The war of the ego about an unrealizable illusion
The war of the ego about an unrealizable illusion.
It will not work, it is useless to waste time and money. The physical laws which man has derived by observing physical phenomena are exact. Our wheel can not turn, it is a pure illusion. Bessler the only thing that allowed us to run are the balls :-)
re: The war of the ego about an unrealizable illusion
Fortunately for us, unstable, they are not exact and it is this inexactitude which allowed Bessler and will allow us to generate energy from Ersatz Gravity with the "catalytic" assistance of Newtonian Gravity.unstable wrote:The war of the ego about an unrealizable illusion.
An example of the supposedly "exact" law which mathematically brainwashed physicists have decreed is the interaction of current flow and magnetic field. They are supposed to act at right angles.
Any engineer worth his salt recognises that this is a nonsense. If they are exactly at right angles they can't interact. No amount of displacement in y will give a displacement in x. In reality the interaction must be an a angle smaller or greater than a right angle.
Must the physicists be mathematically brainwashed?
Senax. Wow, that image! Now I see you imagining you as pile of dried out crystals. (what kind of salt?)
It seems you reached the limits of your vector-knowledge.
Been kind of slow on the forum. Good to see someone posting anything.
Came across this old Youtube video. Not too obvious what is happening.
https://www.youtube.com/watch?v=D9KHNPX0KZM
Before I waste my time building a WM2D model,
I thought I would share it here and ask if anyone
sees something that I seem to be missing.
As for a relevant comment on this thread....
us old timers have learned to keep our expectations low
so our disappoints don't completely kill our optimism.
Bill, if you pause the video , you will notice 5 weights raising as 3 are falling.
- MrTim
It's not *your* time or money being "wasted", so not understanding why you are projecting your defeatism onto the rest of us. But you've made it abundantly clear you are not happy here (do *we* make you unhappy?)It will not work, it is useless to waste time and money.
In any event, it's not *our* ego that is butthurt...
Just read a few posts and it is clear that a continuous battle of the ego between users is taking place. "My mechanism is longer than yours" ... now you're jealous ... and so on.
Blindfolding does not help to see, even less in this forum.
I would like to open eyes to you all, but I read that some prefer to persist searching in an impossible solution. Closed and gullible minds
Good luck ... you need so much here.
Leonardo da Vinci on scholars and science. In hindsight there should be a lot to learn from this. Not much of the schoolbooks has ever stood the test of time.
Quotes:
“some foolish men will accuse me of being uneducated. They will say that because I did not learn from their schoolbooks, I am unqualified to express an opinion. But I would reply that my conclusions are drawn from firsthand experience, unlike the scholars who only believe what they read in books written by others�
"These scholars strut around in a pompous way, without any thoughts of their own, equipped only with the thoughts of others, and they want to stop me from having my own thoughts. And if they despise me for being an inventor, then how much more should they be despised for not being inventors but followers and reciters of the works of others."
- LV
Quotes:
- LV
www.orffyreuscodes.com
Edward Witten
https://no.wikipedia.org/wiki/Edward_Witten
Edward Witten on modern science:
"The problem in physics today is that all is based on two different theories. (Relativity and Quantum mechanics) And when they are added together, all becomes just nonsense"
From this we can conclude that he say that one or both modern main/popular theories of science are wrong! So we are not still there. This would mean that Bessler's secret could still not only be possible, but even guide us to the correct solution.
Remember da Vinci's wise word, seen in hindsight...
Best
ØR
Best
ØR
Re: re: The war of the ego about an unrealizable illusion
Oystein wrote:Leonardo da Vinci on scholars and science. In hindsight there should be a lot to learn from this. Not much of the schoolbooks has ever stood the test of time.
Quotes:
- LV
As are mine.
Thanks for those two constructive posts, Oystein.
- John Collins
“There are none so blind as those who will not see�, or to quote Bessler from Apologia Poetica (also of biblical origin) “Do you still not see?�
Collins, tu proprio non sei nella posizione di poter rispondere. Per te questa faccenda è ormai divenuta chiaramente un business. Chiunque tenti di fare aprire gli occhi agli altri utenti, incantati da tutte le bugie di Bessler, va ovviamente contro il tuo interesse. Come ho già scritto e tutti qui sanno, devi vendere i tuoi libri.
Per quanto riguarda l'ostinarsi a gettare merda sulle leggi fisiche e sugli insegnanti... da cosa credete che queste leggi siano state ricavate? Ponetevi questa domanda e datevi la risposta. Inoltre la fisica quantistica, lo comprendono anche le capre, è valida solo sull'infinitamente piccolo. Tutta un'altra scala di ordini di grandezza inferiore. Per la ruota del truffatore si applica appieno la fisica classica. Non sapete più come rispondere ed il caro rumore di unghie sugli specchi viene udito chiaramente.
Ormai a me rimane solo la curiosità di capire fino a che punto siete tutti disposti a farvi prendere in giro da questa vicenda di truffatori e truffati. Svegliatevi ! Non c'è nessun moto perpetuo, vi stanno solo prendendo per il culo (è un modo di dire che significa che si stanno prendendo gioco di voi).
Spero che i più sani di mente si allontanino da questa buffonata ed investano tempo e soldi in qualcosa di più utile a loro.
Google translate:
Collins, you really are not in a position to answer. This business has clearly become a business for you. Anyone trying to open their eyes to other users enchanted by all the lies of Bessler obviously goes against your interest. As I wrote and everyone here knows, you have to sell your books.
As for the persistence of throwing shit on physical laws and teachers ... what do you think these laws were derived from? Ask yourself this question and give yourself the answer. In addition quantum physics also includes the goats that are valid on the infinitely small. A whole other scale of orders of a smaller size. Classical physics is fully applied to the fraudster's wheel. You no longer know how to respond and the expensive nail noise on the mirrors is clearly heard.
Come al solito il traduttore traduce in un modo pietoso. Peccato ma sono stufo di tradurre io stesso. Guardate che la traduzione è incompleta, ho aggiunto altro.
