Working Models Ratchet Making Code
First make a polygon with three (or more) sides and set its X and Y cordinates at zero.
Click 'Script' then 'Editor'
Copy this code into the editor.
Adjust the first five parameters to what you would like.
Press 'F5' to run the code.
Code: Select all
Sub Main()
 Ro = 1.000 	'outside Radius
 Td = 0.05  	'Tooth depth
 Ar = 0.250 	'Angle relief
 Nt = 60    	'Number of teeth
 CW = 1     	'CW = 1 else = 0 for CCW
 Rr = Ro - Td   'Root radius
 T$ = ""
 For a = 0 to 359 step 360 / Nt
  If CW then 'Teeth point CW
   T$ = T$ + Format$(Rr, "0.000") + Chr$(9)
   T$ = T$ + Format$(a + Ar, "0.000")
   T$ = T$ + Chr$(13) + Chr$(10)
   T$ = T$ + Format$(Ro, "0.000") + Chr$(9)
   T$ = T$ + Format$(a, "0.000")
  Else      'Teeth point CCW
  End If
 Next
 Clipboard.SetText T$
 T$ = "Data is in clipboard, ready to paste."
 T$ = T$ + Chr$(13) + Chr$(10) + "Set Geometry "
 T$ = T$ + "to 'Curved Body' and 'Shape coordinates'"
 T$ = T$ + "then click 'Paste' and unclick 'Curved Body'."
 Msgbox T$
End Sub
To make the pawl first make a rectangle. Position one end at the center of the ratchet. (If/when pinned at its end you can adjust its length without causing problems.) Make a triangle polygon with one corner to fit into a tooth space. Make a 'Keyed Slot Joint' pinned at the corner of the triangle that contacts the ratchet wheel. Attach a spring and adjust its length to half the ratchet OD and its force as light as will work. Set the properties of the pawl and ratchet to 'Ice'
Pin the rectangle and the rachet together or to other objects that rotate. If you need a number of objects that ratchet around a single point then you only need one ratchet wheel with numerous pawls.
Enjoy!
Ratchet Example
Ratchet Example
ken_behrendt
re: Working Models Ratchet Making Code
Post by ken_behrendt »
Jim...
I gave it a try and your code worked perfectly! Below is my first "coded" ratchet...it was a LOT easier make and more precise than trying to assemble one from individual pieces.
P.S. Of course, I am still not convinced that Bessler's wheels actually used ratchets. However, if I change my mind in the future, it's nice to know how to make them...
Your Script code makes ratchets easy...
We, Dutch-people, write Pi as 3,14159265 (watch the comma!!)
Microsoft Windows is a very nice program which helps us to read this kind of real-numbers in the right way. To make the story a bit shorter:
Your function gives back numbers in comma-format, but -to make our dutch lives a little bit better, WM2D wants numbers written with a point.
For those people who have the same problems, I have rewritten the function.
Code: Select all
Function Nmbr(ByVal Nr As Double) As String
Dim p As Integer
Dim T As String
  T = Format(Nr, "0.000")
  p = InStr(T, ",")
  If p > 0 Then Mid(T, p, 1) = "."
  Nmbr=T
End Function
Sub Main()
 T$ = ""
   T$ = T$ + Nmbr(Rr) + Chr(9)
   T$ = T$ + Nmbr(a + Ar)
   T$ = T$ + Chr(13) + Chr(10)
   T$ = T$ + Nmbr(Ro) + Chr(9)
   T$ = T$ + Nmbr(a)
   T$ = T$ + Nmbr(a)
  End If
 Next
 Msgbox T$
End Sub
Don't make me start to explain how we have to deal with the date format (mm-dd-yyyy)
graham
Post by graham »
Jim, when you say "Make a polygon" , do you mean make a right angled triangle ?
I've tried your code and so far have NOT had the success that our friend Ken has had .
I copied and your code and got lost somewhere along the way because When I tried to paste where Ken did I came up with a message telling me something about not being able to convert my paste into proper values.
Where am I going wrong ??
Thanks,
Thanx to this idea of Jim I am starting to learn how to program WM2D...
So here is some code without copy/paste:
Code: Select all
Dim Doc		as WMDocument
'__________________________________________________________
FUNCTION Ang( ByVal Percentage as Double ) as Double
' In:  Percentage of a circle
' Out: Angle in Radians
	Ang = Percentage * 2 * Pi
END FUNCTION
FUNCTION Ratchet( X,Y, Ro, Td, Ar, Nt, CW )
'  Create Ratchet
' X   - Horizontal Location
' Y   - Vertical Location
' Ro  - outside Radius
' Td  - Tooth depth
' Ar  - Angle relief
' Nt  - Number of teeth
' CW  - 1:ClockWise, 0:CounterClockWise
Dim Body     as WMBODY
	VC = 0         ' Vertex count
Set Body = Doc.NewBody("polygon")
	Body.PX.Value = X: Body.PY.Value = Y
	For a = 0 to 359 step 360/Nt
		if CW then ' Teeth point CW
			Vc=Vc+1 : Body.AddVertex VC, Rr*cos(Ang(a+Ar)/360), Rr*sin(Ang(a+Ar)/360)
			Vc=Vc+1 : Body.AddVertex VC, Ro*cos(Ang(a/360)),    Ro*sin(Ang(a/360))
		else       ' Teeth point CCW
		end if
	Next a
	' delete three default vertices
	Body.DeleteVertex Vc+3
	Body.DeleteVertex Vc+2
	Body.DeleteVertex Vc+1
End Function
Sub Main()
'       MAIN
  Set Doc   = WM.ActiveDocument
  ok=Ratchet( 0,0, 1.000, 0.05, 0.25, 60, 1)
end sub
Tinhead
Post by Tinhead »
scraehmmm .. and here with input dialog box.
Just a quick mixup, no error checking or else.
copy the unzipped script into the Workingmodel/Script folder and after a restart of WM2D it will show up in the Script menu ;o)
Cheers,
Rainer
the dialog
the dialog
copy to this folder !
Create_Ratchet.zip
Ratchet creator script
(1.35 KiB) Downloaded 544 times
Cool! That makes it even better.
Is there a way to create such a dialog, or is it handcoded?
btw: I have the Demo-version
Ed
Post by Ed »
In the script editor, go to the Edit menu and select Insert New Dialog.
Tinhead
Post by Tinhead »
Ed already mentioned where to find it :o)
Further more: If you go to the folder
../Program Files/Workingmodel/Program
you will find several xxx.HLP files in there. DG.HLP explains the dialog boxes, but also check the other ones. Quite useful.
Cheers,
Rainer
P.S. I'm using the demo version too, thats why I need those scripts so desperately ;o)
ken_behrendt
Tinhead...
I tried your code and it also works great! However, it would really be cool if there was some way of making an icon or tool appear on the Workspace side or top bar that could bring up that ratchet parameter box without having to go through the Script Editor...
Anyway, here's my second coded ratchet which was made to be 3 ft in diameter with 12 teeth...
Works better that trying to assemble a ratchet from pieces...
Tinhead
Post by Tinhead »
Hi Ken,
I have no idea if you can add custom icons to the toolbars, but if you copied the script to the location I specified it should show up when you open the script menu.
Cheers,
Rainer
Should be here
Should be here
bluesgtr44
Post by bluesgtr44 »
WOW! this worked great for me, tinhead and ME! Do you have any other designs you could post this way? How about a ring made from a polygon?
Steve
Ed
Re: re: Working Models Ratchet Making Code
Post by Ed »
Tinhead wrote:Ed already mentioned where to find it :o)
I don't see where you mentioned the generic creation of dialog boxes (the question) in WM2D...you only described how to run the script in the Editor.
-Ed
Sorry but you can't create a ring (a circle with a hole in it)
But in case you want something... try this.
Run the script, and run the simulation.. it's fun!! but not a perfect ring
Code: Select all
' Working Model Script
' Scriptname: MakeRing
' Function  : Polygon Ring Creation
' Version   : 1.0
' Copyright : (c)2005 ME-Designs
' Programmer: Marchello E
' Date      : Aug 9 2005
END FUNCTION
FUNCTION MakeBlock(            _
	ByVal X			as Double, _ '  X-position
	ByVal Y			as Double, _ '  Y-position
	ByVal W			as Double, _ '  Width
	ByVal H			as Double, _ '  Height
	ByVal Pin		as Boolean _ '  IsPinned
' Make simple Circle
Dim Block   as WMBODY
Dim Anchor1	as WMConstraint
	Set Block = Doc.NewBody("rectangle")
	Block.Name        = "Floor"
	Block.PX.Value    = X
	Block.PY.Value    = Y
	Block.Width.Value = W
	Block.Height.Value = H
	If Pin then
		'// Don't know how to do an Anchor... yet
		Set Anchor1 = Doc.NewConstraint("pin")
		Set	Anchor1.Point(1).Body = Block
		Anchor1.Point(1).PX.Value = 0
		Anchor1.Point(1).PY.Value = 0
   		Anchor1.Point(2).PX.Value = X
		Anchor1.Point(2).PY.Value = Y
	end if
END FUNCTION
FUNCTION MakeCircle(            _
	ByVal R			as Double  _ '  Radius
Dim Circle   as WMBODY
	Set Circle = Doc.NewBody("circle")
	Circle.Name        = "Ring Circle"
	Circle.PX.Value    = X
	Circle.PY.Value    = Y
	Circle.Radius.Value= R
END FUNCTION
Function MakeRing(				 _
	ByVal X			  as Double, _ '  Position X
	ByVal Y           as Double, _ '  Position Y
	ByVal InnerRad    as Double, _ '  Outer Radius
	ByVal OuterRad    as Double, _ '  Inner Radius
	ByVal N			  as Integer _ '  Number of Radial points
'   Try to make a ring
Dim Ring   as WMBODY
Dim i	   as Integer
Dim Vc	   as Integer ' Vertex counter
Dim MidRad as Double: MidRad=(InnerRad*1+OuterRad*3)/4 ' Try something here
	Set Ring = Doc.NewBody("polygon")
	Ring.PX.Value = X
	Ring.PY.Value = Y
	Ring.Name     = "Ring"
	' Draw Outer circle
	For i = 0 to N            '** Maybe: 0 to N-1
		Vc=Vc+1 : Ring.AddVertex VC, OuterRad*cos(Ang(i/N)), OuterRad*sin(Ang(i/N))
	Next i
	' Try to make a 'good' corner
	Vc=Vc+1 : Ring.AddVertex VC, MidRad*cos(Ang(0.25/N)), MidRad*sin(Ang(0.25/N))
	' Draw Inner circle
	For i = N to 0 step -1    '** Maybe: N-1 to 0 step -1
		Vc=Vc+1 : Ring.AddVertex VC, InnerRad*cos(Ang(i/N)), InnerRad*sin(Ang(i/N))
	Next i
	Vc=Vc+1 : Ring.AddVertex VC, MidRad*cos(Ang(-0.25/N)), MidRad*sin(Ang(-0.25/N))
	for i=1 to 3
		Ring.DeleteVertex Vc+1
	next i
	Ring.Curved=True ' Undocumented property (-: found in DLL file :-) // what about colors?
End Function
Sub Main()
'       MAIN
	ok=MakeRing  ( 0, 0,   1.5,  1,  50)   '// My ring attempt
	' ok=MakeCircle( 0, 0,   0.95 )        '// Almost as big as the inner circle
	ok=MakeCircle( 0.49, 0,    0.5 )
	ok=MakeBlock(  0.21546096,   -1.8,  5, 0.5,  True )
end sub
Ed
Post by Ed »
Tinhead, sorry...I don't know what I was on when I wrote my previous response! I thought you were saying you (Tinhead) already said where to find it, instead of that I (Ed) already mentioned it. :-)
I need to get the oil changed on my eyeballs!
-Ed
