The Bosnian Pyramids
https://thebihlover.wordpress.com/2016/ ... -pyramids/
The truth is out there or not; your call.
re: The Bosnian Pyramids
After seeing the rock formations in this are I reasoned that they could be used.
If you built tapered stone wall then place the flat rocks from this area up against this wall.
The natural rock crack with sharp corners.
After placing these flat stones vertically in there original relative position.
You then can indent the cracks between the flat stones to give a beveled appearance.
In several hundred years a person will say 'How did these people carve these stones so neatly together'.
