Ram pump , , i just vied this
racer270
Post by racer270 »
re: Ram pump , , i just vied this
I had a look into these previously.
https://www.youtube.com/watch?v=zFdyqTGx32A&t=471s
You need some sort of gain for it to be useful.
When you think about it a pendulum is like a flow of water.
You have to think laterally.
If you were to stop the flow/movement then the pressure could be used to lift up a mass.
We know the ram pump transfers energy in a balanced way without any gain.
This higher pressure can be used too increase the movement of another smaller mass.
The difference is the pendulum version can use a third energy source to recycle the masses.
Could this concept be used to create a new version on a ram pump?
All the Best
