Testing
john.smith19
Testing
Post by john.smith19 »
James Lindgård here. That'd actually be considered my real name and not James Lindgaard. My fathers last name was spelled that way (Lindgård). :-)
With Bessler, certain facets of what he said can be tested. I am posing this query mainly to John Collins. It's his book and work that is mostly responsible for the content of this forum.
John,
The attached image shows a basic configuration. The image shows 4 ounces (114 grams) hanging from the end of a long lever. The weight wheel weighs about 1 lb. (450 grams). The 4 ounce weight can't lift 4 times it's weight. Simple truth based on Archimedes work. https://www.google.com/search?q=archim ... e&ie=UTF-8
He dies about 2240 years ago.
John, in going over the math I don't think Bessler knew why his wheel worked. His "principle mechanism" could allow for perpetuity without using levers. Using levers it becomes basically a non factor.
The configuration in the drawing could prove that 450 grams x 30 cm's divided by PiR of the overbalance is a minuscule force.
My point ? It takes much less force to reset the weight at the end of a long lever than the work it performs. If that's right then the retraction disc isn't necessary. And all of this can be tested.
My question is this, does anyone care ? To shorten a lengthy explanation the retraction disc agrees with Conservation of Momentum while the use of levers actually demonstrates the theory that pulley systems are based on.
I am going to finish this build while doing some testing. Anymore not sure why I should care what anyone associated with this forum thinks.
re: Testing
terms of use wrote:You explicitly agree, in using this web site or any service provided, that you shall not:
3. Create more than one account. This rule is only excepted on a case by case basis for users who have a legimate need for two accounts and have demonstrated their trustworthiness to the administrators. No more than two usernames are ever allowed. The two usernames must be identical except for a numeric suffix;
See: Terms of use
john.smith19
ME,
I addressed the post to John Collins. Why are you answering for him ? Thank You for pointing out my mistake, John Collins is not an administrator.
@AB Hammer, you have trained some people quite well. His simulations wouldn't be capable of showing what programmes aren't written to allow for.
was kind of hoping some thought would go into this but will leave you guys alone.
Au Revoir, До Свиданийя
re: Testing
Spam dick needs more propping up. So needy.
re: Testing
Lindgård Name Meaning
  • English: habitational name from Lingart, Lancashire, or
    Lingards Wood in Marsden, West Yorkshire, both named from
    Old English lin ‘fecal’ + garðr ‘enclosure'.
    x
    Anglicized as 'Shitsack'.
The Computer Fraud and Abuse Act (CFAA)[1] was enacted by
Congress in 1986 as an amendment to existing computer
fraud law (18 U.S.C. § 1030), which had been included in
the Comprehensive Crime Control Act of 1984. The
law prohibits accessing a computer without authorization,
or in excess of authorization.
http://www.scienceforums.net/topic/2976 ... s/?page=17
James.Lindgaard has been banned as a sockpuppet of jlindgaard. Sorry it took so long to recognize this.
re: Testing
Walt .. he has had about 10 sock puppet accounts here. He is told of terms of use everytime, and he comes back under a new handle anyway.
The ignore function is there for a purpose and I use it in cases like his.
john.smith19
For the 3 idiots who posted, Scott Ellis doesn't have to allow me to make a new account. It's at his discretion that I can open new accounts. He knows that people who are willing to work at something can be successful. :-)
Still, why bury Bessler's work ? That's all guys like you are doing.
re: Testing
I know Fletcher and he doesn't bother me in the least,
but he has never had a Federal Judge tell him.
http://www.uscourts.gov/sites/default/files/ao091.pdf
john.smith19
@WaltzCee,
AB Hammer is not the only person who thought I was Mark James Lindgaard. With AB Hammer's B.S. I sent off emails and now Mark James Lindgaard is properly identified
Here is what I do
.http://www.climate-debate.com/forum/cli ... ral-f6.php
re: Testing
Someone cared about spam dick.
AB Hammer
Post by AB Hammer »
john.smith19 wrote:@WaltzCee,
Here is what I do
Who is Mark? I have only known you as James or Jim Lindgaard and all the sock puppets you have had. But now Spam dick, as ovyyus so named you.
I myself am back on some wheel work, and with hopes & plans on showing some runners for a fantastic new year.
This string would be a great place to leave the BS behind.
