...speaking in a common language,is an everyday "nasty" happening,you must take into account,when you commute to the job with your car.
Usually,you must bump-up (then a short launch...),or bump-down (after a short launch...),it depends if you meet a small elevation or a hole,on your way.
If you don't push the brake,in a very short time,the gravity requires that the car's mass (and your...so to "feel" inertia),bumps,moves with an uneven way from the linear to nonlinear interplay with inertia.
Your CoG experiences a "jerk" motion,a kind of acceleration of acceleration,it depends of your velocity and way curvature(concave,convex).
It's a strong,powerful,unpleasant tremble motion,that you feel,due to an abrupt changing trajectory of CoG,from translation to a fragmentary convex,or concave...we try to avoid them.
But some people (Milkovic and others...),made this type of motion to be utilizable :they bumps a pivot in a bearing.
You can capture this motion,if you take a look at www.veljkomilkovic.com then at "Key of Gravity Machine"/Jovan Marjanovic/see Fig.2
In my opinion,they use instinctively,a bump inertial induction,and they get as a result a "wonder leverage" (output>input).
All the problem is,that they can't close up the process,with a swinging pendulum motion at the input.
If,as Marjanovic said,we really have a key to unlock the gravity power...we need one more key,maybe.
All the Bests! / Alex
Bump induction...
Bump induction...
re: Bump induction...
...when you drive a car, without pushing before the break , usually is an unpleasant happening.
Your car is not an unicorp(steel ball),but a system composed of thousands spare parts:the shock-answer is a multiple mechanical vibratory phenomenon.
If you like,it's a "harsh" (mechanical) oblique reflection if we set side by side an "ethereal" (light) one,but in the same conceptual line,also...it can be the so old Aristotle's(and later Newton's...) original analogy of reflection as rebound.
Here,naturally we have :input(momentum)=output(momentum).
But,for Milkovic's arrangement(pendulum with a lever),the bump motion inside a concave surface ,is continuous and "soft".
About input/output ratio,we must take into account something additional regarding the pendular motion,so rotational inertia.
A more extensive concept,defines the reflexivity as a general property of matter and energy.
We know how to "harvest",focus the diffuse power of the light with the help of a concave mirror.
Maybe,thinking about Milkovic's method,again a concave "idea"-surface,as a focusing technique can help us to amass the rotational inertia induction of the pendular swinging.
Key words:reflection ,concave
.....can be considered a nonlinear interplay with the inertial property of space.
Take a look at : www.youtube.com/watch?v=_J5V3BVXZlM
A fixed fulcrum and a swinging bar is a common pendulum.
If we add a mobile fulcrum and a second bar we have a chaotic pendulum.
Chaotic motion,in this case, can be no more than a new aspect of the centrifugal effect of inertia into a mobile fulcrum.
If we can "manage" this non-linear feature of inertia ,we can have a "key" for the so-called "overunity box"(input<output)....
....and for the obsessive recurring theme of this forum...:that phantom-like "prime-mover"?
All the best! / Alex
.....maybe,a suggestion for a bump launcher,to play short to long (arm) ,in your arrangement ,at:
www.youtube.com/watch?v=5mlVHJRGgPU
This short movie is half reality-half fiction ,maybe capable of creating a slight trace in your mind ,regarding the topic of this forum...
.....with a magnetic threshold , at:
www.youtube.com/watch?v=GpbGHc-b4NQ
To simplify the things,this "wheel" is a double pendulum ,you can see at:
www.youtube.com/watch?v=d2E5oojoXjk
These pendular arrangements have no restraints and so,no control of motion,so to play a torque difference in a regular manner.
All the best ! / Alex
Great! After all these years, not only do we not have flying cars, but I also have to kick around a pendulum whilst relaxing?
Hi Ed !
Starting with your words "...after all these years...",we have a certain evolution of the basic ideas...take a look at :
http://artojh.wordpress.com/tag/sixto/
.....or combining the constant gravity acceleration and the increasing rotational acceleration , or a spiral trajectory as a cyclically "light blow"/bump induction...jerk...as a higher "g"(a change in gravity action due to higher derivative ).
Some comments , at :
http://iopscience.iop.org/article/10.10 ... jpaa4184s5
The simple image can be a repetitive 360* spiral trajectory , or gravity freefall "bumping" rotational inertia...for a possible gravity ( self ) powered device...as the next step for a "modified" trebuchet(playing alternately long-short arm...).
Al_ex
Al_ex
