Scrap pad for testing .jpegs, .gifs etc.
- Wubbly
re: Scrap pad for testing .jpegs, .gifs etc.
With all that energy, that must be Sparta's cousin.
Mean little kitty song: https://www.youtube.com/watch?v=Qit3ALTelOo
And if you need to test jpegs, there's always the PREVIEW button right next to the SUBMIT button.
test
FOR THE ATTENTION OF ZHYYRA
Reduce the size of your .jpg in Paint. I suggest a width of 640 pixels.
Copy image address from the attachment box which gives you:-
https://www.besslerwheel.com/forum/files/thumbs/t_fw-126-overbalance-calcs-bwf_139.jpg
delete the thumbs/t_ and the s from https which gives you:-
http://www.besslerwheel.com/forum/files ... wf_139.jpg
Then enclose the whole in image tags and HEY PRESTO!!!
And you can then continue on writing text.
Treat any further attachments the same way.
You're thinking along the right lines, Agor. 👍agor95 wrote:Senax - Eric's Gyro lifting weight method.
At some point I am expecting you to use 3rd derivative energy to raise the
weight by retarding a gyros precession.
Link to Ventomobiles
https://www.google.com/search?q=ventomo ... pQPZtkB-0M:
The way that the VentoMobile can sail directly into the
atmosphere wind has always seemed a good analogy for a Vimmy wheel
sailing directly into the gravitational "wind".
Link to Ventomobiles below:-
[https://www.google.com/search?q=ventomo ... pQPZtkB-0M:
VMs rely on a rotational reaction from the ground. Without this they
won't work. As you can see from the linked images they normally comprise a
pair of wheels supporting the main load and third outrider wheel providing the
necessary rotational reaction.
I copied the VM design in my gyro carriage for the same reason.
Till now I thought that the rotational constraint provided by the Bessler
support pillars must be the analogous constraint. But, thinking about it
I realise that the two constraints are different. The VM constraint
plane is parallel to the direction of the wind whereas the Bessler axle
support constraint plane is perpendicular to the gravitational "wind".
However, there's a more subtle possibility of a Bessler constraint, a reduction
of the vertical load on one of the pillars and an increase on the other.
One small step on the yellow brick road to wheel energy. 😎
There are others who put forward gravity is a result in a difference is time ?
That being as you get closer to the Earth time slows down.
https://www.youtube.com/watch?v=6qGucb958rI
skip to minutes 41 and listen to kip
FOR THE ATTENTION OF JUSTSOMEONE
draft
Now interestingly enough there already is a device well known to members
which generates an oscillation between the two axle supports, i.e. the
Pop Keenie or Buzzwheel.
Weights are dropped between the inner and outer wheels and in so doing
move the axle support of the weight to and fro along the axle with a
corresponding oscillation of weight on the axle supports.
This action is analogous to that produced by a swashplate
"A swashplate engine uses a swashplate in place of a crankshaft to translate
the motion of a piston into rotary motion."
You have to admit the action of the weights falling in and out of their slots
under gravity does visually suggest the action of multiple pistons in cylinders.
I was rather surprised to find that the swashplate was invented as late
as 1917.
Many thanks to Justsomeone for drawing my attention to his album.
draft
as 1917.
del.
Re: re: Scrap pad for testing .jpegs, .gifs etc.
I suggest you download this .pdf attachment for my view onagor95 wrote:There are others who put forward gravity is a result in a difference in time ?
The Nature of Time. 😎
- The Nature of Time.pdf
- (99.61 KiB) Downloaded 201 times
Based on this document; as I travel forwards and my mind starts to forget all I have learned. Then my perception of time will reverse and I will arrive at my second childhood.
As the bard put it:-
.......... And so he plays his part. The sixth age shifts
.......... Into the lean and slipper'd pantaloon,
.......... With spectacles on nose and pouch on side,
.......... His youthful hose, well saved, a world too wide
.......... For his shrunk shank; and his big manly voice,
.......... Turning again toward childish treble, pipes
.......... And whistles in his sound. Last scene of all,
.......... That ends this strange eventful history,
.......... Is second childishness and mere oblivion,
.......... Sans teeth, sans eyes, sans taste, sans everything.[/size]
del
