Mick - my quick reference to Newtons Cradle didn't really explain things very well. I made the reference to Newtons Cradle to introduce the subject of Momentum being a Conserved quantity. Which means that if we transfer or share momentum from a heavy mass to a light mass, the light mass has to move faster. (Yes - Momentum = Mass X Velocity)mickegg wrote:.....Newton's Cradle does not demonstrate this....this is the problem we are having at the moment.
A method is required to transfer all the momentum from the large mass to the smaller..........other than the cylinder and spheres.
...any ideas? <grin>
Mick
The problem, as you correctly observe, is transfering all the Momentum from the Heavy mass to the Light mass. Pequaide has given us two methods - the Cylinder and Spheres, and the Bolas method.
Personally, I think the Bolas method matches with Bessler's description of the 'dog on a leash - straining as far as he can go'.
Remember that Impulse = Force x Time, and is equivalent and convertible with Momentum. If we connect a slow moving Heavy mass with a stationary Light mass via a rope, at the point where the rope tightens, the Force within the rope will be equally shared between the two masses for the equal amount of Time. That means for the duration of that Impulse, the Momentum gets shared equally.
With an Atwoods, we can generate as much surplus Momentum as we want by increased the Ratio between the masses. So even if we can't transfer All the momentum from Heavy to Light - we can at least transfer half by using the Bolas method. So providing we generate twice as much Momentum as we need, half is plenty.
Surplus Momentum can always be absorbed into a damping system, and used as surplus energy. Hydraulic or electromagnet systems spring to mind ...
The cylinder & spheres is superior, because it allows the total transfer of Momentum.
Something I notice about the nay-sayers who disagree with Pequaide is that they never seem to follow the complete recipe for success. The 3 components all need to be brought together to make it work. Bessler himself mentioned that his system depended on a correlation between the various components.
