wheeler wrote:it must be in perfect timing and if his system is correctly designed, it may hold the key to a working wheel.
I'm not able to calculate the correct gear ratio so my system isn't designed correct.
sevich wrote:I believe gears are only worthy of the trash bin
this is a reckless statement! but your arguments are legitimate.
it is obvious to me that this design wasn't besslers one, guaranted. and because it is a bit more complex, one cannot see the fault promptly.
when I build a machine I use the k'nex construction system so I save time and money. the disadvantage is here that I don't have so much possibilities and a system with gears like this one, I cannot build. finally I want to achieve a design that is realizable by k'nex, so if I have a working wheel, eventually, everyone would be able to recreate it easily. and when the mechanism that bessler used was really so simple as the history tells us, this plan is achievable.
I hope, god will give the humans a second chance and inspires one of us.
