PROCESS RESTART
Re: PROCESS RESTART
It's mind boggling even with the drawing, don't you think? And a fabulous drawing it is, jb.
What happens is; the center sprocket is held stationary by the rollers. As the wheel turns CW the chain wraps around it. It's like the chain kind of walks backwards, which causes the outer sprockets to turn CCW keeping the green rods level.
Simple, right-----------------Sam
Re: PROCESS RESTART
Bonjour Sam et JB,
Le coup de boost est enthousiasmant pour l'évolution du concept dans nos esprits!
Sam avez vous fait le montage en réel?
Hi Sam and JB,
The boost is exciting for the evolution of the concept in our minds!
Sam did you do the actual editing?
Hi Sam and JB,
Re: PROCESS RESTART
Hi SHADOW,
If you mean the drawing, No. johannesbender did the drawing. The text yes, I did that---Sam
Re: PROCESS RESTART
Bonjour Sam, je parlais du prototype!
Hi Sam, I was talking about the prototype
Re: PROCESS RESTART
Test du jour: la spirale.
But du test, observation du comportement de roulement.
Prochain test, spirale multi spires.
Test of the day: the spiral.
Purpose of the test, observation of rolling behaviour.
Next test, spiral multi coils.
- SPIRALE.zip
- (359.19 KiB) Downloaded 5 times
Re: PROCESS RESTART
SHADOW,
Oh, the prototype. I'm working on it but, it's still not complete. I have to make a set of levers that slide the weights back and forth. One set is done. Have to do the 2nd one----------Sam
Re: PROCESS RESTART
L'essai du jour, moins concluant que le précédant!
Mais un ajustement envisageable.
The test of the day, less conclusive than the previous one!
But a possible adjustment.
- Spirale Multi Spires.zip
- (345.91 KiB) Downloaded 8 times
Re: PROCESS RESTART
Now you just need to inverse the action. Don't lift along the rim.
Great work by the way.
Re: PROCESS RESTART
Principe recherché, les poids remontent au plus près de l'axe central vertical.
le poids arrivant à hauteur de moyeu est versé sur la rampe de transfert vers la jante.
Le poids près de la jante exerce le couple pour monter les poids à la verticale.
As a principle, the weights rise as close as possible to the vertical central axis.
The weight arriving at hub height is poured on the transfer ramp to the rim.
The weight near the rim exerts the torque to raise the weights vertically.
Re: PROCESS RESTART
Hi Shadow can you share with us the last Spiral please? It is much better than the one I made.
Re: PROCESS RESTART
Daxwc, Je suis en transit je fais cela dès que possible
Re: PROCESS RESTART
Voila Daxwc
- (337.23 KiB) Downloaded 10 times
Re: PROCESS RESTART
Thank you very much Shadow. I know it was hard work thanks for sharing.
If people are wondering how to save it. (this is the only way I know how; there may be better ways). Doesn’t seem to save by pushing the save button.
From the Algodoo screen it is running on highlight the whole machine.
Press Ctrl + c
Open new Scene on Algodoo and select one.
Press Ctrl + v
Should appear, then you can rename and save it.
Press Ctrl + c
Press Ctrl + v
