Much Too Do About Nothing
I have always pondered how we got from nothing [void] to now.
Imagine looking at a region of nothing. Then imbue it with properties.
This is a little game, but it is one that can lead to some interesting ideas.
1. Property there is no infinities in the void.
Now that drives some major implications.
re: Much Too Do About Nothing
If you treat this as hard science fiction then you will be in the right mind – set.
This property of No Infinities to be true; then there can be no Edges or Absolutes.
So the region does not stop and does not go on forever.
That is only possible by using the ‘terra incognita’ principle.
The region as you move out becomes – not mapped.
We have that in this reality as the Universe goes incognita outside the observable region.
The void only appears to be empty for an absolutely empty region is infinitely empty.
The void in our reality, space, exists out there and within us.
Therefore it could have properties and as its everywhere it is not noticed.
It is like fish in water and us in air. Do you notice air pressure differences?
Electric and Magnetic, photons, travel through space so what are they?
The void is very cold; almost not moving which indicates heat.
The void is superconductive; almost.
Photons in reality can travel from the far limits we can observe to us without apparent loss in energy.
So this superconductive nature is a part of the void.
This property is the cause of inertia; in reality.
A particle, proton, when accelerated creates a resistance back EMF.
Also a revers back EMF when decelerated.
However to move, we need, ‘freedoms of movement’.
This is described in maths as dimensions X, Y & Z.
In the void they do not exist only relative movement in 3 degrees of ‘Freedoms of movement;
Zero Degree is no movement infinitely no movement.
That is not allowed property 1.
2. Property: As we want to get to a reality like ours; I am going with
3 degrees of ‘Freedoms of movement'.
The main point here is the void has modes of vibration.
3. Property: The void can be compressed
If the void is compressed , does distance inside the void also compress , if distance's is compressed , how will we measure the compression of the void ?
Good Question; I used the same paradox on gravity waves.
The compression is on the small scale, very small scale.
You are correct if we were inside the void then compression would effect the distance. That would effect us who are doing the measuring.
The same thing happens in reality with the measurement of the speed of light at near light speed.
Photons are waves of electric and magnetic fields in this reality.
They move at a set speed, have energy and no mass.
Waves on the ocean have a set speed, have energy and no mass.
They have an edge and are the result of Potential and Kinetic interaction.
Another model is the good old rubber sheet.
Have a rubber sheet slightly stretched.
Stick a rod through the sheet and push in a direction.
Let us hope it does not tear.
Then let go and imagine.
1. The rubber in front is compressed.
2. The rubber behind is stretched.
3. The rubber to the sides is pulled into the stretched area.
4. The more energy is used to distraught the more of the region is affected.
Now put these features into the void and see what happens?
Re: re: Much Too Do About Nothing
agor95 wrote:Good Question; I used the same paradox on gravity waves.
Hi agor95 ,
Would this not only be for someone outside the frame of reference , wrt light .
But if a void is compressed , all frames should be equal , whether inside or outside , unless the void is moving at lightspeed .
Good point the property of equivalence needs to be present.
There is a property of our reality that needs to be reviewed.
The wave length of light equates to energy and size.
When we look at an object we need to illuminate it.
The smaller the object size the higher the frequency.
So from visible light we use ultra-violet, x-rays, gamma, electrons & high energy proton annihilation.
When we put distortion into the void it takes energy.
The relationship between energy too distortion is exponential.
The more energy the ‘modes of vibration’ has the higher the frequency.
Therefore the size is small. Smaller than the Planks Constant and the frequency is more than we can create.
For we are unable to go passed the hadron barrier.
Just want to put this point; wave’s change as they pass into Stretched or compressed regions.
Their speed, frequency and direction are modified. Like light going from air to water; causing distortion.
That is the introduction to the next post.
So we pull at a region of the void and the distortion requires energy, lots of energy.
Let us say all the energy in the known universe and an extra joule for good luck.
The potential energy causes movement back to the rest point and off to the other side.
As the movement happens the sides that were pulled in is now pushed out.
This process repeats; however the side are movements in and out in their own right.
This compressed area is equates to the electric field and the side waves
equate to the magnetic field.
This mains vibrations triggers side vibrations which in turn create their own etc.
Vibrations can travel faster in some regions of compression due to increased density or pitch in the stretched regions.
The propagation path can be distorted.
This makes the Void really hot. With a rapid expansion in the sub-particle scale.
However in our scale it is cold.
This odd paradox can be explained like this:-
An ultra-sound beam can be modulated with an amplitude signal.
This sound can't be heard; however after the ultra-sound energy is lost the signal which is in the audible frequency is heard.
Another we can't see into smoke but infra-red can without noticing this barrier.
So this small high frequency energy is not on our wave length.
Apologies for this post in advance.
This is a bit of fact and fiction.
Sellotape does emit hard radiation including x-rays.
If you pull the tape in a dark room you may see blue light.
The void is not alone; it is located in a higher dimension - sorry.
Our void passes another and they stick were they make contact.
However has they part the connection stretches to braking point.
That is the start of this story from the beginning to the hyper-inflationary stage before photons; we are now.
This can happen multiple times even when the story reaches our time.
https://en.wikipedia.org/wiki/Great_Attractor
There are two aspects to this time.
One aspect is similar in nature as the breaking point contracting event and
a whip extending.
A whip that is set into motion each section moves relative to the next.
The movement is by the same amount; however viewed from afar the
tip can travel faster than sound.
When the void contracts from the breaking point [region] it also moves relative to the region that surrounds it. The movement is lower than light speed relative to the local region.
However viewed from afar the breaking region appears to travel faster than light.
Nothing travels faster than light
At the end of this stage the void is in random movement were ever you have time to look.
Void has no form.
The amount of energy was finite in the breaking event; however it was large.
Energy can’t be created or destroyed
The energy is in the random movement of the void.
It is still superconductive.
a whip extending.
Void has no form.
Entropy, Evolution & Superconductive
Entropy was zero when there is no movement.
Now Entropy is high as the movement is random and high with energy.
With random movement; entropy is linked to temperature change.
We are now coming to the start of Evolution where order comes
out on chaos.
Superconductive the void has this property because it does not flow.
This is a paradox as it moves in relation to us watching.
However it does not move passed the other regions in it's surrounding.
The region moves, vibrates, around its resting position.
If we were to try and fix this resting position then the uncertainty
increases as the region size decreases.
That is the uncertainty principle.
Example
Does the Land move up or down; or is it the sea?
out on chaos.
Example
Evolution & Entropy
The age of the Solitons
https://en.wikipedia.org/wiki/Soliton
As we watch the region you will see periods where
it becomes less random.
Therefore in a local region the vibration state reduce.
Outside the region there is random movement; however the energy reduces.
Reduced states or energy is a lowering of Entropy
This is caused by compatible vibration frequencies
coming together as Solitons; like they do today.
That is the first Evolutionary step.
Vibration stats are not up and down along one direction.
The vibrations move in an elliptical motion.
A circular & flattened motion are forms of elliptical motion.
This is the origin of string theory
Dark Matter
This is not like normal matter put does contribute to gravity
at the cosmic scale.
A true random distribution is clumpy.
So the vibrations that hold the finite energy is in clumps.
These vibrations in time trigger particle pairs [a.k.a. virtual particles]
They are not around long put in large regions they add to galaxy formation.
Dark Energy
This is supposed to be causing the universe's increasing acceleration.
However the high energy vibrations evolve into solitons/photons
some of the non-compatible vibrations cancel out.
So the region expands as the vibration reduce.
A smooth cloth covers an area more than a crinkled cloth.
Dark Energy
- Silvertiger
Not true. That restriction is only defined as u<c=3E8 m/s^2 for Special Relativity only. It is allowed in General Relativity and is possible without breaking any other laws of physics as well. It is impossible for a mass to accelerate linearly to the speed of light, but how do objects get around this? The answer is rotation. This allows for speeds of objects with mass to go above c. Imagine I had a retractable mass-less rope of infinite length tied to a penny. (In the "void," the mass-less rope is simply the gravitational interaction between objects rotating about their common center of mass.) I then turn on the machine that starts it rotating. Once it starts rotating, the CF causes the retractable rope to begin extending (gravity just isn't strong enough to keep everything close together for long, and so things fly apart over a long period of time. Either that or they crash into each other lol). If the penny were a pencil, it would draw a spiral. So the motor is going at a constant rpm, and the penny is getting further and further and further away. The more distance it gains from the center of the motor, the faster its delta linear (tangential) velocity becomes, while the rpms of the motor remain unchanged at an angular velocity that is easy to maintain. Once the penny gets far enough away, it will eventually surpass the speed of light, and will never violate any physics law, as it has not been linearly accelerated. The inertial resistance that would normally build up to a terminal velocity in a linear acceleration is essentially bypassed. Cool, huh?agor95 wrote:Nothing travels faster than light
