Leibniz wheel
Leibniz wheel
Have a look to the
https://en.wikipedia.org/wiki/Leibniz_wheel
a rotating drum with unequal mass distribution which will generate a sudden move.
with this function you can easily generate a fast up, slow down functionality which is a pre requisite for an gravity energy converter.
re: Leibniz wheel
Cool.
It reminds me I have this Brunsviga 13 still scheduled for a clean-up....
I can have a look, maybe next winter.
re: Leibniz wheel
you maybe look at it as an calculator machine, which it is of course too.
I see a rotating drum, which will pulsate in its movement, gravity can work on it. A variation of an archimedes screw used in an other way.
An unequal mass distribution, broken symmetry.
AustinLis
re: Leibniz wheel
Post by AustinLis »
What about it makes it a good calculator machine?
Johndoe2
re: Leibniz wheel
Post by Johndoe2 »
Great post Georg!
re: Leibniz wheel
Really,
no one sees what we can do with the Leibniz wheel ?
It is also an gravity converter.
Assume this wheel is running in a half filled tube,
then the wheel will turn because it has different displacement of liquids,
left and right, symmetry is broken.
It creates also a tilt swing.
FunWithGravity2
Post by FunWithGravity2 »
Ive been away
I thought you had a wheel and your carpenter was finishing it up. It should be done, where is it?
