Offset the magnets and drive coil from the center as shown below.
There is practically no change to the input of the motor compare to the centered configuration, however, the offset gives additional torque to the motor for free and therefore exceed unity.
Pulse motor Overunity design
Re: Pulse motor Overunity design
Hell, forget about electrical… just magnets.
Re: Permanent magnet generator speed regulator
Mass and spring is used to control the speed of the system.
High speed pushes the masses outward and change the magnet angles. This to ensure it does not overspeed and felt apart.
With the quadrature that Mr. Tim posited and my riddle, there is an answer. What you posted is close to it. It needs to work with magnets only.
Then any work can be converted into electricity. What gain is there if 1/2 of the electricity is used to make the magnets electromagnets? Creating
an armature or field coils only matters if the device is generating its own current. Then it could amplify its own potential.
Still, might be best left for another day unless someone does figure it out. As AB Hammer said, people need something that people are fascinated
with and this might be that thing.
An example of a quadrature repeating itself. Each 90º arc segment is 1/4 of a quadrature. With my work on Bessler's wheel, I adjusted both the phase variance and the timing. With a motor using magnets, it will need to be played with otherwise it's just magnets on a wheel.
