Wall of Death
- eccentrically1
re: Wall of Death
I have found this code that converts the result line into an image.
It would really help if this could function on the forum.
I expect is would need to be a [ ] tag that parsed it via the script.
Code: Select all
\[result = \frac{-b\pm\sqrt{b^2-4ac}}{2a}\]
<script type="text/javascript" src="http://www.hostmath.com/Math/MathJax.js?config=OK"></script>
re: Wall of Death
Afaik "Latex" is available as plugin for PhpBB 3.0, this is 2.0 (also afaik)
Until then we could use unicode:
x= (-b ± √[b²-4·a·c]) / (2·a)
[ Topic Delete ]
As this PHPBB will not be getting the 'Latex' plugin.
Also the unicode database has been reverted back to the ascii (code page) version too reduce database size.
Then you can delete this topic of mine.
Re: [ Topic Delete ]
Delete Double Post
