Non-Perpetual Gravity Powered trains
Aman
Post by Aman »
Please see a simple figure on:
http://flic.kr/p/cXHXZm
How about a gravity powered train track.
Supply less amount of energy to lift a train box over less distance and let recover the supplied energy over a large slopping distance through wheel connected generator inbuilt in train box.
The amount of energy needed to travel through larger distance is very much greater than energy needed to travel though a very less distance.If you don't agree with this,then it is against law of Energy Conservation which is never possible.
It obeys the principle:
Mostly real Gravity engines should work on the principle that the Gravity engine/Gravity wheel systems are innovatively designed to take in (consume) much more Gravitational energy than what energy needed to lift heavy ball upward.
So if you are ready to travel in a gravity powered Bumpy train ride,here is a gravity powered train!
And yes,notice that the wheel weight of train passes through different Potential energies and not one potential energy point,that is it passes though Varrying gradient of potential energy.
Offcoarse I will need a battery in the train cart itself to store and dissipate energy in this concept,along with motor cum Generator attached to the wheel shafts.
This is not something extraordinary ,but some excellent simple observation which very few people do.Most People simply make a hype of Perpectual motion machines.
Real gravity powered devices are possible but they are not and can never be Perpetual Motion Machines which violate law of thermodynamics.
Science is the king,commerce and MBA are servants of mankind.True Gravity-magnetic powered engines are possible but they cannot be against 3 basic laws of thermodynamics and newton's laws of motion.
Aman
Post by Aman »
I always wanted to invent a car powered by Gravity.Nevermind,if my Gravity engine was not able to produce enough power,atleast we can have a Gravity Powered train!!!And further research could make my dream about Gravity Powered car,come true.
Wow,that awesome!
