A spiral has mechanical advantage , the inclined planes wrapping around its shaft is mechanical advantage , if there is no difference between the plane MA and the spiral MA then they should be in balance , you however mean to say one produces less counter torque on the axle to create a net torque , i doubt there would be a continues net torque from this , although i would love to see it because i am busy with counter torque reduction myself.
PROCESS RESTART
Re: PROCESS RESTART
Last edited by johannesbender on Fri Mar 15, 2024 7:53 pm, edited 1 time in total.
Re: PROCESS RESTART
Nouvel essai de distribution Buzzsaw
New test of Buzzsaw distribution
- BUZSAW 2024_5.zip
- (633.37 KiB) Downloaded 18 times
Re: PROCESS RESTART
Impressive ..
Re: PROCESS RESTART
Bonjour Fletcher,
hélas couple insuffisant, je tente avec un seul poids en monter, à suivre!
Hi Fletcher,
Unfortunately not enough, I try with only one weight to climb, to follow! te.
Hi Fletcher,
Re: PROCESS RESTART
It is impressive but it doesn’t run very good with the motor off. I still don’t believe the buzzsaw isn’t anything more than an old piece of mining machinery; but what then was it used for? It sure doesn't like RPM or being reversed. Reverse it piles up immediately is it some kind of safety brake and speed limiter?
Good work Shadow and good luck with your refab.
Re: PROCESS RESTART
Bonjour Daxwc,
l'essai avec la remontée d'un seul poids ne marche pas mieux, moteur éteint!!
Je passe a autre chose
Hello Daxwc,
the test with the ascent of a single weight does not work better, engine off!
I’m moving on
Hello Daxwc,
I’m moving on
Re: PROCESS RESTART
I had a go at something similar a while back.
The difference being, the mass of weights were moving around the axle, with the hope of the last weight dropping back (rotating slower) in a similar fashion to Shadows sim.
My sim isn't as good as Shadows, and i didn't do too well when selecting the colours. In the programme everything was easy to distinguish, but on the Youtube video it's not very easy to see the heavy weights, or what's what.
https://www.youtube.com/watch?v=c48yPaHcLLE&t=4s
I like to think if we ever find the solution to Bessler's wheel, we will be able to either work out how the Buzzsaw worked, or be able to assume with more confidence that it didn't.
Re: PROCESS RESTART
Bonjour Robin des bois,
Je vois le travail que tu as du fournir pour ton montage, excellent travail!
La restitution sur YouTube est généralement médiocre, flou, pixellisation et images fantômes.
Hello Robin Hood,
I see the work you had to provide for your editing, great work!
Rendering on YouTube is generally poor, blurry, pixelated and ghostly.
Hello Robin Hood,
Re: PROCESS RESTART
Essai du jour: un dérivé de mon idée hélicoïdale.
Today’s essay: a derivative of my helical idea.
- BUZSAW 2024_6.zip
- (600.73 KiB) Downloaded 7 times
- Helicoïde D.zip
- (302.4 KiB) Downloaded 8 times
Re: PROCESS RESTART
Mes derniers travaux méritant une construction pour essais réels!
J'essai de mettre une vidéo.
My latest work deserves a construction for real tests!
I’m trying to put a video.
- EXCENTRIQUE 2024 J.B Sim.zip
- (609.1 KiB) Downloaded 7 times
Re: PROCESS RESTART
Hi Shadow, before you do anything else with the idea just try setting the accuracy to 1200 and see if it can still do what you want it to do. Having the accuracy on 60 causes too many errors.
All the best
All the best
Re: PROCESS RESTART
Bonjour Roxaway59,
A quoi correspond ce réglage?
Hello Roxaway59,
What is this setting?
Hello Roxaway59,
Re: PROCESS RESTART
Hi Shadow, in Algodoo left click the cog like icon next to File then click Simulation and you can then select the accuracy. By default it is normally on 60 but this is way too low. I suggest having it on 1200.
Re: PROCESS RESTART
Ca ne me dit pas sur quoi cela agit? pour l'instant cela freine!
J'ai trouvé la commande et l'ai mis à 1200Hz.
Re: PROCESS RESTART
Basically it makes things more realistic. Generally the simulations run slower because your computer is working harder.
