"Perpetuum motion" is "on air" ?!...
iacob alex
Post by iacob alex »
.....starting with a mechano-electrical toy ( battery "assisted"...) , playing an erratic swinging , at :
https://www.theswingingsticks.com/how-t ... -works.php
.....then, with a mechanical toy , playing an erratical motion , also...at:
https://grabcad.com/library/perpetuum-mobile-1
.....and a proposal to evolve the mechanical model into a gravity continuous unbalanced leverage (pulsatory regular rotation) , at :
www.geocities.ws/iacob_alex/Some_Drafts/text028.JPG
.....if we take into consideration : gravity free fall , rotational inertia and a single self-switching of the gravity unbalance ( torque difference on the same side of the fulcrum...) in the top ( or bottom ) position...or an "inertia assisted "gravity free fall.
As a matter of fact...Why not a " minimum minimorum " design !?
Al_ex
re: "Perpetuum motion" is "on air" ?!...
Thanks iacob alex
very timely
Cheers
All this versions are failing for one simple reason,
the reaction is always against the earth directly.
They have all an solid stand !!
What you need is a moving ground !!
How does an ABS System work, does it work on an movable ground ?
iacob alex
.....if you simplify the well known "swinging sticks game"(erratic swinging/pendular motion ).
So , you can :
-buy one
- remove (take away , extract) the electric circuit(and battery...) , as :
- https://youtu.be/RlAtXeDY7qs
- https://youtu.be/PWg6TG2bkFU
-place a magnet in every stick ( intended to repel one another...)
-add a "knee joint"(180 * limiting joint) for the small stick
Now you have the possibility to play a "new game " (regular rotating inverted pendulum ) : "self" rotation due to a continuous gravity unbalance on the same side of the fulcrum and rotational inertia !?
Spare parts:fulcrum/support , two sticks,two joints,two magnets...if you intend to build and test it...
Simply , we replace a battery assisted motion ( swinging ) with a moment of inertia assisted motion ( continuous rotation...or "self" rotation due to gravity fall and inertia ).
Inertia helps every turn ( or half turn...) , to tumble ( in the top or bottom point ) the torque difference ( due to gravity unbalance ) on the same side of the fulcrum...resulting a continuous pulsatory rotation ).
Al_ex
gravityman52
Post by gravityman52 »
I agree.....it would be possible to learn a great deal from this endeavor.. With the great amount of items that can controlled through a radio frequency you can do amazing processes. The battery can just be attached to the wheel and a radio control console that controls a small hobby train can be used to control dozens of activities. No wires required .... I want to hear more
a Romantic seeking to find the link to powering the planet
iacob alex
......maybe , not as a gravity "self" moving "shape" , but as a big size , at :
https://youtu.be/88Z2x1MEex8 (a big wheel in France )
https://youtu.be/watch?v=qp5xqzGFcAQ (a big height leverage proposal )
....if we take into consideration the real "source" ( gravity level potential ) , at:
https://theory.uwinnipeg.ca/mod_tech/node32.html
So , the main "factor" is the velocity of the free "falling" unbalance , or the change of a high level of PE into a greater KE...
.....but the "shape" remains to be tested.
Al_ex
