Frank, it's not a matter of what I like. Your gravity wind powered engine is not an example of a real exception just like a fairy powered engine isn't an example of a real exception. ie; neither are real.Grimer wrote:You may not like the answer, Bill, but I did answer your question.
Scissors Simplified
re: Scissors Simplified
Gravity is a real energy source. Wind is a real energy source. Wind was a real energy source, albeit unexploited, before the invention of windmills.
Gravity is the real energy source in hydro. It's not the ultimate energy source but if we start tracing things back to first causes uncaused then we leave natural philosophy and move on to theology.
You might as well say that petrol is not a real energy source because without the sun there wouldn't be any petrol.
No matter how you try to intellectualize it, gravity has no mass. It is pure energy force.Grimer wrote:Certainly.daxwc wrote:So then the earth is growing?
By the accumulation of meteorites for one thing.
The Earth is growing as the energy force of gravity is changed to mass at a rate of E = MC^2. Gravity also heats the Earth's core. Gravity is a shadowing effect and thus most of the gravity energy absorbed by the Earth turns to either heat or forms new matter. This is why the Earth and the universe is expanding, not because of some big bang theory.
But still, gravity does not have any mass and therefore it cannot turn any windmill type device.
See this older post for a link to Stan Byers website concerning the cause of gravity.
Of course the usual disclaimer that I reserve the right to be wrong.
Irrelevant. A similar diversion would be to say a spring is the real energy source in a clock.Grimer wrote:Gravity is the real energy source in hydro.
The question stands.
I suspect Frank may be right on this one, the spring is the energy source. There comes a point when human knowledge limits how far back we can work things. We know that somebody wound the spring, that the said somebody is an inhabitatant of the planet earth, member of one of the homonid species. Further we can only speculate (or believe) that earth was created by (cross out where appropriate) God, random sequence of events, terraforming by aliens (or MIB), other.
Nick, discussion becomes pointless without context.
Hi Jim,jim_mich wrote:Gravity also heats the Earth's core. Gravity is a shadowing effect and thus most of the gravity energy absorbed by the Earth turns to either heat or forms new matter.
A few things:
1.) Matter cannot be created or destroyed. Gravity does not form new matter.
2.) If gravitational force can be converted to heat isn't that an example of the energy that causes gravity to exist (E=MC2) being converted back into usable energy (heat)?
E
- eccentrically1
- eccentrically1
Read Stan Byers website: http://home.netcom.com/~sbyers11/grav11k.htm
If Gravity is a shielding effect then something must happen to the gravity that is blocked by the Earth. There is much evidence to suggest that Stan Byers is correct.
I agree with Stan Byers and would add to his conclusion and research one more thing...
Where Newton Struggled and Einstein balked; we can complete the summation of Stan Byers works...."Absorption"
I.e. Absorption is a natural consequence to Byers Radiation, in the same sense that there exist:
...condensation and evaporation
...impact and momentum
...energy and force
(E=mc2) is actually a quantative value denoting an Energy paradox. It is the precise calculation of the" threshold value of energy"
It is the point at which energy is constantly "created and destroyed"
the paradox is that, at E=mc2 Energy is at both its greatest and least potential..It is the point at which mass ceases to exist (speed of light in a vacuum) and Force is "non restricted"....after all, energy is by definition, the result of "restricted Force."
above mc2 Force is infinitely unrestricted or absorbed. below mc2 Force is a quantative value, expressed as energy, which is the same as the restricted or absorbed force.
Stan Byers is clearly Brilliant....we must add absorption to radiation and conclude, that there is one energy and one force and both are "work" in terms of restriction, absorption and quantified in terms already familiar to us.
I see a future when men Like Byers and Euler are mentioned side by side with Newton and Einstein...
thats my story and I'm sticking to it...:-)
...energy and force
I'm sorry... What?
Matter and energy cannot be created or destroyed. Period. It can only change form.
My point, which seems to have been missed. Is that if the theory that gravity is a side effect of general relativity is true than gravity is the result of massive amounts of energy causing an object to accelerate (a-la the Big Bang) which causes a gulf in space time which we call and experience as gravity. If energy creates the effect of gravity than perhaps the gravity can be converted back to energy. We see this all the time in the form of our Earth's core and the Sun (energy in the form of heat and pressure).
As for the discussion of Stan Beyer's theory: With all due respect that sounds like a bunch of utter nonsense.
E
E
