mathematics alone make us feel the limits of our intelligence
mathematics
mathematics
hi
hi to all
i want to join the forum,thanks
re: mathematics
hi
bessler said:i would success in my project!.the right path is there-the thing is some where in natures' law.
hi to all
re: mathematics
hi
the most difficult is the building(physical implementation of the idea)
hi to all
re: mathematics
hi
i
i
f your machine design does not have an internal structure with free movement there ,it will never work.
hi to all
re: mathematics
hi
self turning wheel requires some force other than gravity in order to work,this fact has been know since before bessler's time.
hi to all
re: mathematics
sadiq attamish
I believe Bessler would say differently. ;-)
???self turning wheel requires some force other than gravity in order to work,this fact has been know since before bessler's time.
re: mathematics
hi chirs
how do you know that i m smoking cigar.that is true i m smoking natural cigar.
hi to all
re: mathematics
hi AB Hammer
i dont thing so,any how if not bessler said,now this is my statement.thanks
hi to all
sadiq attamish
Well lets look at it for a moment. What force or action can happen without something? Your device it there and only gravity is available. If you have wind for your device it will fall under a wind device. If you have water, it is under a water device. If you have steam or heat, who is tending the fire or is it from the volcano? If you have the sun, you have solar. All that is left is gravity or magic. So you ask yourself. Which one can you prove? What else do you have? If not gravity.
A gravity alone powered wheel will be proved. That does not prove perpetual motion yet. ;-))
re: mathematics
hi alan
no need to go for long discussion, let put in this way,say your weight 75kg & also my weight 75kg .if we stand on the gable end of seesaw it will balance,may be your friend give you helium ballon (same size of foot ball),what will happen if you still standing at the same seesaw?.thanks
hi to all
re: mathematics
hi
if hold stubby ,i thing the seesaw will un balanced.if up or down thats what we need to cheat the gravity to make something great.thanks
hi to all
sadiq attamish
weight and leverage do effect at the axle/fulcrum of a device. This is a given of leverage and weight value. If a hundred lb steel ball and a one lb steel ball fall from the same height. The will hit at the same time, but the impact of the hundred lb steel ball will leave a bigger impression due to it mas and weight. These are basic understandings. But lift 4lbs 4 feet with 1lb dropping 1 foot. Now you have a shocked world of science. LOL
re: mathematics
hi AB hammer
not simply like that,there is CF force,inertia,torque,natural force to make tow-graviton(extra energy) as well as the very important is the gravity.thanks
hi to all
