Hollow object in Working Model 2D 2005
ravengo
Post by ravengo »
Does anybody knows how to create hollow object (drum) in Working Model app? I tried many things, without success.
mondrasek
re: Hollow object in Working Model 2D 2005
Post by mondrasek »
From what I've seen, this is not possible. But I'd like to learn otherwise myself.
Instead of a fully closed drum, draw it with a slot running from the ID to the OD, like a letter "C" with a very small opening. Also, you can draw two halves of the drum and then attach them to get the whole. These shapes are usually drawn best in a CAD program and then exported as a DXF and imported into WM2D.
Make two 'C' shaped polygons and pin them together!
Or check out this thread: http://www.besslerwheel.com/forum/viewt ... 5266#15266
axel
Post by axel »
Ah yes, that link takes us back to when Ken was a regular here before all you righteous knumbskulls chased him away.
Axel
coylo
Post by coylo »
If you 'sincerely' miss him Axel, you can always drop him an email and let his info-overkill replies fill your inbox - knock yourself out!
ravengo
Post by ravengo »
Thanks Jim, this article contains some really nice tips. :-)
