picture of bidirectional wheel from Georg using COG-technic
Showing my wheel as promised.
complete wheel
complete wheel
re: picture of bidirectional wheel from Georg using COG-tech
and the internal view.
and internal view
and internal view
sequeen
Post by sequeen »
Hi George.
Is your wheel rotate by itself after initial push?
I don't say I can do it, I do it until I can.
Hi SK,
this version, about 50 cm in diameter and small weights is not running.
But there are 3 parameters, which I can change, to get it running, maybe i change it in the next days.
First i can increase the count of rollers, second I can increase the internal mass and third I can buildt a wheel with a bigger diameter. Maybe you have the possibility to buildt it larger.
Patrick
Post by Patrick »
Hi Georg;
Your wheel looks great. I wonder how it would roll on its own if you took it off the axle and just let it roll on a flat surface? Maybe an interesting experiment to try.
best regards--Patrick
Hi Patrick,
i did that already, i made several test, on a complete flat surface, it stops after 3 turns.
When I increased the swinging mass, it stops after 6 turns.
On a nearly flat surface it accelerates to about 1 revolution per second.
From the building size I am able to increase the swinging mass to 300 percent. I am on the way to make this modification and then do the test again.
hartiberlin
Re: re: picture of bidirectional wheel from Georg using COG-
Post by hartiberlin »
Georg Künstler wrote:and the internal view.
Hi Georg,
I thought you would use now your sheme over here:
http://www.kuenstler-energie.de/Gravit/einfac~1.htm
Did you still change that again ?
Where are the springs now or
is this another wheel ?
Regards, Stefan.
