The weights I'm currently working with weigh exactly one pound according to my postal scale. They are cylindrical and measure 3/4" thick (or long) and have a 2 1/8" diameter (they're made from lead I poured into small Red Bull cans.). If I decrease the diameter to 1" how long will the cylinders be?
Thanks in advance for any help.
I have a question for an engineer please.
re: I have a question for an engineer please.
Oops- sorry- I found this link.
http://www.matweb.com/tools/weightcalculator.aspx
Looks like it would be 3.2 inches long (the internet never ceases to amaze me.)
- path_finder
Dear Ben,
Unfortunately, you are too much confident in the computers. I guess your result was wrong.
On my own side I refuse to be the slave of any computer.
May be, I have been polluted by the HAL deconnection in '2001, a space odysse' from Stanley KUBRICK...
So far like Tarzan, I made the computation myself, see hereafter.
This kind of exercise is good against the Helzenheimer disease...
Many thank to you.
The volume of a cylinder is given by: V = pi x R² x L
where R is the radius, L the length, pi = 3.14
If you decrease the diameter of 1" the volume will decrease from V1 to V2 (V1=before, V2=after)
V1= 3.14 x (17/16) x (17/16) x (3/4)
V2= 3.14 x (9/16) x (9/16) x (3/4)"
V1 - V2 = 3.14 x ((289-81)/(16x16)) x 3/4 = 3.14 x (208/256) x 3/4
where (V1-V2) is the mass to add to the V2 cylinder, which will have a new length L3
The old volume V1 must be equal to the new volume
V1 = 3.14 x (17/16) x (17/16) x (3/4) = 3.14 x (9/16) x (9/16) x L3
then
L3 = (17/16) x (17/16) x (3/4) x (16/9) x (16/9)
L3 = (17 x 17 x 3 x 16 x 16) / (16 x 16 x 4 x 9 x 9) = (289 / 108)" = 2.6759" equal about to 2" 2/3
I can now testify the calculation of this computer is correct. See below the screen shots.
Many thank to you.
then
Thanks, PF, for your response and your time. Ungowa Tarzan!
Path
Ben required the diameter to be reduced to 1 inch diameter....not by 1 inch diameter.
r1 = 1.0625 L1 = 0.75
r2 = 0.5
L2 = (r1 squared x L1) / r2 squared
L2 = 3.38671875
Mick
Edit.......pi cancels out
r2 = 0.5
L2 = 3.38671875
Mick
Yes, and I also noticed that no material was selected on the screen shots
[/img]
The actual weights are indeed 2 1/8 inches long. I drilled 1 1/4 holes into 4X4 blocks. The holes were about 2 1/2 inches deep. I then set the blocks on the scale and turned it on. It sets at zero. I then poured the molten lead into the hole until it read one pound. When the lead cooled, I split the wood with chisels.
So, the physical weight verifies the calculator- at least for lead.
Edited to add--
I did start with a 1" diameter in mind, but a three inch length was way too long for the model I'm working on, so I settled for a 1 1/4" diameter.
[/img]
Edited to add--
