Is this IT?
re: Is this IT?
It's not too much to expect some encouragement for my endeavor.
re: Is this IT?
Raj do you like my suggestions about drafting? Please don't tell me that you've put me on ignore. If that's even possible, since if you have me on ignore you wouldn't even hear me asking you if you put me on ignore.
re: Is this IT?
My dear Preoccupied,
I shall NEVER put friends like you on my ignore list. ignore list is not on my vocabulary!
I, too, am not an engineer. I do not understand your request for a drafted presentation with letters and so forth.
I can only explain my ideas by drawings and by written words.
I always try to carry out some physical tests of my concepts, within my limited abilities and facilities.
re: Is this IT?
I have the solution to Bessler's Wheel but I won't share it because I think that the energy being used is from Earth's gravity and that using it would cause the Earth to leave orbit. Maybe if I used it personally for fun, it would not have that big of an effect, but if the entire world wanted to steal Earth's gravity I think that there would be a man made change to the Earths rotation around the sun. I believe that the Earth maxes out its heat that it can hold in the vacuum of space and that this produces gravity. If the Earth uses its gravity over and over again for energy for us humans to use for stuff then I think that the Earth will max out less heat and we will have less gravity and then the Earth's rotation around the sun will change. My Gravity wheel does not spin the wheel unbalanced, it just cranks springs, and the springs spin the wheel. The wheel itself is balanced.
re: Is this IT?
The lower wheel and the two weights are hanging/swinging freely from the rim of the upper wheel on its axle.
What would happen if the lower wheel was also on its axle perpendicularly below upper wheel axle?
This is what I want to know and I am going to India next month, to find out.
re: Is this IT?
Hi Raj ,
At least all measurements was double checked .
re: Is this IT?
I CAN NOW show the world the SECRET of Bessler's wheel, THANKS to my desktop TOY gravity wheel.
The SECRET IS finally out. It's about time.
Re: re: Is this IT?
Yes it does. Still this design, right?raj wrote:Looking Good!!! My desktop toy wheel.
http://www.besslerwheel.com/forum/viewt ... 532#134532
re: Is this IT?
Thank you Marchello.
There is FUNDAMENTAL change in-between. Can you see the change?
Maybe too subtle for one to see, without some explanation.
Both designs are trying to perform the same rotary actions.
My TOY auto gravity wheel design is doing it FLAWLESSLY.
This DESIGN is simplicity itself. It consists of :
1. A SINGLE drum wheel.
2. 8 pairs of identical strings.
3. 8 pairs of identical springs.
4. 4 identical weights.
Can you see them in my drawing above?
re: Is this IT?
What happened to your offset-wheel?
Don't know how I could have missed that. It was the most characteristic part of your design!
But it is right there in the side-view of your desktop-toy-model, gone in the front-view.
Now it will just look like that ancient design I showed on page 52 of your "Mayday"-thread. (I refuse to link to it)
That clear plastic still looks nice though.
re: Is this IT?
