Wiki
Stewart
Wiki
Post by Stewart »
Hi Scott
I'm getting the following error every time I update a page on the wiki:
Code: Select all
A database query syntax error has occurred. This may indicate a bug in the software. The last attempted database query was:
    (SQL query hidden)
from within function "SearchMySQL4::update". MySQL returned error "145: Table './srellis_bessler/wiki_searchindex' is marked as crashed and should be repaired (localhost)".
...could you have a look please and see if you can fix it? Thanks...
Stewart
scott
Site Admin
Site Admin
re: Wiki
Post by scott »
Sorry Stewart, the wiki is so overrun with spam I had to disable all updates, and now the table has crashed. I will deal with it when I can but no promises. Please feel free to remind me.
-Scott
- Pierre Proudhon, 1881
- Michel de Montaigne, 1559
- John Milton, 1667
Stewart
Post by Stewart »
Hi Scott - thanks for the reply. It's not a major problem - I can still update the pages, but just get that error after it's updated. I'm not sure if the wiki gets looked at much - I didn't get any feedback on my edition of the documents page to it, so I'm left wondering whether it's worth doing anything further on there. Anyway, thanks for your help. Stewart
re: Wiki
I believe the wiki is a very good repository of accurate updated information & that it is looked at & quoted often as a base resource - Scott mentioned quite a while ago that it was overloaded with spam & that he had shut down the ability to update/edit it, so if like me, many have not attempted to edit it for perhaps a year or longer.
So I'm surprised & pleased Stewart that you were able to as I hadn't expected that you'd be able.
DrWhat
Post by DrWhat »
I look at the wiki a lot.
justsomeone
re: Wiki
Post by justsomeone »
Same here Dr. and thanks Stewart.
path_finder
re: Wiki
Post by path_finder »
Dear Scott,
I have access to the Wiki only in reading mode.
No way to edit anything.
See screen copy below.
The cookies are enabled. The link at the top right loops on the same error.
Stewart
Post by Stewart »
Ok, thanks guys - I wasn't sure if the Wiki was reliable or safe to use after Scott's comments, but I'll carry on with it now I know that it's ok and people are using it. I've been keeping a back-up of the wiki markup code I've created for that page anyway so that if anything happens I can just put it back.
Stewart
scott
Site Admin
Site Admin
Post by scott »
I thought I disabled editing and adding new pages but I guess not for everyone. In any case there are hundreds of spam pages on it and no easy way to remove them that I can find. If someone wants to help out I'd be very grateful.
Thanks,
Scott
scott
Site Admin
Site Admin
Re: re: Wiki
Post by scott »
path_finder wrote:Dear Scott,
Path Finder, you need to create a new account on the wiki using the same name you use on the forum (path_finder). The wiki does not use the same login mechanism as phpbb.
Thansk,
Scott
- John Milton, 1667
Stewart
Post by Stewart »
Hi Scott - I'll have a go at deleting the spam if you like but I don't have delete privilege at the moment it seems. Stewart
path_finder
re: Wiki
Dear scott,
It is exactly what I tried to do with NO success..
I suspect the underscore may be not supported in this part of the software.
