Question. Was the “clattering sound� continuous or intermittent?
axel
Post by axel »
Have never read anything that said one way or another.
Many mechanisms would make the whole sound continuous, while each one is intermittent.
Can’t believe what I’m seeing.
Silvertiger
Post by Silvertiger »
Intermittent...otherwise, witnesses would not have been able to distinguish what they thought to be eight weights falling. If the sound were continuous, then those speculations would not have been made.
sequeen
Post by sequeen »
Continuous it was based on the mechanism it was 4 fold mechanism so there was 8 sound during one rotation.
If the wheel had 3 cross-bar there was 6 sound during one rotation.
My current wheel has two crossbars, so there is only 4 sounds during one rotation.
Silvertiger
If there were eight distinct sounds, then how is that continuous and not intermittent? It was continuously intermittent; not continuous lol.
axel
re: Question. Was the “clattering sound� continuous or inte
Post by axel »
I’m experiencing vast progress with a breakthrough approach.
BTW. The clattering sound could sound off and on. The more mechanisms there are, the more continuous it becomes.
I’m working with each one being approx .5� off center.
As promised previously, John Collins will be the first to see it running other than me and possibly a patent lawyer. And he, if he wants to can tell you all all about it
axel
Post by axel »
FYI MT 55 and 62 are the only drawings that have any clues as Bessler said. Still, they are a stretch.
unstable
Post by unstable »
Ah, then the secret of the wheel is just an airflow. I suspected it. :-)
Hi Axel,
maybe you overlook the ratchet function in MT 55. You find a second one on the child page.
A pendulum wheel with a ratchet function has a complete different function as a normal pendulum.
A normal pendulum will swing back and forth until friction has taken all its energy.
A pendulum wheel with a ratchet function will swing and because it is blocked for the reswing, the pendulum wheel is relocated by the radius distance of a excentrical roller.
Silvertiger
Georg wrote:A pendulum wheel with a ratchet function will swing and because it is blocked for the reswing...
If it is blocked from the reswing, then how exactly is it a pendulum???
rasselasss
Post by rasselasss »
Georg k.,i like your line of thought on Pendulum with ratchet function as an aside,early 1930's electric-mechanical clocks used a type of reed relay(elecro-magnet)to keep the pendulum in "beat"unfortunately without any means to keep the amplitude of the swing in check is was not a success,nowadays it would be simple using an optical sensor...i would still call it a pendulum with its fixed fulcrum allowing it to swing controlled or not...Good Luck.
Hi Silvertiger,
obviously you know the function of an
stehaufmännchen
translator will pass me the word
bounceback
A
Stehaufmännchen
will swing but will not move on the ground sidewards.
When you put a pendulum in a hollow cylinder on an hollow shaft, then the pendulum will swing in the cylinder, but the cylinder will not move.
The function is like the
Stehaufmännchen
And now the interesting. The same construction with a ratchet on the axle will transform the movement in a side step. So we have a relocation of the weight, normally i use the radius from the cylinder for the relocation.
The construction of the pendulum wheel you can see in the other thread
mit die Ãœberwucht....
