G-Force Rotational Machine...
JohnnyD
Post by JohnnyD »
I've just seen this on freeenergynews.com:
http://www.youtube.com/watch?v=ZItT-XqqrHE
It is a G-Force rotational machine by an Armenian inventor.
Thought you may be interested!
JohnnyD
AB Hammer
re: G-Force Rotational Machine...
Post by AB Hammer »
I watched the video, and it seems to be running slow.
With as large of wheel system and seems to only run about 3 rounds per minute, but it is suppose to be running against a load, but like others it is still a wait and see thing.
Jon J Hutton
Post by Jon J Hutton »
An Armenian inventor has demonstrated a machine that harnesses gravitational energy to turn a 3 meter diameter wheel, to which a 300KVA electric generator is attached. It allegedly requires no outside energy whatsoever. All that is necessary to turn it on is to release the brake.
Though modern physics would predict this to be impossible, a video has been released to us that shows the machine in operation.
This machine has been under development since 1967. The first working model was demonstrated in 1993 and allegedly put out 15 KVA. The present model allegedly puts out 300 KVA (~250 Watts).
The machine has not run more than few hours at a time as they felt that was not necessary because of the fact that a proof of concept was accomplished successfully. The machine has been tested by the Armenian government but not yet by an international testing organization.
The endurance of the machine, comprised mostly mechanical parts such as ball bearings, hinges, transmission gears, and metal rods; will be optimized to be built to the highest standard of quality. It is said to be scalable. The bigger the diameter the more torque to run a more powerful electrical generator.
The first commercial model is expected to be delivered in around one year (as of Jan. 2008).
An answer to the question of how something so monumental could be around since 1993 and the world not know about it, is partially answered by the cultural climate of Armenia, which is very private, not seeking the spotlight, as is the case in many Western cultures.
KAS
Post by KAS »
It sounds as if there is pneumatic actuation going on.
Not sure why but if that is the case, then energy is needed to do this.
There would be no advantage in the wheel itself compressing air as a form of work because there are more efficient ways of producing energy.
It all seems rather odd!
On the other hand, we could be looking at a breakthrough - who knows?
I wish there was more info on the workings.
Kas
AB Hammer
Post by AB Hammer »
Thanks Kas
I didn't have my speakers hooked up so I didn't here it. I thought it was a silent video. I then found where my speakers got unplugged, and yes you can here the air. It is an obvious compressed air sound.
Well in a way it sounds good to me. LOL So back to doing it correctly. ;)
LennyD
Post by LennyD »
Congratulations are in order. This inventor proved it can be done. Granted, I am taking the news and video at face value.
What interested gravity engine builders should take away from this is that: IT CAN BE DONE. One cannot argue with success.
My thinking is to *step away* from Bessler's smoke screen of drawings and shadowy descriptions.
Naysayers matra is that every possible angle and configuration has been tried. My hunch is that those who would be capable never try because they are taught in school that it is not possible.
Lenny
"If we knew what we were doing, we wouldn't call it research." Einstein
Dave Roberts
Post by Dave Roberts »
If this is patented, then the inner workings should be available. Has anyone viewed the patent?
Dave
I searched for patents and came up blank. The inventor's name is never mentioned, so it is difficult to find his patents. Suspiciously there is no mention of specific patent number or patent dates. In most countries even patent applications that never got patented are available in the search data bases. At this point the lack of information makes it difficult to determine if it's a scam or not.
Reticon
Post by Reticon »
compare the video to the one here: http://www.besslerwheel.com/forum/viewt ... 5047#85047.
path_finder
Post by path_finder »
The web site of Mr Khalil_M-Niazy (Karra Green Energy) has been closed, but I have a full copy.
Here are some pictures earlier displayed on the Web.
My signature seems to be very appropriated in this case...
KarraGreenEnergy1.zip
(579.5 KiB) Downloaded 415 times
DrWhat
Post by DrWhat »
Thanks path.
I like it! Add as many arms levers and contraptions as you can and no-one will have any idea how it works!
Just another way of concealing the mechanism!
path_finder
hereafter the primemover principle?
Reticon
Post by Reticon »
don't miss my point. The same video of the same contraption is being used under two different names and even from two different Countries. Wreaks of fraud.
AB Hammer
Post by AB Hammer »
Lets not forget the compressor that runs it.
path_finder
IMHO this is the same principle for the both designs: an electric motor is generating (1)compressed air/(2)electricity, used for the control mechanism. The rotation of the wheel is used for powering back the motor. An 'underunity' device for sure.
