Cold Fusion
Brian3051
Cold Fusion
Post by Brian3051 »
This is the ad that will be running next Tuesday,
It may be possible to slow or stop Global Warming if Cold Fusion is possible.
By placing CO2, H2O and CH2O in the same vacuum chamber, when the
vacuum exceeds 29 hgs, oxygen should be detected in the vacuum chamber.
This would demonstrate that the carbon element in CO2 can be transferred
to a water molecule creating 2 gasses, O2 and CH2O. In that all molecules would become gasses, this may be considered as equilibrium which the 2nd Law of Thermodynamics allows for.
If this is possible, it would allow for some oxygen to be returned to the
atmosphere. And since this would help to decrease the density of our
atmosphere, then less heat energy would be absorbed while allowing for more cooling at night.
The reason I'm running the ad is that I am hopeful that someone who has the ability to conduct this type of experiment will do so.
terry5732
re: Cold Fusion
Post by terry5732 »
There is not a vacuum pump strong enough to evacuate a hoax
Brian3051
re: Cold Fusion
Post by Brian3051 »
Terry,
The cost of the experiment is nothing. Kind of like the value of your opinion.
re: Cold Fusion
Kind of like the value of yet another sock puppet generated from an already multi-banned parasite.
Scott should jump on this before history repeats.
Brian3051
re: Cold Fusion
Post by Brian3051 »
ovyyus,
And yet if it works, you will be stuck with your opinion. BTW, Isn't it supposed to be Jim_Mich that accuses someone of being a sock puppet ?
I guess if that's all you have. :-)
edited to add; You know ovyyus, there was one thread where Jim_Mich wanted me banned for the heck of it. I was building and he wasn't. Plenty of people in here did want me posting my work in here.
Hey Mr. sock-puppet Brian3051, aka bobd, aka smith66, aka bobriddle, aka john, aka James.Lindgaard, aka to.late, aka Bessler_Supporter, aka Jim_Lindgaard, aka Jim_L, aka P-Motion aka wikiwheel aka Bessler007, please don't drag my name into this. You're on your own this time. I'll not dot anyone green or red. You can swim, or more likely sink, on your own past and present merits.
MrTim
re: Cold Fusion
Post by MrTim »
.It may be possible to slow or stop Global Warming if Cold Fusion is possible.
Doncha know? They're already building windmills like crazy to blow air over the earth to cool it off....
Brian3051
Post by Brian3051 »
Jim_Mich,
You're funny, LMAO !
Explaing a part of the photosynthesis process makes me a sock puppet ?
I happen to be disagreeing with a small group of scientists who claim tne 1st Law of Thermodynamics as the reason.
BTW way Jim_Micn, I also show my work and explain how it relates to Bessler's drawings and some of his writings. He did build 2 different wheels you know.
One of tnem used centrifugal force because the weights did not work together.
@ Mr. Tim,
Now you tell me !!!
re: Cold Fusion
Like a malignant cancer this parasite reappears again and again to infect the forum. Hurry up and die already.
Brian3051
Post by Brian3051 »
oyvvus,
you and Jim_Mich should resolve your issues that you two have. It's not healthy.
BTW, parasites and sock puppets do not promote life or need to discredit Bessler.
re: Cold Fusion
Cancer is never right.
