Happy News...
raj
Happy News...
Post by raj »
Just some three hours ago, I found a way to make SOLID weights, moving/resting/swinging/rolling inside gravity wheels, change the shape of their mass and change their centre of gravity with their changing positions in the the rotating wheels.
I have just carried out some physical test which confirms my finding as being perfect.
This time I am a bit unwilling to share it here with my usual explanations.
Hopefully I'll come back with details later.
raj
raj
re: Happy News...
Post by raj »
deleted:
Duplicated below.
raj
re: Happy News...
Post by raj »
Before I get too worked up with my happy news finding, Can any forum members tell me IF they have seen or heard of shape-changing SOLID Weights being used to rotate a wheel anywhere before?
If yes, where?
re: Happy News...
A simple 'lever' or a 'cam' could be considered as such: its able to change its center of mass relative to the wheel depending on position. A combination of those can do more things.
Actually the first thing that came to mind was the T1000 (movie: terminator).
I guess/hope you have something else.
Anyway, good luck.
DannyBouy
re: Happy News...
Post by DannyBouy »
"Before I get too worked up with my happy news finding, Can any forum members tell me IF they have seen or heard of shape-changing SOLID Weights being used to rotate a wheel anywhere before?
If yes, where? "
"My model flips between a liquid and a gas. It's a mass changing states. Could be from a solid to a liquid. The force of gravity is the cause. "
http://www.besslerwheel.com/forum/viewt ... 596#146596
The red and green might be looked at as 2 atoms of a molecule that compress/expand.
As they swing down the red moves from the inside to the outside.
Thanks
Daniel
Trevor Lyn Whatford
re: Happy News...
Post by Trevor Lyn Whatford »
Hi Raj,
yes, Compressing Reservoirs of variable shapes, which also give variable volumes.
These are the most underestimated MT drawing of all, I am convinced (Edit, based on my real life compression tests) that there will be variations that will work, and still have many options on my to build list.
I have been wrong before!
I have been right before!
Hindsight will tell us!
AB Hammer
re: Happy News...
Post by AB Hammer »
Hi Raj
I had worked with a member that was know as beapilot which also had a rolling device in a wheel. But that is as far as I can talk about it. But here is a video of rolling a square.
https://www.youtube.com/watch?v=53dnYTOCKZM
re: Happy News...
The US navy has a new wheel operated by moving a magnetic fluid to one side or another causing a gravity imballance.
re: Happy News...
@AB
We should not forget Wally Wallington's stonehenge
https://www.google.co.uk/search?q=wally ... rfJ8ZTM%3A
raj
re: Happy News...
Post by raj »
In the last hour, I just learnt about what cpuld be Bessler's mechanism for raising a weight in a FLASH.
re: Happy News...
That's nothing special, Raj. I just recently learned how to create matter by compressing a spring.
raj
re: Happy News...
Post by raj »
"Children's game in which there is something etraordinary for anyone who knows how to apply the game in a different way".
This above quote from Bessler is very interesting...MT137.
I have learnt a lot about this.
I have found that something extraordinary.
I am presently trying to apply this extraordinary mechanism in a wheel concept.
re: Happy News...
Hi Raj
There is something wrong with the bottom of your image. Here you go:
re: Happy News...
@Raj
I respect you wish to go dark BEH [Beyond the Event Horizon:other post comment]
What I see is two masses that if placed into a rotating frame could be used to keel that frame; Thus supplying torque.
During that process the hammer will strike, creating N.F [structural stress].
If that is locked until the right moment. Then it could be used to flip the toy back into it's original state.
Then off we go again.
raj
re: Happy News...
Post by raj »
Thank you Tarsier79.
