Shutterstock PPM
Oxygon
Shutterstock PPM
Post by Oxygon »
Hi everyone, long time... I thought of this forum seeing this.
https://www.pinterest.com/pin/39406565480343358/
I came across this by accident on Pinterest, thought you all would be interested... I have never seen this specific design, maybe I am a bit rusty on PMM.
The only thing I noticed is the water pump portion underwater should be a dual stroke pump.
Re: Shutterstock PPM
La pompe ne fournie pas assez de débit pour remplir les poches sur un tour de roue.
donc pas de compensation des contraintes mécaniques.
The pump does not provide enough flow to fill the pockets on a wheel turn.
therefore no mechanical stress compensation
