the Rv to (as a prime mover) and a low lenz generator (muller)
how to do the OU magic:
need to have 18GA magnetic wire (motor rated type)
need ferrite cores (or low-hysterisis black sand or metglas)
NO GODDAMM FERROUS STEEL OR IRON IN CORES AT ALL.
need lots of neo magnets
nice balanced rotor, 1" thick cutting-board polyurethane plastic.
good big and heavy AC motor with CLEAN bearings...
follow Bill Muller instructions of even N-S rotor magnets against odd
number of coils to cut latch, BUT - watch out for some ratios: for
example, 32 vs 15 will not work, and 32 vs 14 also will not work,
since with 14 or 15 coils there will be coils lined up very near 90
degrees or near 180 degrees...this is why I chose 13 coils on each
side of the 32 magnets...
NOTICE NO SWITCHING at all in RV-Muller! Nothing wears out but
bearings.....
ciaoK
more pictures -
> rotor and coils on 5hp AC motor:
> http://www.geocities.com/koneheadx/132vs13.JPG
> backside of 1" thick plastic ring of 13 coils pressed onto endplate
> of AC motor:
> http://www.geocities.com/koneheadx/232vs13.JPG
> Air-gap between coils and magnets:
> http://www.geocities.com/koneheadx/32magap.JPG
Today I got the rotor of 32 N-S magnets onto the shaft of the AC
motor and also got the airgap between the magnets and stator coils
with ferrite cores to be fairly small - around 2mm - and the rotor
spins very smooth and easy so I fired it up and tested a single coil
under resistive load after being rectified into DC.
Results:
AC from coil: 14.5Vac
AC amps: 1.1A
DC output from coil (after runnig leads through FWBR): 14.5Vdc (same
as AC)
DC amps: 1.1A (also same as AC)
POWER OUTPUT TEST:
DC volts ACROSS 10ohm resistor: 9.6Vdc
simultaneous DC amps TO 10ohm resistor: 690ma
9.6V X .690A = 6.62 WATTS
13 coils X 6.62Watts = 86.06 watts total
INPUT during test into 5hp AC RVmotor was .45A X 120Vac = 54Watts
The motor does not increase in draw when 3 of the 13 generator coils
are shorted out completely, so assume then that all of the 13 coils
with a 10ohm resisntor on each is not going toincrease motor draw
either...also this is only half the coils, another 13 need to be on
the other side of rotor too for around 86 watts on that side...
So it looks like around 172Watts in DC while-under-resistive-load
output possible from this 13 vs 32 generator design, with I predict
will require 60Watts in AC to the AC motor to operate.
ps, koneheads credability and intelligence is enough for me
bearings.....
ciaoK
more pictures -
> of AC motor:
Results:
AC amps: 1.1A
as AC)
POWER OUTPUT TEST:
I've done this - it's a flux decoupling effect that has fooled many a free-energy enthusiast. Lot's of assumptions with these guys and no independant measurements... the cat's still trying to see the light of day. I think the bunk here is still several layers thick.The motor does not increase in draw when 3 of the 13 generator coils are shorted out completely, so assume then that all of the 13 coils
with a 10ohm resisntor... assumptions... assumptions... and more assumptions
Sorry mate, I'm not so ready to believe that I'll watch logic and reason fly out the window. Konehead might be credible and intelligent, and still be wrong at the same time. The real test is to simply close the loop and create fully self acting system - but they can't do that - do you wonder why?
I'm just so hard to please, or have I heard this all somewhere before :)
Rv has been looped, and i dont think kone missed any thing.
hector has said you cant get free energy from some thing that wastes 90 pecent of it, and the prime mover 9wiring with caps) alone is salvaging that. hence why kone is using it to power a low lenz generator (muller design)
i dont think you understand the Rv to tell you the truth mate you might want to look a bit loser at it ;)
the altenator can build up currents that exceed the input by 10.
every one that replicated them has voched for that, i cant wait to see it for myself.
I think you'll get the AC of the net, so can't you do another test by getting it off the net.
Use two car accumulators (equally charged): the first for the lightbulb itself, and the second for your machine to run with another lightbulb as load. Let it run for as long as you like, and then re-measure the difference in charge (after reconnecting all that)
A simple stepdown transformer has more current at the output too. You obviously don't have much knowledge or experience in this field epi, so it's kind of hard for me to seriously accept that you think that I don't understand :)...the altenator can build up currents that exceed the input by 10...
Believe whatever you like mate, it makes no difference either way because the thing either works or it doesn't. IMO, it's not working like they think it is. I've seen no evidence to confirm any OU performance - just a bunch of assumptions and incomplete measurements. The fantasy can't last.
bill in short, you can build up resonance conditions at 10X the input, and obtian 10 percent of that with diode plugs..
with out killing the resonance action (still ou)
il post mine when its finished mate
