Now you're getting it 😆daxwc wrote:You are right, but I just never met somebody that will not take accountability when pinned down. Sort of interesting on the degrees he will go to.More trolling for trolls and troll behaviour.
How do you know for sure EC1 that Jim isn’t the troll getting what deserves? Hard to tell the difference isn’t it.
Polymath
- eccentrically1
Re: re: Polymath
- eccentrically1
re: Polymath
EC1:
Oh, I knew before, but I just needed to know how far he would lie. Somebody needed to do it and I was probably the best suited for it. One thing I didn’t care about was the green dots and I don’t have to worry about that now 8))))
It probably put a new perspective on both of us, but I never said I was an angel to begin with.
Polymath
So are you claiming that I've NOT found Bessler's secret?eccentrically1 wrote:No, you claim you found bessler's secret and are criticized. Yuge difference.
How often have I said to you that when you have eliminated the impossible, whatever remains, however improbable, must be the truth?
re: Polymath
Yuge is a synonym for invenit. Yep invenit difference. Go ahead and punch his greenie Jim.
re: Polymath
Frauds and fools claim they found Bessler's secret without first demonstrating something that works.
- cloud camper
re: Polymath
We can forgive JM now.
He did not understand the definition of "fictitious".
Strange for a polymath.
"Misunderstood words breed false ideas" L Ron Hubbard
No I'm not a Scientologist but was married to one.
- eccentrically1
Re: Polymath
Yes, your concept doesn't work. Neither of your prototypes rotated for x amount of time. I don't remember what happened to the first one, but Bessler's clue about stuffing more weight into a wheel and expecting better results is the simplest proof your fluid wheel wouldn't work. But I guess it's a good weight now for something, anchor a boat maybe.
It's got nothing to do with what path around the axis you force it in; putting "custom" curves into the straight sections wouldn't change a thing. All paths around a circle are equal, from the perspective of forces. Even if the path of the fluid mass is rotating in the opposite direction of the wheel. That's what Bessler discovered about gravity wheels and motion wheels, forces of any kind, including fictitious, reactive, inertial forces, etc., can't rotate a wheel.
After a gravity or motion wheel is spun up by hand, gravity or spring, etc.; while the conservative forces are quickly cancelling each other, the non-conservative forces are doing negative work and slowly draining it of the initial push.
