Bessler Collins Gravity Wheel
- John Collins
I’m going to share what I know about Bessler’s wheel and the design I’m building. I will post the same on my blog as on the Besslerwheel forum, but the drawings and photos may be more accessible on the blog, but I’ll do my best to get them on both.
I’ve called the thread ‘‘Bessler Collins Gravity Wheel’ because it is based on my interpretations of the many Bessler clues, codes and hints he left. I believe that the design is entirely his, hence his name first in the title of this thread, but my name is there too because these are my interpretations of the information I extracted from his works. My wheel is not finished because there are difficulties in getting mechanisms perfect but I believe the theory is correct. I hope there will be several attempts to simulate what I post here.
This is a brief explanation of some clues and where they are. It has proved impractical to get this all down in one post but I will provide more detail as soon as I can get it written. I will now describe some of the actions and mechanisms involved but I haven’t got the pictures ready yet, but will post them as soon as I can. I’ve added some at the end of this post which should go some way to supporting my claim to have found the secret of Bessler’s wheel.
In my blog on 4th November 2013 I posted my belief that all the information needed was to be found in the six drawings to be found in Bessler’s works Das Triumphirende (DT) and Gruendlicher Bericht (GT). If you search my blog for word ‘drawings’ you will find more of the same information which I’m going to post here.
First I believe that the ‘T’ shaped pendulum shown in Bessler’s (DT) and (GT) is in fact ‘L’ shaped. The two long arms of the pendulum show the starting and finishing positions of its range of action, but more on that later.
The wheel has a pentagram drawn on a disc or backplate to which everything is attached. The five segments of the pentagram each contain one mechanism and its complete range of movement. Although all the five mechanisms operate independently there are always two mechanisms working together.
The following description assumes that the wheel will turn clockwise. I include a colour reference to each lever for ease of reference for when the new pictures are posted.
Each mechanism includes two main levers and each has a weight on its end. All the weights are of equal mass. One lever, which I call the (red) initiator lever, is the one which starts the action. It could be thought of as the prime mover. Each lever’s pivot is positioned on a radius line.
The (red) initiator lever pivots roughly half way along the radius when the radius is at the six o’clock position. The exact position of the pivot is simple to calculate from the information which follows.
It falls 90 degrees from a position approximately 18 degrees to the right of the vertical six o’clock radius line. It lands close to the rim of the wheel, at an angle sloping downwards about 18 degrees.
The second lever in each mechanism, which I cleverly refer to as the (blue) ‘secondary’ lever, is attached to a pivot on the same six o’clock radius but it is positioned just below the centre of rotation (CoR). This (blue) lever is the longest one, stretching all the way to the rim. It’s weight is attached to the end of the (blue) lever. When the (red) initiator lever falls it pushes the (blue) secondary lever and its weight, 30 degrees to the right from its position which also starts 18 degrees to the right from the vertical radius.
The (red) initiator lever is ‘L’ shaped, having a short stub for the short leg. It’s pivoting point lies at the junction of the two arms of the ‘L’. When the (red) initiator lever falls, it pulls a cord which is attached to the short leg. This cord runs around two pulleys and its other end is attached near the end of the (blue) secondary lever in the preceding mechanism. The (red) initiator lever lifts the (blue) secondary lever in the preceding mechanism 30 degrees by pulling on the cord. This moves the weight at the end of the (blue) secondary lever upwards and clockwise from a horizontal position 15 degrees below the CoR to a horizontal position 15 degrees above the CoR.
This lift reverses the action caused by the (red) initiator lever currently at the six o’clock position which pushes its own (blue) secondary lever anti-clockwise.
The clues which provided some of this information are all in the first drawing in (DT) and (GT). There are other helpful drawings which are in DT and in the Toys page in Maschinen Tractate (MT).
One of the written clues came from Apologia Poetica (AP) known as “The great craftsman� passage. This is a heavily abbreviated version of what I published on my blog back in November 2017. The omitted pieces are indicated by several dots or periods.
“What follows is my interpretation of the “great craftsman phrase�. In his Apologia Poetica, Bessler included many clues…..
He wrote, “a great craftsman would be he who, as one pound falls a quarter, causes four pounds to shoot upwards four quarters.� …….
Note that within the quote he mentions that there are five weights, one plus four, and each one is equal to one pound. Secondly, one pound falls a quarter. How do we define what he meant by a quarter? In this case he was referring to a clock - something he also included in the first drawings in both Grundlicher Bericht and Das Triumphirende - and a quarter of an hour or fifteen minutes covers 90 degrees…..
We saw in the first part that the word ‘quarter', referred to, not just 90 degrees but also to a clock. In the second part the word ‘quarter' also refers to a clock but this time he has confused us by using the words ‘four quarters’. ‘Four quarter’s equals ‘one whole hour’. Each hour on a clock is divided into 30 degrees, so the words ‘four quarters’ meaning ‘one hour’ as used here equals thirty degrees. To paraphrase Bessler’s words, “a great craftsman would be he who, as one pound falls 90 degrees, causes each of the other four pounds to shoot upwards 30 degrees.�
You might also think it would have been better to have said that “one pound falls 90 degrees, causes one pound to shoot upwards 30 degrees�, but that would have removed the information that five weights, and therefore five mechanisms were involved, so it had to be four weights plus the one.
This 90 degree fall by the (red) initiator lever generates enough mechanical energy to drive three actions. The first one causes the wheel to rotate 30 degrees; the second one moves the (blue) secondary lever 30 degrees anti-clockwise; the third one lifts the (blue) secondary lever in the preceding mechanism up 30 degrees. The cost in mechanical advantage is spread unevenly between the three actions. Clearly the swift lift is the most expensive.
These actions break the symmetry which has always prevented a successful reconstruction of Bessler’s wheel.
More information, clue interpretations and drawings to follow asap …. hopefully. Here are some illustrations to help the above explanation, BUT this is only half the picture!
Actually I can’t seem to add any pictures but you can see the same post including the pictures on my latest blog.
re: Bessler Collins Gravity Wheel
John,
if your problem for sharing photos here is that they are not the correct format and/or too heavy, (not the correct term maybe) you can change the format here and then download the lighter version.
https://www7.lunapic.com/editor/?action=quick-upload
For some reason i am never notified of messages on your blog.
Let's hope we can collectively take your wheel to the finish line.
Thanks for all your hard work.
- eccentrically1
John, I attached a resized version of the blog pic if that's ok.
- John Collins
Yes thank you, that’s most helpful. JC
I am delighted that it is you, dear JC, who finally found Bessler’s wheel. Your continued effort and persistence has paid off.
Congratulation.
Congratulation.
- eccentrically1
If you want to add more pictures later, then when you have a post reply window open, click on the attachment button and add your resized pic (100KB or less in correct format: jpeg, etc.) with a comment.
The attachment button includes a link to the resizer page. From there you upload your file to that page, then download the resized file to your computer, then when you click the attachment button, you should be able to navigate to your pic and add it to your reply.
That link works fine for resizing photos but it doesn't allow us to change the format. Maybe it does and i couldn't find it??
That is why i shared the link to the other one, because it does both.
I made the assumption that the red lever drop that takes place in section 1, does not reset until section 4. I think these illustrations closely match what John has presented so far.
"A great craftsman would be that man who can 'lightly' cause a heavy weight to fly upwards! Who can make a pound-weight rise as 4 ounces fall, or 4 pounds rise as 16 ounces fall. If he can sort that out, the motion will perpetuate itself. But if he can't, then his hard work shall be all in vain"
The problem with interpretation, is it is just that.
One way to interpret (the way JC appears to have): "This is what you do to perpetuate motion"
The way I mostly believe it to be interpreted: "Only Jesus performing miracles could make a 1 pound rise.... If by some wizardry you could do this, motion would perpetuate itself." And it would.
Another one:
"a work of this kind of craftsmanship has, at its basis of motion, many separate pieces of lead. These come in pairs, such that as one of them takes up an outer position, the other takes up a position nearer the axle. Later, they swap places, and so they go on and on changing places all the time"
Read the context around it, and my interpretation is "Wagner says this, so it must be true." In the words of Homer (Simpson): "In case you couldn't tell, I was being sarcastic!"
Just my 2 cents.
Another one:
Just my 2 cents.
- John Collins
I’ll post some more details as soon as I’ve completed the drawing. It may take a couple of days
Great news, John... and just in the nick of time. If I didn't get an actual working Bessler Wheel this Christmas then I was going to blow up the World. Whew!
- John Collins
Wow! Thank goodness we’ll be saved......if it works!
Uh oh...
It is less than two and three quarters of an hour before it strikes twelf on the Christmas clock.
He's making a list and checking it twice. Gonna find out who's naughty and nice. Santa Claus is coming to town...
John, thanks for sharing your idea.
I still have to figure out how it is supposed to operate, so here just a quick observation of the principle I'm considering and I hope you could shine some light on it:
Or, when the wheel rotates 30° then the anti-clock motions have to be 60° to be lifted from the observer's point of view, or when it is lifted 30° then it looks stationary.
Does this 90° drop include or exclude the 30° rotation? Or does this 30° rotation indicate the speed of operation?
My best guess is that the situation describes the following sequence from a close to self-starting situation:
- The red-lever drops 90°;
- This causes two blue levers to rise 30°;
- The whole system turns 30°.
- This whole system turns 42° and repeats (note: 42+30=72)
Thanks.
He sees you when you're sleeping. He knows when you're awake. He knows if you've been bad or good. So be good for goodness sake! Ey!
In order for a pulley system to operate by gravity, no matter the pulley ratio, the total mass has to descent.John Collins wrote:This 90 degree fall by the (red) initiator lever generates enough mechanical energy to drive three actions. The first one causes the wheel to rotate 30 degrees; the second one moves the (blue) secondary lever 30 degrees anti-clockwise; the third one lifts the (blue) secondary lever in the preceding mechanism up 30 degrees. The cost in mechanical advantage is spread unevenly between the three actions. Clearly the swift lift is the most expensive.
Thanks.
- John Collins
Sorry Bill, when! Always seems sensible not to tempt fate.
Hi ME. The red lever operates the pulley to lift one blue lever in the preceding mechanism. The red lever also pushes the the blue lever which is within its own mechanism, sideways by alternative means, not the pulley.
The first rotation occurs because the red lever’ weight lands about 30 degrees to the right of where it launched from, so unbalances the wheel in doing so. It starts from near the CoR, but lands near the rim of the wheel.
The red levers gradually return to their launching positions, but because they push the blue lever by falling, they are not affected by the thrusting upwards of the blue lever, which would be slowed down if they had to also lift return the red lever.
A photo of my wheel will explain things better.
