Apologies this is a text only description for now.
I will see if I can get motivated to model it later.
The principle is based on a Ball (1 kg) on a rail.
The rail is a spoke of a wheel.
The ball is halfway to the rim from the axle. The wheel is 2 metre wheel.
The rail rotates down anti-clockwise as it's on the left part of the wheel.
The rule is the rail curves up as it rotates and the ball rolls from axle to rim.
This is the power spiral as the rail is horizontal under the ball to give maximum force.
The second spiral presses against the ball so it can only roll to the rim.
This spiral is as vertical as possible.
Spiral 1 is rotating anti-clockwise and spiral 2 is connected so it rotates clockwise.
Logic tells use this wheel will not accelerate. Or does it?
P.s. Where there's life there's hope.
The Two Spiral Device
