Fernando Sixto Ramos - Force Multiplier
honza
Post by honza »
This invention appears to be a genuine breakthrough. Apparently able to multiply the input power many times over. Verified by Peru officials and awarded best Peru invention 2011.
It appears to work as a mechanical oscillator. The power gain does not seem to be explainable with the current laws of physic / mechanic as we know it - yet it produces overunity of an unparalleled magnitude.
Hardly any publicity outside of Peru - very little in English.
I suspect that we can learn a lot from this.
http://www.youtube.com/watch?v=pJfiDmWaXuA
http://www.youtube.com/watch?v=rUkh7PWuz30
http://www.youtube.com/watch?v=UkfAUXnAnpE
Aman
Post by Aman »
Honda,if you can translate everything in the videos into short brief English text description ,then we can understand about it,else we won't be able to understand it.Please provide some more information in english with some photos,descriptions,etc.
Science is the king,commerce and MBA are servants of mankind.True Gravity-magnetic powered engines are possible but they cannot be against 3 basic laws of thermodynamics and newton's laws of motion.
Aman
Post by Aman »
honza wrote:.........Apparently able to multiply the input power many times over............It appears to work as a mechanical oscillator. The power gain does not seem to be explainable with the current laws of physic / mechanic as we know it - yet it produces overunity of an unparalleled magnitude.
Mechanical oscillator,if really works,may not violate laws of physcis,it is just that the inventor does not disclose about the hidden Amplified Gravitational energy input.
95 percent working Gravity engines work on the principle that the Gravity engine/Gravity wheel systems are innovatively designed to take in (consume) much more Gravitational energy than what energy needed to lift heavy ball/pendulum arm upward.
If you substract total Gravitational energy input from the energy needed to lift heavy balls/pendulum arm up in a gravity wheel/Gravity engine,you get some net gravitational energy which is the net energy input to the system(input after subtraction) which can be converted to electrical energy.This is the scientific basis for any real Gravity engine.And hence real Gravity engines are not perpetual and do not violate Laws of energy conservation.
When a Pendulum oscillates,it comes under influence of Continuous Gravity points like an array of gravitational waves,hence some mechanism can be used to tap that energy.
Really he should be a genius,he cannot disclose about the hidden mechanism using more amplified Gravitational energy,may be just because most people are not intelligent enough to understand and accept his invention OR may be because he wants to patent it.
DrWhat
Post by DrWhat »
The movement is not smooth. So I have my doubts.
murilo
re: Fernando Sixto Ramos - Force Multiplier
Post by murilo »
They don't show and it's not easy to see what he's doing, besides looks familiar.
If he won a bronze medal with this huge OU, which are the invents that won gold and silver in this Swiss exposition?
(our competition never sleeps! 8(
Best!
M
pstroud
Post by pstroud »
Over the past 3 weeks, I have downloaded many videos of interviews with Fernando Sixto Ramos, showing his device. If find it quite fascinating and worth exploring. The articles state there is a 30X multiplication of force.
Some videos show the oscillating horizontal rod having what looks like springs pulling it down towards the base. Another shows a vertical inverted like pendulum flipping side to side up in the air as it oscillates.
I find it very interesting.
Preston
Trev
Post by Trev »
Would be great to get some translations... please, anybody?
EDIT: found these-
http://orbo.es/
http://www.peswiki.com/index.php/Direct ... ier_System
https://www.youtube.com/watch?v=4wz0XALlLNU
murilo
Post by murilo »
After new looks it was not possible to understand the design and eider find something to build a believe.
They don't open the show and this makes a VERY hard to believe stuff.
Let's wait...
M
LustInBlack
Post by LustInBlack »
I made a quick prototype of the sixto ramos, at least, the best I could do at the time with the information I had..
There must be something missing because it certainly acts like a very good brake..
getterdone
Post by getterdone »
Hi LIB, if you are using belts similar to Fernando's, make them as loose as possible. This might help
LustInBlack
It was actually in ABS plastic and a crude test. I guess the problem is that there are specific dimensions for the machine to work.. But it didn't seem like overunity to me.
Trevor Lyn Whatford
Post by Trevor Lyn Whatford »
Hi all,
I have only taken a quick look but Leverage recoil may be the secret on this one!
Edit, shunt and shunt back!
I have been wrong before!
I have been right before!
Hindsight will tell us!
