Mann Gravity Mover -- RESEARCH FINDINGS (by P.Stroud)
This forum thread is for numerous posts on the research findings / evidence that I (Preston Stroud) have uncovered on the Mann Gravity Prime Mover, invented in 1997.
I will create two more threads, one for sharing test results and another for general dicussion
I have been been reseaching evidence, purchasing information, building test models and having parts custom made since July 2008. The inventor's website went down in December after his 1 year domain name was not renewed.
In 2005, two patent applictions were filed on the Mann Gravity Prime Mover. Starting in 2006, India's Punjab Energy Development Agency (PEDA), Sector 33, Chandigarh began running tests on this gravity device. Many variations were built and their designs & results were published. For example, some ran faster, some had more power, etc.
Inventor: Gurbakhsh Singh Mann
Invention: MANN GRAVITY MACHINE 10/29/1997
GURBAKHSH SINGH MANN (Inventor)
PROP. MANN GLOBAL ENERGY SOLUTIONS,
S.C.O. - 277,Sector- 35/D,
Chandigarh ,(India)
Ph.- (0172) 660263
E-mail -gurbakhsh_mann{at}yahoo.com
Chandigarh ,(India)
Ph.- (0172) 660263
re: Mann Gravity Mover -- RESEARCH FINDINGS (by P.Stroud)
Details on the Mann Gravity Prime Mover - Invented by Gurbakhsh Singh Mann.
Patent Abstract
MANN GRAVITY PRIME MOVER
Application 2512/DEL/2005 published 2008-05-30, filed 2005-09-16
MANN GRAVITY PRIME MOVER is a gravity perpetual Motion Machine. It moves only with the gravitational pull of the earth. MANN GRAVITY PRIME MOVER is a fuel - less prime mover for limitless power generation and other useful purposes. It moves automatically due to gravitational pull of earth. In it the required weight(s) is made to move automatically horizontally in circular motion at the same height from ground level - A NEW THEORY - for 24 hours a day. In it a shaft inclined downward / upward (4-inches per foot approximately) is made to move with weight(s) fitted on levers (s) with the help of a wheel running on a circular runway and the same is used to do mechanical work for power generation and other useful purposes such as pumping of water, running of small machines in industry. At its centre there is a stepped hole in which a ball bearing is made to move in a cup/cover of a taper ball bearing. It enables the movement of main shaft in downward / upward inclination. At the centre a supporting shaft vertical to the main - shaft is provided and a ball bearing at its other end moves in a pulley type ring at suitable depth/ height as per need. It controls the movement of weight (s) and keeps it at the same height from ground level. The supporting shaft is further connected to the pulley fitted at the top of the stand of this prime mover for power generation and to do other necessary work mechanically such as pumping of water, running of machines in industry. With the movement of this Gravity Prime Mover the pulley moves - it further drives a small pulley of gear box and the gear box increases the speed of its couplin. A small generator is directly connected to this couplin for power generation. A large generator is kept by the side of the prime mover and power is generated with the help of helical gear and vertical and horizontal shafts etc. In MANN GRAVITY PRIME MOVER - hydraulic brake is provided to stop it as and when required and a stand may be placed under the weight (s) at that time. With the removal of stand and releasing of hydraulic brake - Gravity prime mover again starts moving at the same speed. The wheel of small MANN GRAVITY PRIME MOVER may be made to move on a circular steel plate - wide enough for its movement. The wheel of a big MANN GRAVITY PRIME MOVER may be made to move on a circular railway line type -single line circular installation. No. of Pages : 3 No. of Claims : 14
Applicant
1)GURBAKHSH SINGH MANN
:S.C.O.277, SECTOR 35-D, CHANDIGARH
Inventor
International Info
Classification: F03G 3/00
Patent Abstract
Applicant
Inventor
International Info
Original Drawing with (2) Points Clarification
Two important points of this invention which have not been disclosed earlier:
o are that a Plan Ball-Bearing has been made to move in the Taper Cap of a Taper Ball-Bearing to enable the main shaft of MANN GRAVITY PRIME MOVER move in inclined position towards its centre.
o Secondly the supporting shaft provided at the centre has a Ball-Bearing at its top which moves on the outer surface of taper ring fixed at suitable height.
In the page given on 18.03.2006 in my website it has been mentioned regarding two important points relating to MANN GRAVITY PRIME MOVER:
o In the first point to enable the main shaft of MANN GRAVITY PRIME MOVER move in inclined position towards its centre may be considered to/fro centre.
o In the second point that the outer surface of taper ring may be considered as outer surface of taper/plain ring.
Picture (1 of 2) - installed at the premises of Punjab Energy Development Agency (PEDA), Sector 33, Chandigarh
Here, the MANN GRAVITY PRIME MOVER - 5HP installed at the office premises of PEDA Chandigarh 50 Kg weight(s) is to move at 50 R.P.M. at a radius of 1.5 meters (say 5 feet) and as such it is MANN GRAVITY PRIME MOVER - 5HP.
Some civil works including increase in height of runway for its wheel to three feet, remain yet to be completed by PEDA, Chandigarh. However:
o the height of runway-A 1.5 feet wide, 0.3 inch thick M.S. Sheet with 12 feet diameter at its centre
o has temporarily been increased to three feet
o to get about two inches per foot up ward inclination of Main shaft of
The movement of wheel on the runway is quite satisfactory. It being a heavy duty prime mover:
o the ball bearing of supporting shaft has been made to run at inner surface of ring provided at suitable height as a safety measure.
o In the case of reverse shaft the ball bearing can be made to run at inner surface of ring provided at suitable depth.
Increase in height of runway for its wheel to three feet and three inches with inward taper at the top remain yet to be completed by PEDA, Chandigarh. The height of runway for its wheel has temporary been increased as is clear from the Photograph and the movement of wheel on it is quite satisfactory. But proper run way is necessary to get the required speed
Picture (2 of 2) - installed at the premises of Punjab Energy Development Agency (PEDA), Sector 33, Chandigarh
This new picture is with a proper runway support by brick and grouting.
Two more sketches
The Sketch of my invention MANN GRAVITY PRIME MOVER for fuelless and limitless power generation and other useful purposes is given here under: -
PATENT APPLIED FOR
An agreement for MOU relating to this invention of mine MANN GRAVITY PRIME MOVER has been signed with Punjab Energy Development Agency (PEDA), Chandigarh. Keeping in view some aspects of getting it patented. It is considered to be too early. However the period of Bank Guarantee of advance paid to me has been extended from time to time with mutual understanding of both (PEDA) Chandigarh and myself on the same terms and conditions of Agreement for MOU.
Now having completed the necessary civil works (PEDA) Chandigarh wants me to give demonstration of MANN GRAVITY PRIME MOVER-5HP. This Gravity Prime Mover is already installed at the premises of (PEDA) Chandigarh. Its demonstration will soon be given for earlier commissioning.
Sd/-
Prop. Mann Global Energy
SCO 277, Sector-35-D,
Chandigarh (U.T.) (INDIA)
Ph. No. 0172-2660663, 9815340772
E-mail - gurbakhsh_mann[at]yahoo.com
Two more sketches
PATENT APPLIED FOR
Sd/-
Sketch 4
The Gravity Prime Movers mentioned in page given on 20-3-2007 can also be made having suitable upward inclination of main shaft and the additional attachments used in them adjusted accordingly.
In MANN GRAVITY PRIME MOVER with upward inclination of main shaft of which the sketch is given above the height of run way for its wheel is increased and the height of its base is decreased. The main shaft is made to move at 45o approximately. The run way of suitable height with inward taper at the top can also be constructed for this Gravity Prime Mover.
Such a MANN GRAVITY PRIME MOVER-5HP with constructed run way has been installed at the premises of Punjab Energy Development Agency (PEDA) Chandigarh. The movement of both wheel at extreme end of main shaft and the movement of ball bearing on the 'L' shaped additional attachment provided at the top of the supporting shaft is in the same direction. Therefore the speed of MANN GRAVITY PRIME MOVER-5HP is considerably increased to do mechanical work for power generation and other useful purposes. Its demonstration will soon be given for its earlier commissioning.
Sd/-
S.C.O. 277, Sector-35-D,
Sketch 4
Sd/-
Sketch 5
Above MANN GRAVITY PRIME MOVER has downward inclination of main shaft nearly 6 inches per foot and backward inclination of supporting shaft to the main shaft less than 6 inches per foot.
Due to these inclinations of main shaft and supporting shaft MANN GRAVITY PRIME MOVER - moves at considerably high speed. The circumference at which the weight(s) move is automatically increased. Slightly lesser weight(s) with increased speed (R.P.M.) accordingly - moving at required circumference can also give the required output.
Such MANN GRAVITY PRIME MOVER 5HP has been installed at the premises of Punjab Energy Development Agency (PEDA) Chandigarh for earlier demonstration and necessary commissioning.
Sd/-
Sketch 5
Sd/-
Sketch 6
In the above MANN GRAVITY PRIME MOVER the main shaft is inclined downward towards its far end and the supporting shaft at the pivot is provided downward and the same is inclined backward to the main shaft at 100o nearly.
The supporting shaft with ball bearing at the lower end is further pressed to such an extent that the weight (s) provided at the main shaft near the wheel are lifted high enough and made to move at considerably high speed and as such these weight (s) make MANN GRAVITY PRIME MOVER - move at considerably high speed as well.
Sd/-
Sketch 6
Sd/-
Two alternate positions
Another sketch of my invention MANN GRAVITY PRIME MOVER for fuel less and limitless Power Generation and other useful purposes is given hereunder (Two Positions):-
PATENT APPLIED FOR
Two positions of this Mann Gravity Prime Mover are given below :-
In Position 1 The Gravity Prime Mover is having downward inclination of main shaft nearly 2 inches per foot and upward L shaped additional attachment.
In Position 2, the Gravity Prime Mover is having upward inclination of main shaft nearly 2 inches per foot and upward L-shaped additional attachment.
MANN GRAVITY PRIME MOVERS having both the above different positions are equally good.
Sd/-
PATENT APPLIED FOR
Sd/-
Sketch 7
In the above MANN GRAVITY PRIME MOVER the main shaft is inclined downward towards its far end and the supporting shaft at the pivot is provided upward and the same is inclined backward to the main shaft at about 100o.
Another sketch of my invention MANN GRAVITY PRIME MOVER for fuelless and limitless power generation and other useful purposes is given hereunder:-
PATENT APPLIED FOR
Sketch 7
PATENT APPLIED FOR
Sketch 8
In the above MANN GRAvITY PRIME MOVER the main shaft is inclined downward towards its far end and "L" shaped supporting shaft is provided at the pivot in such a position that this supporting shaft with ball bearing at its top is further pressed to such an extent that the weight(s) provided on levers at the main shaft near the wheel are lifted high enough and thus made to move at considerably high speed and as such these weight(s) make MANN GRAVITY PRIME MOVER move at considerably high speed.
MANN GRAVITY PRIME MOVER - 5HP is being installed as per above sketch at the premises of Punjab Enery Development Agency, Sector-33, Chandigarh (U.T.) for earlier demonstration and its commissioning.
Sd/-
Chandigarh (U.T.)-160022 (INDIA)
Sketch 8
Sd/-
Sketch 9 and Document with PEDA of India dept energy
TWO BIGGEST EVER INVENTIONS FROM UTILITY POINT OF VIEW OF THE WORLD INVENTED BY ME ARE:-
1. MANN GRAVITY PRIME MOVER (PATENT - APPLIED FOR)
2. MANN BUOANCY PRIME MOVER
Both these inventions are for Fuelless and Limitless power generation and other useful purposes.
A M.O.U. for agreement has already been made by me with Punjab Energy Development Agency, Sector-33, Chandigarh in respect of MANN GRAVITY PRIME MOVER.
Some civil works relating to the installation and demonstration of MANN GRAVITY PRIME MOVER - 5HP remain to be completed by PEDA Chandigarh. Soon after the completion of necessary civil works by PEDA Chandigarh successful demonstration of MANN GRAVITY PRIME MOVER - 5HP may be given. An agreement as per above M.O.U. may be signed by me with PEDA Chandigarh within one month of successful demostration and commissioning of above GRAVITY PRIME MOVER.
Even otherwise the sale price of MANN GRAIVTY PRIME MOVER is Rs. 30000/- (Rupees Thirty Thousand Only) per H. P. at source (in India).
Advance booking for MANN GRAVITY PRIME MOVERS - 2H.P., 5H.P. 10H.P. and 20H.P. may start soon.
Production of MANN BUOANCY PRIME MOVER may start later on.
Sd/-
In the above MANN GRAVITY PRIME MOVER, the main shaft is inclined downward and the L-shaped supporting shaft is inclined backward. With ball bearing inserted into the upper ring the levers with weight(s) are lifted up and make MANN GRAVITY PRIME MOVER, move at considerably high speed.
MANN GRAVITY PRIME MOVER - 5 HP is being installed as per above sketch at the premises of Punjab Energy Development Agency Sector 33, Chandigarh (U.T) for earlier demonstration and commissioning.
A copy of letter from PEDA Sector 33, Chandigarh (U.T) dated 25-02-2008 relating to installation of MANN GRAVITY PRIME MOVER, and for earlier demonstration and commissioning is also given hereunder:-
Sd/-
Sketch 11
In the above MANN GRAVITY PRIME MOVER, the main shaft is inclined upward and the downword L-shaped supporting shaft is inclined backward. With the inserting of ball bearing into the lower ring/base the levers with weight(s) are lifted up and make MANN GRAVITY PRIME MOVER, move at considerably high speed.
This MANN GRAVITY PRIME MOVER needs simply proper grouting etc. as its runway is fixed/welded at suitable height of the stand having six legs of MANN GRAVITY PRIME MOVER itself.
In the case of MANN GRAVITY PRIME MOVER - 5HP being installed at the premises of Punjab Energy Development Agency, Sector 33, Chandigarh (U.T.) necessary civil works have already been completed. Demonstration for its earlier commissioning will soon be given.
In both the cases the price of MANN GRAVITY PRIME MOVER will remain the same i.e. @ Rs. 30,000 per HP.
Advance booking of MANN GRAVITY PRIME MOVERS of different sizes may start soon.
Sd/-
Sketch 11
Sd/-
Sketch 12
In the above MANN GRAVITY PRIME MOVER, the main shaft is inclined upward and the upward L-shaped supporting shaft is inclined backward. With the inserting of L-shaped supporting shaft with ball bearing into the upper ring, the levers with weight(s) are lifted up and make MANN GRAVITY PRIME MOVER, move at considerably high speed.
Sd/-
Sketch 12
Sd/-
