Thx Machine II
Thx Machine II
Good morning, everyone,
We'll make it short, I say the Bessler wheel works, and that Newton can sleep easy, no violation 1 ,2, or 3.
With a little patience (10 days) big max, you will see a functional proto (I imagine we already made you that one, but well I will not use any argument of authority to convince you that I am the best, the biggest etc. we don't care.
I must first of all thank all the members of this site, and two in particular, John Collins for his tenacity, his measure and his dedication to the cause 😊
As well as Mrvibrating, although I don't understand much of his prose, but his tenacity, made me believe that there must be something possible.
In short, I will explain later the path....
The Bessler system has no wheel, it is there only in inertia disk to provide a job, but it is not essential to the operation of the system...
The Bessler system is not based on any imbalance... This is the main reason for failure.
And finally it consists of two independent blocks causing a constant oscillation...
The whole thing is almost stupidly simple, the tilt is huge, it's almost normal that nobody for 3 centuries hasn't found anything, in fact few people have looked, energy conservation has done the rest.
We only use gravity in several stages, and that's it.
For the road.... There are two motors, one works with a weight (whose weight varies according to its location), it is when it is heavier that it resets the machine.
As soon as I'm on my way, you'll have the plan, I'm a bit lazy, as soon as I've seen something, it doesn't interest me anymore, but now I'm going to make an effort, at work.
I won't answer any questions at the moment, so don't post here right now, just be patient.
I'll post the advancement videos here.
Thank you.
Thank you.
re: Thx Machine II
"Les cons, ça ose tout. C'est même à ça qu'on les reconnaît. "
Michel Audiard
Michel Audiard
re: Thx Machine II
Hello everyone,
Here are the first two pieces that will be realized in CNC this week, the format of the board (210x300 mm)
I think if everything works (as expected) to make a molding parts so that those who do not tinkering or more can own a copy.
Thank you
https://ahp.li/57b88623752ca9c1fb0b.jpg
Thank you
re: Thx Machine II
Ces CONS sont qui?
Veuillez nommer un seul dans ce forum.
re: Thx Machine II
Thank you Raj, for this highly constructive questioning :)
I understand better why research on Bessler has been stalled for three centuries ...
Your answer is surely in your question :)
a++
The world is perfect.
a++
re: Thx Machine II
“The answer is surely in your question�.
That’s must be a new paradox!
The answer was surely meant to come from you, to back up you statement.
re: Thx Machine II
re: Thx Machine II
Arff,
When I say it doesn't work, it's a gag....
The system works but not here, there are too many ego worries,
my signature doesn't show up as a pity: "The world is perfect"
I don't think so, I know there's nobody lol (yes it's complicated), see the notions of advaita.
When we see some members doing copyright including on their own post, stop, nothing to do here, (in need of recognition, it's pathological).
After reflection, you will see the system running with and without load on youtube.
The system will be broadcast on a crowdfunding platform in early August.
Example: 50 € to have a complete plan, according to the total amount desired, and once this amount reaches this small world will be entitled to this discovery, which can be exploited as you see fit without copyright or ownership, commercially or not, it is ON.
Nothing is fixed, but for now it's the best idea. I'm retired and I don't need the money, (ridiculous amount) but I want to keep the Thx Machine's authorship, even anonymous.
The system is not patentable as it stands, because to the question "where does the energy come from?" it's a huge tank in which, I put a very small, small, small tap.... a plumber sort of:)
I don't know if it's the same mechanism as Bessler, because no one has been able to describe or present it functionally yet.
Personally I think that there is no other possible in the system we are dealing with, you will see in time.
I work with a small team now, on the site and forum : experimente.fr.
Registrations are closed, except to those who make the request by MP, they will receive a number that will identify them, and to register. Natural language is in French.
A++
A++
re: Thx Machine II
In that case each and every one of us are all very glad that you lead us by example in every possible way.
Good luck with your THX Machine IIâ„¢ on the other closed forum.
re: Thx Machine II
Hi THX4,
sure you now that Bessler has more than one running wheels.
Which type of developement are yours ?
The selfstarting of the bi-directional ?
Bessler started to develope his wheel with the self starting wheel.
In my opinion Besslers last version can also be used nowadays to power each house with 4 KW.
Such a device was invented already in the US from Don Martin.
