This saying is very old and I hope we can use this to assist in two active threads.
The question we have 'Where does the energy come from?'
https://en.wikipedia.org/wiki/File:Brachistochrone.gif
So a ball starts at the same height, mass and zero momentum.
Then end with same height mass & different momentum?
All this happens due to it's path.
Does that mean they have the same input energy and finish with
different output energy?
The Shortest way there is the Longest way round
re: The Shortest way there is the Longest way round
I would like to see the same test on a rotating platform.
Wrong.agor95 wrote:Then end with same height mass & different momentum?
This has been discussed a number of times here on the forum.
Two equal objects following different paths but which end up moving at a same horizontal height will have a same horizontal velocity.
The object simply arrive at different times. They take different amounts of time to fall because of their different path angles.
@Jim_Mich
I remember the post around 8 years ago on this topic.
Hopefully we have some new members & guests.
So it is good to keep members on the right track.
If you had not stated there was no difference in momentum then I would have done so.
So with hard geometry in a static frame of reference this is true.
Note. A question is never wrong.
@AB Good point.
Also the Rotating Frame needs to vary.
