Has anyone ever done a systematic analysis of the MTs?
- eccentrically1
I think someone started to go through the mt’s like that, I don’t remember who or what the topic was called. It might have been fletcher? And he grouped the mt’s together that shared similar designs.
Basically the mt’s suffer from the same failure, they don’t have a prime mover (MT 15).They’re all just variations on OOB wheels without the prime mover structure/mechanism/process.
- eccentrically1
re: Has anyone ever done a systematic analysis of the MTs?
Nah .. wasn't me ECC1. Everyone including daxwc has had a pretty good go at some of them tho, in various threads.
Silent .. I for one have a hard copy of MT from John Collins. After a few years I started making margin notes, and now it is full of things and thoughts that were important at the time. I kinda like it that way.
N.B. recently got JC's electronic versions for quick searching, from his web site.
Whilst MT has a loose structure it does duck and dive around with what I call replacement or place holder pics, IMO.
You can read what Bessler said about his unpublished book to be below.
Opening quote from Bessler's MT published by John Collins (underlining and bolding mine).
"Further demonstrations regarding the possibility and impossibility of perpetual motion.
N.B. 1st May, 1733. Due to the arrest, I burned or hid all the woodcuts that prove the possibility. However, I have left all demonstrations and experiments since it would be difficult for anybody to see or learn anything about a perpetual motion from them or to decide whether there was any truth in them because no illustration by itself contains a description of the motion; however, taking various illustrations together and combining them with a discerning mind, it will indeed be possible to look for a movement and, finally to find one in them'."
I don't think it is as easy as combining a couple of "failures" from a bunch of failures (no disrespect to ECC1 there).
Bessler says there is a description of the motion to be found, and a movement to be found. Clearly he felt they were different enough to mention them separately, so they must mean slightly different things, or to be combined into his True Mechanical PM with Prime Mover ;7)
Or perhaps searching for a Motion eventually begats a Movement !
- eccentrically1
But that’s exactly what he says in the quote you mentioned!. I don't think it is as easy as combining a couple of "failures" from a bunch of failures (no disrespect to ECC1 there)
MT001-2 opening statement (prior to No.1 description)
---------Bessler wrote:'The first prints using lampblack'; clear problems in the demonstrations and experiments, what was seen among various friends.
Almost everyone who has sought to invent a perpetual motion machine has considered bringing about motion through spheres and thereby has hit upon the idea that through straight lines nothing would be gained for their purpose. Therefore, departures from the structure are present, as the first figure shows. A beginning student of mechanics can judge that with such things [departures?] assumed nothing at all would be effected.
I think Bessler used "motion" and "movement" as shorthand for 'perpetual motion'.Fletcher wrote:Bessler says there is a description of the motion to be found, and a movement to be found.
Bessler's fundamental requirement of a "discerning mind" in order to put the pieces together seems like just another tease. Bessler's discerning mind already knew the answer and I'm sure he saw pieces of his wheel scattered throughout MT.eccentrically1 wrote:"However, taking various illustrations together and combining them with a discerning mind, it will indeed be possible to look for a movement and, finally to find one in them'."
There's a third option. Nothing is ever either/or.Silent wrote:The entire human race is either severely mentally retarded and Bessler was a genius, or Bessler was a fraud and we are still retarded in our thinking for even trying to figure out the wheel.
silent wrote:
Then all of a sudden we get to Bessler's wheel and the movement is so specific and so precise so as to be unique to the PPM and yet no one, not even the world's top mechanics and scientists can figure it out. Yet here we have a guy who in the 1700s - before modern advances in machinery and engines even came into existence - that build not just one, but 4 and maybe more wheels that ran and the largest having enough power to lift a few bricks.
silent
When an answer is not immediately obvious to a question it is human nature to default to more and more complex alternatives. I can't see the answer so it must be a more complex solution that I am searching for, not a more simple one, else I would have already thought of it, eh ! Perhaps the answer is actually simple, we just are looking in an apple orchard for an orange ?Bessler wrote: .. the design has, in fact, progressed to the point where there is nothing supercritical about the exact disposition of the weights - an ounce more or less, here or there, makes not a scrap of difference to the Wheel, which will hold its course serenely without 'turning a hair' – AP pg 316
- eccentrically1
Yes, that's what I meant when I said he wants us to think if we combine the right "failures" together we'll find a motion/movement. But then in MT 15, we getovyyus wrote:Bessler's fundamental requirement of a "discerning mind" in order to put the pieces together seems like just another tease. Bessler's discerning mind already knew the answer and I'm sure he saw pieces of his wheel scattered throughout MT.
bessler wrote:No. 15 This ratchet-wheel derives from the previous model, except that the tensions are somewhat longer and have an additional special weight at the external ends. From this drawing alone, however, nothing of the prime mover's source can be seen or deduced although the figure shows the superior weight.'
As we know, any figure can be drawn to show superior weight. When he says 'anyone who see fit can build this on an axle' he's teasing again because he knows his drawings don't reflect what happens after it's built.
That's the answer his discerning mind already knew - the prime mover.
So a prime mover has to be an additional, external force traced to a transfer of a form of energy that is either thermal or mechanical. Those are our choices apart from collusion in fraud.
I'll get you started:silent wrote: I think a great thread would be to take one MT, slice and dice Bessler's commentary, and then start taking notes over the best ideas the brain trust can put forth.
MT1-27 are all basic overbalanced wheels. Same cart, same horse.
MT28 doesn't have any internal weights, but it is a leverage type design.
Hey silent,
I did my first build in 1991 and didn't think I had any more ideas.But I've since done about 300 more builds ( my basement has barely room to walk ) and every time I think I'm out of ideas, here comes another one. If you look up specific MT's you will find that this forum has probably dissected it at some point. The more builds you do and the more failures you have, the faster you'll be able to spot a non-runner without building it. What other cause would you give your time to? I personally have no other avenue that would allow me to change the world from my basement.
A prime mover has to be an additional, internal or external force traced to a transfer of a form of energy that is mechanical.
Because we are dealing with Bessler and not with a Diesel engine.
The energy for the start purely mechanical. m*g*h
In my opinion we have for the different types of the Bessler wheels also two types of the prime mover.
1. the self starting wheel has a prime mover in that way, that you set the complete internal mechanism under stress by gravity.
Internal force.
2. in the bi-directional wheel the hand of Bessler was the prime mover.
External force.
He turned the wheel out of position, so that the internal mechanism tilt over.
Internal force.
External force.
Re: Has anyone ever done a systematic analysis of the MTs?
Dave Roberts attempted something similar a few years ago... not really a success I think.silent wrote:Has anyone ever done a systematic analysis of all the MTs?
Just throwing out some thoughts to see if we can work together to try and analyze the failures of each MT.
The most successful topic from the series: MT013Community Buzz\MT001, Dave Roberts wrote:To aid future Bessler enthusiasts who endeavor to solve this puzzle, if enough discussion follows (and please, keep it as technical as possible), lets try to analyze each MT Drawing.
MT 001 - this is a basic wheel and yes I built a similar wheel many years ago with no success. It obviously cannot work because more weight is being lifted on the ascending side than on trying to impart rotation on the descending side.
If you find a way to lift the two weights at the bottom straight up, you have rotation.
How many others have tried to build this or similar?
Am I wasting time trying to start a discussion on the MT's?
Topic MT001:
http://www.besslerwheel.com/forum/viewtopic.php?t=6410
http://www.besslerwheel.com/forum/viewtopic.php?t=6421
I guess we all have our own priorities, points of interests, conclusions...
Maybe best to look at the MT's on your own and ask specific questions when you find something.
http://www.besslerwheel.com/wiki/index. ... T#Drawings
Eventually there are so many ways to look at it, you can always try to summarize it, or pattern-match it, in your own way.
Note that it would also take you almost 3 years to go over each MT once a week, hence my advice is to find your own way of compressing the information to your own liking.
This is one of my attempts from a while back.
Topic: Bessler's wild Goose chase
http://www.besslerwheel.com/forum/viewtopic.php?t=6282
Full marks for Georg!!!
Spot on for prime movers.
Prime mover can be nothing but the one that moves FIRST.
- eccentrically1
No, sorry, a prime mover would have to be external to the wheel and it could have been thermal as well as mechanical. Think of it as an energy transfer machine. A solely internal prime mover violates CoE.George Kunstler wrote:
Georg Kunstler wrote:1. the self starting wheel has a prime mover in that way, that you set the complete internal mechanism under stress by gravity.
Internal force.
The operative word in your prime mover is "you". You set the the weights under stress by gravity. The weights didn't jump onto the wheel by themselves. They are given GPE by an external form of energy - you. Gravity (an internal and external force btw) gives it back by self starting the wheel.
He was the self starter for the bi-directional wheel but not the prime mover. He didn't stand there and keep pushing it by hand.2. in the bi-directional wheel the hand of Bessler was the prime mover.
External force.
