Big fall,small jump...
iacob alex
Post by iacob alex »
...is an open suggestion , for a possible PM.
To play the well known long arm-short arm concept (a continuous torque unbalance on the same side of the fulcrum),we can think about a high and retarded drop down ,of a thinkable simple unbalanced arrangement,so to get an easy small jump up (the "remake" of the starting unbalance).
For simplicity,we can imagine a "minimal wheel" :two spokes only.
One spoke ,with a fixed mass , plays the constant torque (medium).
The other spoke,with a mobile mass,plays the variable torque(long,small vs. medium).
The big fall is the elevation (diameter).
The small jump up,is the arm's difference (small to long),nothing more.
So,we have a single problem :the mobile mass.
All the Best! Alex
iacob alex
re: Big fall,small jump...
....as an easy understanding,can be depicted at : www.geocities.com/iacob_alex/Some_Drafts/text028.JPG
Here,you have the general concept,so you can imagine (and test,maybe...),your's own variable arm procedure ,as a minimal set of actions,required to play the long arm-short arm game.
If we impose two restrictions (M1=M2 and R3-R1=constant arm difference ), but the diameter of the wheel,is little by little increasing,as in: www.geocities.com/iacob_alex/Some_Drafts/text045.jpg ,then,have we a small "confusion"?!...or are we unable,to tell the difference between them?!
All the Best! / Alex
iacob alex
...concept has two parts:
-big fall (spoke),so grater v=g*t , EK=1/2m*v*v
-small jump(m*g*h=const.),as a spring,leap,hop,vault motion ...
All the Bests! / Alex
iacob alex
...in simple words,comes up with a greater natural "avalanche" type fall ( longer gravity drop down ), for a same,constant jump up ("remake" of the unstable requirement).
By the way,the main problem is,I hope, to take out some power,not the self,only.
Thinking about "Big fall,small jump..." point of view,really,why make it easy,when you can it not possible ?!
Why to play Archimedes,when we can ornate the paper with "arabesque" decorative compositions,doesn't so ?!
iacob alex
...in simple words,it's a slight trace to think a possible "PM" in a distinctive manner.
We can take advantage of a longer gravity drop down (natural "avalanche" )/big fall ,so to provide the same small jump up ("remake" of the next unbalance sequence).
Big fall down-small jump up,can help us,not only to perform the self (museum performance...),but most important ,to get out some real power...
Anyway,a question remains:why make it easier,when you can make it...not possible?
Why to play Archimedes,rather than ornate the paper,with decorative "arabesque" flowers/wheels...it's more "simpatico",doesn't so?!
iacob alex
Hi !
Take a look at an experiment ( wheel concept alike Bessler's MT 13 ) , at :
https://youtu.be/Rgp6gcSaF2Y
It's Leo Ackermann's "Perpetuum Mobile Gravitations Rad" on Youtube...it has a small "stimulus"(impetus...) insufficient to maintain a "self" motion/rotation...
Now , let's experiment a possible greater impetus , with a lever concept , as :
www.geocities.ws/iacob_alex/Some_Drafts/text048.jpg
www.geocities.ws/iacob_alex/Some_Drafts/text029.jpg
Al_ex
Leafy
Post by Leafy »
Hmm if this is real then I could rest my case. Nice design though, looks smooth when transition.
iacob alex
Re: Big fall,small jump...
