A new PPM for your ride is here.
- Silvertiger
re: A new PPM for your ride is here.
uh-ohthe inventor wrote:...With a few more parts he expects to have the test pickup running exclusively on hydraulic power soon...
Sounds like it might be a similar system to the Clem Engine .
http://www.rexresearch.com/clemengn/clemeng.htm
- gravitationallychallenged
Thank you both for posting those links! I had forgotten about the Clem Engine.
Nikola Tesla
Nikola Tesla
I had forgotten about it too! There evidently is something to this - the severe compressing of the oil and the pressure that is released through the nozzles evidently allows this thing to keep on compressing more oil and it builds. Something as simple as that could bring down an entire industry and no doubt why it's been squelched. History seems to be full of people who came up with a brilliant invention and then they suddenly died.
silent
My opinions 100%
silent
My opinions 100%
Could you consider a source of energy being produced by the oil molecules;
When they are being broken into smaller units.
Another example is sticky tape when pulled apart produce x-rays.
In this case the oil molecules are pulled apart / break then the energy heats up the oil.
This causes expansion and makes the oil less viscous.
Note. I remember early mountain bike riders required to clean out and re-grease wheel bearings. Those wheels were really smoking.
I think the secret of the Clem engine lies in the conical design of the pump. Centrifugal force and speed increases as the diameter increases If you're familiar with Viktor Shaumberger's vertical turbine generator it uses a similar shape.
Nikola Tesla
Nikola Tesla
I think the secret of the Clem engine lies in the conical design of the pump. Centrifugal force and speed increases as the diameter increases If you're familiar with Viktor Shauberger's vertical turbine generator it uses a similar shape.
Nikola Tesla
Nikola Tesla
Both also have the effect of transporting heat from the starting point to the periphery.
