try to appreciate...
murilo
Post by murilo »
...to the mind of others, you may learn!
http://video.google.com/videoplay?docid ... 9320&hl=en
I also appreciate how do others have enough time...
regs. M.
murilo
re: try to appreciate...
Post by murilo »
ok... no more unanswered msgs.
LustInBlack
Post by LustInBlack »
Nice, useless, but it's art so it's beautiful and makes me smile.
Changes my mind because I'm tired of feeding the dead beef.
murilo
Post by murilo »
Thanks for your consideration.
Who's that dead beef? Yourself? Your alived body and personality?
At least, hardly pessimistic.
Regs. M.
( sorry for the above quotes.)
LustInBlack
As odd your question is, I will however answer respecfully ..
The dead beef is the wheel ..
The wheel isn't proved yet, and so considered dead .
I'm feeding it, figuratively, which means I'm putting life into it, someday, the dead beef will come back to life.
8]
graham
Post by graham »
The King is dead.
Long live the King.
murilo
Post by murilo »
Truly saying, I'm glad the beef is the wheel, a much fair appreciation.
To look for the wheel, or some other PM, is just like to shew an eternally tastefull gum... An adventure.
Many of those we know are satisfied to shew just to tasteless pure rubber gums.
So, let's keep the dead King's body in good conditions...
regs. M.
murilo
Post by murilo »
Take a look.....
http://www.youtube.com/watch?v=gxnHJoyr ... ed&search=
I do appreciate to a good idea!
Thanks Murilo .. it's a good idea half completed unfortunately. For those who are wondering what is happening. While the weight/float falls under gravity via the chain, it turns a generator producing electricity. After release it floats to the top of the column of water & stops there.
The column of water is held there by atmospheric pressure & a vacuum at the top of the closed pipe. Transferring the float across to the chain again is the devil in the detail. They could shut off the pipe with a butterfly valve & open the top to get the weight/float out but some water would be lost.
I guess they are hoping that the electricity produced in the descent is sufficient to pump that escaped water back up to the top of the column as replacement or to pump the air out the top of the cylinder so that atmospheric pressure pushes the water in behind it to replace it that way ?
Unfortunately when you create a vacuum the whole column must be lifted by several inches or alternatively they pump up the replacement volume the height of the cylinder via a connecting pipe & in at the top. Either way it takes the same amount of energy imo.
murilo
Post by murilo »
You see, for me is a pleasure to appreciate good ideas, specially if they are steel ''going on''.
One must see that *many* floating bodies are falling with the chain as potential and many others are inside that tube, also as float potential.
- Valvules must be used...
- Another paralel tube may receive an water excess, as communicating tube, for partial replacement...
- Better would be experiment to draw a set just like a piston at top, as two tubes, one inside to the other, that at each floating ''shot'' would naturally free to top body by a single window.
This project is just fine and forces one to think about.
regs. M.
murilo
Post by murilo »
... try...
http://www.pmmh.espci.fr/~jbico/Research_pt.html
( the bad portuguese may be translated, but the links are ok for english readers )
murilo
Post by murilo »
This one is not to loose, absolutely!
http://tesladownunder.com
Regards,
M.R.F.
Agent 00e
"Either learn the truth or die" -- Aut
I wish I could know this guy. regs. M.
LustInBlack
Insane!
I've been playing with high voltage too .. It's all fun and games until you get shocked. ;P
murilo
Post by murilo »
Competition never rests!!!
http://www.youtube.com/watch?v=vGFhr5uY3Yc
regs. M.
murilo
Post by murilo »
Simple and spectacular stuff:
http://www.rolls-royce.com/education/sc ... flash.html
Cheers! M. SP 22/june
