Surprised you're not turning blue at the snail's pace i'm going..Fletcher wrote:I find myself holding my breath with you MrV.
Looking forward to future installments.
Still, 8 months left for a 2017 success...
Yeah, we discussed this before. I can only say the same....Imagine this cycle in reverse - let the mass fling outwards on the corners, loading a spring, say, then retracting on the straights... in principle, you could stop a freight train without generating a Joule of heat, i think... just sinking its momentum away over successive term changes..
IOW, it looks consistent with a non-dissipative loss mechanism, able to destroy momentum... maybe..
Correct. I see it the same way....pulling the mass inwards while it's rounding the corners raises linear momentum without raising angular momentum, and also does so without applying counter-torque..
...equally tho, re-extending the mass on the straights raises angular momentum, but without raising linear momentum... and also incurs no counter-torque..
Yes, angular momentum rises, but when you look at the full cycle it is not for free. It costs a very little to overcome the inertia of mass while it starts moving outward (cf would do it anyway). But what is much more important, you have to pull the mass inwards in the first place, working against CF. This is the cost of the rising angular momentum...plus it costs no energy!
Think about it - pulling the mass in on the corners does cost energy - the work involved in displacing the mass against CF...
..however re-extending the mass on the straight is not performing work against CF - it's simply a small linear translation, and whatever it costs to set the mass in motion on its outwards journey is recouped when it reaches full extension - the net cost for which is thus zero.
Yet as it enters the next corner, now at full radius again, its angular momentum has been raised!
For free!
Am i wrong?
Surely this is a bona fide symmetry break? I mean the raising-angular-momentum-without-cost part is almost tangential - the broken symmetry part is in re-extending the mass without incurring counter-torque, while retracting does cause torque.
