force on a dam
bilbo
force on a dam
Post by bilbo »
Just a quick question- does the force acting on a dam from the water depend only on the vertical area of water and the depth of the water or is it also dependant on the volume of water as well?
I would have thought that the greater the volume of the water, the greater the force on the dam.
re: force on a dam
Volume has no effect on the forces - only height [depth] is important, & to remember that Thrust [force] = Pressure x Area & therefore P = F/A.
Try asking My Google about ...
Pascal's Law
Hydrostatic Pressure on dam walls
http://www.math.ucsb.edu/ugrad/fluid.pdf
re: force on a dam
Thank you Fletcher for not only explaining but for the posted link.
Having spent 20+ years in the hydroelectric profession I of course agree. Your link only adds another clip of ammo when I am ready to confront Jim_Mich regarding 3rd dimensional weights adding force to a wheel.
bilbo
re: force on a dam
Post by bilbo »
Thank you Fletcher- your post is greatly appreciated.
I remember doing fluid dynamics a long time ago and your link will help me refresh my memory.
re: force on a dam
Ralph:
Interesting statement though adding force or stress is not always adding movement.
Example: compress a gas beyond the structures limit it will blow up. Compress a fluid against a structure limit it will just crack. But the energy you add into both are also very different.
re: force on a dam
Dax,
The only force I refer to is mass and the gravitational Pe of said mass. No stress implied as one cannot compress a liquid, it does however expand and contract with temperature changing density or weight per unit.
No energy added other than gravity and quantity of mass per cubic inch or cubic feet depending on size of containment.
