Fictitiousness
Fictitiousness
Unicorns, a fictitious type of horse!
Inertia, a fictitious type of force?
In another thread, Eccentrically1 posted a number of points of contention.
Rather than try to address ALL of these points of contention here in one post, let us take up only one or two points at a time. First, the background…
Jim_Mich wrote:Over eight MILLION hits concerning the phrase "Inertial Force"
Eccentrically1 wrote:That's not a surprise, there are over 19 million hits for unicorns, a fictitious type of horse.
Jim_Mich wrote:Inertia most definitely produces a force. So don't give me any crap that it’s not a force. It is the negative force which must be acted against for a body to accelerate. And depending upon your frame of reference is can also be a positive force.
Eccentrically1 wrote:It's not crap. Inertial force on wikipedia, the online encyclopedia we all love to use, redirects to fictitious force. So inertia, or, a body’s inertial mass, produces a fictitious force, if you prefer saying it that way. A real force, like friction for instance, can exist in either an inertial frame or a non-inertial frame.
Let us look at the following, which are related. Let us look and discuss what these have in common and the differences between each pair.
Inertial force -vs- momentum force
Fictitious force -vs- real force
I think we both agree as to what momentum is. It is the mass of an object times the velocity of the object. But the velocity of the object must be measured relative to some background inertial frame of reference. Ah, so right from the start, momentum has some relationship to inertia. So, in order to understand momentum, we need to also understand inertia.
An inertial frame of reference is normally considered to be the observer, who is considered to be stationary. Though in the big scheme of things, stationary is often considered to be the surface of the Earth, which is flinging itself thru space at some astronomical speed. But I digress. The most common inertial frame of reference is the Earth.
Inertia is often considered to be simply the mass of an object. Mass is different than weight. Gravity on our moon is a fraction of gravity on the Earth. In the Metric system of units and measurement, our gravity force is measured in kilograms of force. Inertia is also measured in kilograms. This is because inertia is the measurement of how much kilograms of force are required to accelerate one molecular equivalent of material. Each molecule of matter contain a specific number of atoms. And each atom contain a specific number of electrons, protons, and neutrons. And each proton has the same mass as every other proton. Each electron has the same mass as every other electron. Each neutron has the same mass as every other neutron. Thus the mass of each atom, say a hydrogen atom, has the same mass as every other hydrogen atom. The same goes for all matter. Science measure mass according to how much force it takes to accelerate the matter. The matter resists being accelerated in an exact ratio to the number of elementary particles present. We use the word 'inertia' to describe this resistance to being accelerated. Thus, inertia is simply the resistance that all bodies exert against any force acting upon the body.
Newton's Third law of Motion: When one body exerts a force on a second body, the second body simultaneously exerts a force equal in magnitude and opposite in direction on the first body.
Assume we have a first body exerting a force on a second body. The second body exerts an equal force backward. Where does this second force come from? What causes this second force of the second body to exert itself against the first body? The answer is that our universe supplied this second force. We label it as resistance to motion. We label it inertia. And we measure it as the equal and opposite force caused by the first object.
In school, many are taught that inertia is a fictitious force. Educators awhile back started using the words 'fictitious force' as a descriptor for forces that arise in our universe seemingly out of nowhere, and which often go by different names such as pseudo force, d'Alembert force, and in the case we are discussing here, inertial force. These ‘apparent’ or 'fictitious' forces act on all material mass.
Eccentrically1, you called a unicorn as fictitious type of horse. Thus your concept of the word 'fictitious' is that it does not exist. In school you were taught that the above mentioned forces are 'fictitious forces', and because you know the meaning of a fictitious unicorn, you assume that a fictitious force does not exit. The reason that educator use the words 'fictitious' is because the forces having this handle don't arise directly, but come into being indirectly because the universe resists and pushes back whenever any material matter changes velocity, speed, or direction.
Unfortunately in your mind, you mix the fictitiousness of unicorns with the fictitiousness of inertia. And you claim that that inertia force or inertial resistance to force is fictitious in the same manner that a unicorn is fictitious.
The modern school system has warped the minds of younger students. A force is a push or pull. Inertial force is the pull of the universe counteracting the push of a known force whenever objects accelerate, decelerate, change speed, or change direction. Such forces are actual physical forces supplied by our universe in reaction to opposite forces.
Calling such forces 'fictitious' is confusing to young students. It puts in their minds that such forces are like unicorns and don't exist. It would be much better if the scientific world used a phrase like 'universe force' in describing such forces, but hey, they have chosen to use 'fictitious force'. Giving such forces the nomenclature of 'fictitious' does not magically make them into unicorn-type forces.
The bottom line is that inertia exists. It manifests itself in the resisting force produced by the universe in which we live, whenever any object changes velocity or direction. In other words, whenever any object accelerates or decelerates. When you measure the resisting force of inertia, it is equal to the change of momentum. It this sense, inertial force is the inverse of momentum force. If you truncate the phrase 'inertial force' to simply 'inertia' then it becomes the same as truncating the phrase 'momentum force' to simply 'momentum'. Momentum is mass times velocity. When the velocity is zero then you have just the mass with no velocity. Inertia is mass without the velocity. We don't assign any values to inertia because it is understood to be mass at zero velocity. So inertia becomes more of a concept than an actual quantity of physics. Instead, we use the word 'mass', which in reality is a measure of the inertial resistance of material being accelerated.
The bottom line... All Earthly materials exhibit resistance to change of motion. This resistance is often called inertia. Inertial force is the resisting force. Mass has two meanings which are often mixed. If you weigh an object on a scale you will say its weight measurement is a certain number of kilograms. This is a measure of its gravitational force caused by it physical mass. If you transport the object into outer space then its weight measurement drops to near zero. But its mass stays the same. It will still take the same force over a same distance to affect a same change of velocity as it does here on Earth. This resistance to change of motion is not momentum, though you might call it negative momentum. But we call it inertia. And inertia has an initial velocity component of zero speed. Thus inertia is simply zero momentum.
Inertial forces are NOT fictitious in the same sense a unicorns. It is unfortunate that educators and academician have chosen the word 'fictitious' when referring to forces derived from and supplied by the universe within which we live.
I'm going to scream the next time anyone claims that a force is not an actual force because some academician decided to label certain forces as being 'fictitious' and thus in some peoples mind they think such forces don't exist in the same sense that unicorns don't exits.
Sorry for such a long post. But when I truncate my writing it seems many don’t comprehend what I write. And if I let the words flow, I’m sure I’ve lost many reader after a few paragraphs.
How often have I said to you that when you have eliminated the impossible, whatever remains, however improbable, must be the truth?
re: Fictitiousness
I was making a little joke about the unicorns, sorry, it was too subtle. I wasn't implying fictitious meant the same thing in both cases. I know fictitious doesn't mean the same thing for forces as it does for unicorns.
Part of the joke was you can get hits on the internet for practically anything except unrecognizable gibberish. Simply typing a search string falls far short of an argument, jim.
Part of the joke was a reference to Bessler's quote about the cart before the horse. In a PM wheel, the wheel is the cart, and the horse of course is the unicorn. Because you need an actual horse to pull a cart, not a unicorn, you also need an actual prime mover, or energy source, to rotate a wheel. Forces in any combination, either real or "from the universe", can't do it because they are all opposed, as we all know. Internal forces must cancel, gravity cancels in any situation, EM forces all cancel in any situation, and nuclear forces cancel. When inertia is a force in an observers' frame, it is cancelled.
The real "horse" in any motion, ANY motion, is the form of energy transformation that takes place. The forces in the motion are a consequence of that, not the other way around.
Real forces cause changes in acceleration, proportionally to the mass. Forces are not the cause of motion. Energy conversion is the cause. In everyone's favorite mechanism, the pendulum, the motion is caused by energy conversion, not gravitational force. In a perfect vacuum, which can't be reached (absolute zero), it is all converted, none lost to heat, and you'd have a PM.pendulum. But not over unity! Why would you have PM? Not because of gravity, I think we both understand that. Or do we?
Momentum is not a force. Momentum is mass times velocity, not mass times acceleration. It's an instantaneous measurement of the object. Force is mass times acceleration. The difference between force and momentum is momentum can be a constant - velocity can be unchanging. Force is always accompanied by an +/- increase, also indicating the presence of energy conversion. If the velocity changes, then there is an unbalancing force, and energy is being converted. If the velocity is constant, there is a zero net force.
But, can the velocity of anything ever be constant? Not unless you can produce a perfect vacuum. Velocity is always changing in the real world. Nothing is ever at "rest" because you can always choose a frame of reference where it is in motion. What does that imply? Momentum doesn't exist, except as a formula that represents a perfect world.
Ok, back to work.
cloud camper
re: Fictitiousness
Post by cloud camper »
OK Ecc - very clearly stated.
The idea is that since all forces cancel within an unpowered structure, that structure then becomes symmetrical.
I think JM will now be very relieved to finally understand why he spent 10 years in a fruitless attempt get his concept to work!
It wasn't him, it was simply the laws of physics that prevented operation.
Now JM will finally be able to move on to other possibilities!
A sextuple post!
That might be a record, lol.
Gill Simo
re: Fictitiousness
Post by Gill Simo »
I think all should now be very relieved to finally understand why they have spent years in a fruitless attempt get their concept to work!
It wasn't you's, it was simply the laws of physics that prevented operation.
Now all will finally be able to move on to other possibilities!
Like what I wonder....when, by simple laws of physics, you know it's impossible, take every opportunity to point out how well you know it's impossible.....yet continue to hold blind faith in the impossible.....
Other possibilities will ever evade you.
cloud camper
re: Fictitiousness
Like a truly asymmetric design Gil.
A truly asymmetric design would change it's properties in time as well as
space, allowing one to leverage on changing characteristics.
I certainly don't claim to have one but that's the goal.
JM's design has been shown to be symmetrical meaning there are no residual forces at play. Even if all fictitious forces in the design were somehow "real", they still add up to zero.
And his failed liquid driven wheel which was advertised as using the same principle only doubles down on symmetry.
I wish I could comment on your design Gil. But it is so far removed from any known physics formulation that no one can even discuss it intelligently.
It's definitely interesting. Maybe it's asymmetric. Why don't you build one and find out?
Allen_T
Re: Fictitiousness
Post by Allen_T »
jim_mich wrote:Unicorns, a fictitious type of horse!
Um, inertia is the linear momentum something has. If you have a tether ball going around a pole, when released, it will move 90° perpendicular to the pole and the point it was released from. Why Leibniz said F = mv^2/r
That is the amount of stress or load that is placed on a mass being tethered like the weights in my build.
And in my design, I am accounting for this entropy or loss of energy. If I expect it to work, I need to account for all forces acting within the frame work of my (Bessler's?) design. :-)
AB Hammer
Post by AB Hammer »
A fictitious forces is only fictitious until proven otherwise.
To be successful in a self running anything. The what makes it work is the most important part. Gravity is my source/holy grail. The rest is just nuts and bolt so to speak. If another source it found then that information is the holy grail of another direction. It takes people thinking out of the box to try truly new things.
re: Fictitiousness
jim-mich wrote:If you transport the object into outer space then its weight measurement drops to near zero. But its mass stays the same. It will still take the same force over a same distance to affect a same change of velocity as it does here on Earth.
The first time I read that something sounded funny about it. It occurred to me just now that in space it takes less force, or a shorter distance, to affect a same change in velocity, because there is less resistance. Being there is almost no frictional forces in space.
re: Fictitiousness
If YOU take an object with YOU into outer space inside the cabin of a spaceship filled with breathable air like on Earth, then there will be air friction just like on Earth. And even though there is no gravity, all other things being equal, the force required to accelerate the weight will be the same as on Earth.
The point is that gravity or lack of gravity has no effect upon the force required to accelerate or decelerate any weight mass. This is what momentum and inertia are all about.
There might be less contact friction in outer space since there will be no weight of the object to not press it downward against a supporting surface.
On another note...
eccentrically1 wrote:Momentum is not a force.
Let's not get so darn technical. Momentum is indeed capable of causing force to be exerted. Momentum is often stored up in large flywheels in machines in factories. Then the stored rotational energy is turned into a sudden force for stamping and forming metal products. You can call this stored up rotational energy as momentum or as potential force or as potential kinetic energy. Regardless of the nomenclature used, the momentum of any moving object will produce a force when the moving object is caused to change velocity. If the velocity change starts with the object stationary, then the object is usually said to have inertia, which must be overcome so as to cause the object to start moving. After the object is moving we usually change the words that we use to momentum.
(Like a swarm of no-see-ums)
clod camper wrote:The idea is that since all forces cancel within an unpowered structure, that structure then becomes symmetrical.
This is clod campers idea, that all forces cancel within an unpowered structure. A PM wheel must gain force and power by some means. When it gains internal force, then it is no longer an unpowered structure. It becomes a powered structure with asymmetrical forces acting inside.
clod camper wrote:Now JM will finally be able to move on to other possibilities!
I wish this little no-see-um clueless bug would move on. I need a bug-swatter.
re: Fictitiousness
Yes, in ship with air it's the same. I thought you meant out in space, in a spacesuit.
I know that was your point, gravity plays no part in the force pair when you push or pull something. Sorry about the confusion.
But, I don't agree momentum is a force. Force = momentum/time. Related, by time, but not equivalent. KE = (momentum)2/2m.
They all have different formulas to describe different properties, so they don't have interchangeable meanings. You wouldn't measure the amount of force a flywheel had using the formula for momentum. That wouldn't give the answer for the force it had. Same goes for energy, etc.
In my mind a flywheel is best understood having PKE. I'm not familiar with the term potential force?
Yes, the stored up RKE in the flywheel is turned into a sudden force.
NB, you said the energy turns into a force.
That's what I've been trying to get across in the forum for a long time. Energy is converted from RKE in the flywheel (which got that RKE from an external energy source - which is the sun, ultimately) into a force using simple machines like gears and levers to stamp things, etc.
Anyway, that's the way I understand them; force, momentum, energy.
A flywheel, such as used by a big stamping press in a factory, gains rotational energy from a relatively small motor. Thus the spinning flywheel gains momentum and it gains kinetic energy as its speed increases. The flywheel possesses/holds/contains momentum. And it possesses/hold/contains energy, which is in the form of motion, i.e., kinetic energy. The flywheel has the potential to supply usable energy, and thus one could say it has potential energy and potential force.
Since all of these forces or energies are kinetic in nature, you can prefix each with the word 'kinetic'. Thus you have your PKE, or potential kinetic energy. Since all would be derived from the momentum of the flywheel, one could equate (using the proper equation) the momentum with the PKE of which you write.
The rotating flywheel of a punch press has the potential to produce a force when the trip-clutch is engaged. When the operator guy/gal presses both hand buttons (a safety feature) then the clutch engages and the potential energy derived from the momentum of the spinning flywheel, which was derived over time from the motor, gets transferred through the eccentric of the crank shaft and it presses with tremendous leveraged force, thus doing work of punching holes, of shearing metal, or forming automobile fenders or any other such operation that required lots of force during a rather short period of time. Obviously this slows the flywheel. Then the little motor accelerates the flywheel back up to its maximum running speed.
Thus force, momentum, and (kinetic/motional) energy, are all just different words used to look at situations from slightly different perspectives. Saying that one is not the same as another is what academicians say, as they nit-pic. :)}
AB Hammer
re: Fictitiousness
Post by AB Hammer »
That is also the same with a blacksmith how we swing a heavy hammer with ease. We pivot at the shoulder dropping elbow spinning the hammer in the hand not (spin the hand in case Lindgaard is reading) picking up volatility and making impact approximately (depending on the smith) 10 to 20 times more force than just dropping the hammer .
Allen_T
Re: re: Fictitiousness
Post by Allen_T »
jim_mich wrote:If YOU take an object with YOU into outer space inside the cabin of a spaceship filled with breathable air like on Earth, then there will be air friction just like on Earth. And even though there is no gravity, all other things being equal, the force required to accelerate the weight will be the same as on Earth.
On another note...
Jim_Mich,
I think maybe studying physics might help some. Right now, just having a little fun with you because of what you don't know. :-)
>> The point is that gravity or lack of gravity has no effect upon the force required to accelerate or decelerate any weight mass. This is what momentum and inertia are all about. <<
Your comments are wrong in so many different ways I am not sure where to start. But seriously, have you ever heard of escape velocity ?
When a mass like a space shuttle is orbiting in a low Earth orbit, it's MeV is less than that when said shuttle is lifting off.
This is so basic I am at a loss. I mean really, don't you know anything about rocket science ?
I think this is why ab hammer says that I am anti-American. I kind of expect Americans to have some understanding of what made America a world leader.
I hope you understand I have trouble believing anyone could make a mistake like your post. That is sad. Who knows, maybe one day I'll get over it but you have no fear of being called a nerd. You are safe.
