I have been looking at MrVibrating fine graphic Counter-force-to-gravity.gif
Imagine there are no forces just accelerations. replace the 'F' with 'ma'.
Does that take us anywhere? It maybe a padded room!
So I look and see the red blocks being accelerated and the green block moving down the page going at a constant speed.
Accelerating the red blocks requires work to be done. From outside the system.
When the green blocks reach their limits then more work needs to be done.
As they also need to be accelerated.
Then there is the 'ma' term could the mass part be replaced with a counter acceleration?
This interest me for representing the reduced interactions of connections allows modelling of the Calloway GW.
The Calloway GW basic elements are pendulums, even the sliding weights.
Cheers
Scotch Mist - Forces?
re: Scotch Mist - Forces?
Simply Work out the effect of Acceleration.
When you've never done the algebra, you may be surprised of the outcome, even though you shouldn't.
