Hydro-Tank: Poll Opinion
In your opinion...
You may select 1 option
View results
Oxygon
Post by Oxygon »
I recently found this "quote" from "Anonymous #580" in the last post in a thread at GNN.com Forum Post (Guerrilla News Network)...
I asked "Jonathon" in a private message what he thought of it, now that I have his opinion... he can post it if he wishes
I want to know what you all think as well?...
here is the quote:
The "experts" say you can fill a resivor tank with water using an electric water pump and a hose over the side, drain the tank through a turbine generator, and the most you will do is break even, generating only as much electricity as it took to fill the tank with the electric pump in the first place.
This is a lie too but we'll humor them and use their electric pump,
no problem, I won't dispute their words at all, okay little feller?
Now put a 3000 ton fraighter ship in the resivor. It floats in the ocean, it will float in the resivor tank. When the water rises the ship will rise with it, no extra work on the top feed water pump. Drain the resivor tank through the turbine generator breaking even on the initial electricity. You still have a 3000 ton fraighter ship hanging in mid-air via cables ready to use with gravity and a linear generator all night long until morning when you start the whole process over again.
...Free energy.
any opinions?
As far as I understand it would take no additional energy from the top feed water pump to raise a multi-ton vessel up and retrieve this stored energy potential after the resivor is empty... also one could utilize the up-float of its path while the resivor fills...
sounds like F/E to me...
maybe this is my idea, maybe it's not... ;)
hope this... at the least it gets some good thinking going on.
F/E in 2004! ;P
Kirk
re: Hydro-Tank: Poll Opinion
Post by Kirk »
consider this. The hull displaces water to the point the mass is supported. In a fixed enclosure with a fixed fluid the fluid would rise as the apparent quantity is increased. It is increased by the quantity called "displaced" This is the quantity with an equivalent mass.
If instead the water is pumped into a container just filled with air and the ship the level will rise eventually raising the ship. If the ship is then secured and you drain the water the water will drain quicker in the space occupied by the hull as the available liquid has some missing due to "displacement" That volume represented by the hull will not be available to drain. Were the ship free to descend with the liquid the height would be increased by that volume and height until the hull reached bottom.
I hope I have presented this clearly enough.
Kirk
coylo
Post by coylo »
I suppose you could run your own experiment with a block of wood in your kitchen sink. Until then the jury is still out for me. I have to say I like the idea, however a tanker is not designed to be suspended from cables, it could break up. An alternative is required.
I would recommend not completely draining all the water. Drain to the level where the tanker just floats without resting on the bottom.
Kirk
You tried your best, but.............
Oxygon
Re: re: Hydro-Tank: Poll Opinion
Post by Oxygon »
Kirk wrote:consider this. The hull displaces water to the point the mass is supported. In a fixed enclosure with a fixed fluid the fluid would rise as the apparent quantity is increased. It is increased by the quantity called "displaced" This is the quantity with an equivalent mass.
Kirk
ha? ... ;|
statements are hard to understand...
the idea is to raise a (3ton.approx) vessel up by adding water to a (5ton.approx) resivor by a top feed pump, the added water lifts the vessel (not ship) up, and upon/during/after the release of the pumped water to the lower resivor, the suspended/supported vessel can generate energy on the way down from its height. also the vessel may be utilized to generate energy on the way up too (buoyancy)
pumped water in/drained water out, break even maybe
Add to that
lifting vessel up = generating energy / lowering vessel down = generating energy
...problems
simple.
here is a picture...
Jonathan
Post by Jonathan »
The reason why it doesn't work depends on the exact design (w/ or w/o bouyancy, number and placement of pumps and turbines, etc.), but I'm not just good enough with fluid mechanics to begin to explain why I don't think it will work.
Actually that is the basis of an idea I've had "floating" around for a decade or two for creating electricity from tidal rise & fall. Except instead of anchoring your boat to a mooring you anchor it to inground block & tackle (pulley) directly beneath the "vessel", which then connects via a spring loaded cable to a land based generator/turbine. The vessels bouyancy causes it to rise with the tide pulling the cable thru the generator & turning a geared armature etc. The spring tension (or counter weight arrangement) reverses the action as the tide falls. A short but powerfull stroke 4 times a day limited by anchoring strength & bouyancy so can be scaled. Just like a elevator/lift with counter weight but the electric motor becomes a generator.
As for your "intellectual problem" I would think that the the power generated from the water as it drains from the tank is dependant on the "head" or pressure (atmospheres) of the water created from vertical water height, & as the water level drops the water pressure avaiable to drive the turbine is less, therefore once the ship is suspended the displacement it created is "swallowed up" (causing a rapid drop in vertical water height) & the ability to do work drops proportionately so no extra energy in the system. That's because bouyancy/dispalcement doesn't change internal pressure between individual water molecules in an open system - Bournelli's theorm I think ? - just my opinion, I'm no expert. Convince me otherwise.
-Fletcher
Michael
Post by Michael »
If the water is being raised by the moons gravitational pull, then, in a way, there's free energy. Not quite, but in a way.
Otherwise not.
Reg.
Mike
It won't work. Here is a very simple analysis of what would happen.
[1] On the left the green vessel floats.
[2] In the middle the water level is raised by pumping the red square full of water.
[3] To the right we have drained water in the red rectangle through our generator and no longer have any pressure.
[4] On the far right is our water source.
But we are short a whole lot of water through the generator compared to how much we pumped!!
If our water source was lower we would get similar results. Just that we would be pumping water higher and draining it lower.
Oxygon
Post by Oxygon »
you lost me...
All I am saying is that we can still extract energy from a used process...
One which does fall short of O/U can be used to facilitate another potential without consuming any of the former process potential...
As for the comment regarding the lower pressure with loss of water, there are way around that: large horizontal/wide resivor, deep penstock ,etc...
here I used the above image again...
(1)-filling (2)-full (3)-drained/remaining potential (4)-process restarting
many pumped-storage plants utilize the process of pumping and releasing water to maintain power needs... here an additional supplemental power is created without consuming from the earlier process...
I dont want to sound off soo much, I just don't see the flaw in my understanding...
Tausen
Post by Tausen »
yeah you have to drain all the water Jim.
You would have some loss I think. From the water draining and replenishing. If you had a big enoff tank you might be able to gain some energy with floating weights. I think atleast.
T.
Oxygon
Post by Oxygon »
I was going to post another image, but dont want to keep pushing my images on besslerwheel.com without need...
the connecting pipe (penstock) maintains the pressure (pipe beneath the upper resivors release gate) most of the stored energy remains in the large wide shallow high compacity resivoir.
Actual length not shown... in previous image "energysurplus.jpg"
(imagine edit) ;)
OK what goes up must come down. But the path may vary. Lets say we take figures like I used before.
Since I used real numbers to make the drawing I'll use the same to descibe them.
The small red rectangle is the water pumped in until the vessel starts to float. It measures 1 x 4.5 with a volume of 4.5
The large rectangle is the water pumped in after the vessel floats. It measures 5 x 5.5 with a volume of 27.5
If we assume it takes 1 unit of energy to lift 1 unit of water 1 unit high, then the following is the results. I broke it down into 1/2 unit increments.
Code: Select all
 HIGH  VOLUME  ENERGY
 0.50 * 0.50 =  0.25
 1.00 * 0.50 =  0.50
 1.50 * 0.50 =  0.75
 2.00 * 0.50 =  1.00
 2.50 * 0.50 =  1.25
 3.00 * 0.50 =  1.50
 3.50 * 0.50 =  1.75
 4.00 * 0.50 =  2.00
 4.50 * 0.50 =  2.25
Total up1  =   11.25
 5.00 * 2.50 = 12.50
 5.50 * 2.50 = 13.75
 6.00 * 2.50 = 15.00
 6.50 * 2.50 = 16.25
 7.00 * 2.50 = 17.50
 7.50 * 2.50 = 18.75
 8.00 * 2.50 = 20.00
 8.50 * 2.50 = 21.25
 9.00 * 2.50 = 22.50
 9.50 * 2.50 = 23.75
10.00 * 2.50 = 25.00
Total up2  =  206.25
10.00 * 0.50 =  5.00
 9.50 * 0.50 =  4.75
 9.00 * 0.50 =  4.50
 8.50 * 0.50 =  4.25
 8.00 * 0.50 =  4.00
 7.50 * 0.50 =  3.75
 7.00 * 0.50 =  3.50
 6.50 * 0.50 =  3.25
 6.00 * 0.50 =  3.00
 5.50 * 0.50 =  2.75
 5.00 * 0.50 =  2.50
Total dn1  =   41.25
 4.50 * 2.50 = 11.25
 4.00 * 2.50 = 10.00
 3.50 * 2.50 =  8.75
 3.00 * 2.50 =  7.50
 2.50 * 2.50 =  6.25
 2.00 * 2.50 =  5.00
 1.50 * 2.50 =  3.75
 1.00 * 2.50 =  2.50
 0.50 * 2.50 =  1.25
Total dn2  =   56.25
Total up   =  217.50
Total dn   =  -97.50
Result     =  120.00
The results are self evident. The difference will be returned when the vessel drops which is the work required to lift the vessel.
Oxygon
Post by Oxygon »
jim_mich wrote:
Code: Select all
 HIGH  VOLUME  ENERGY
 0.50 * 0.50 =  0.25
 1.00 * 0.50 =  0.50
 1.50 * 0.50 =  0.75
 2.00 * 0.50 =  1.00
 2.50 * 0.50 =  1.25
 3.00 * 0.50 =  1.50
 3.50 * 0.50 =  1.75
 4.00 * 0.50 =  2.00
 4.50 * 0.50 =  2.25
Total up1  =   11.25
 5.00 * 2.50 = 12.50
 5.50 * 2.50 = 13.75
 6.00 * 2.50 = 15.00
 6.50 * 2.50 = 16.25
 7.00 * 2.50 = 17.50
 7.50 * 2.50 = 18.75
 8.00 * 2.50 = 20.00
 8.50 * 2.50 = 21.25
 9.00 * 2.50 = 22.50
 9.50 * 2.50 = 23.75
Total up2  =  206.25
10.00 * 0.50 =  5.00
 9.50 * 0.50 =  4.75
 9.00 * 0.50 =  4.50
 8.50 * 0.50 =  4.25
 8.00 * 0.50 =  4.00
 7.50 * 0.50 =  3.75
 7.00 * 0.50 =  3.50
 6.50 * 0.50 =  3.25
 6.00 * 0.50 =  3.00
 5.50 * 0.50 =  2.75
 5.00 * 0.50 =  2.50
Total dn1  =   41.25
 4.50 * 2.50 = 11.25
 4.00 * 2.50 = 10.00
 3.50 * 2.50 =  8.75
 3.00 * 2.50 =  7.50
 2.50 * 2.50 =  6.25
 2.00 * 2.50 =  5.00
 1.50 * 2.50 =  3.75
 1.00 * 2.50 =  2.50
 0.50 * 2.50 =  1.25
Total dn2  =   56.25
Total up   =  217.50
Total dn   =  -97.50
Result     =  120.00
how am I supposed to respond to that....?
Since you speak in a strange foreign language, I'll just plug my ears, OK.
;P
Jonathan
Post by Jonathan »
I thought it was pretty clear, the energy used to pump the water is greater than the energy gotten when releasing it by exactly the amount of potential energy gained by the vessel.
Lightwave
Post by Lightwave »
this may be simular... but diffrent :-P
http://www.theverylastpageoftheinternet ... oyancy.htm
Lightwave
