Too bad Bessler's notes have been removed from the MT drawings. Really enjoyed referring back to them.
ArchCalc
Post by ArchCalc »
Oh well.
Banned
Re: Too bad Bessler's notes have been removed from the MT drawings. Really enjoyed referring back to them.
Post by Banned »
Who done that.
ArchCalc
Post by ArchCalc »
Better question is why? Fear?
Banned
Post by Banned »
The notes are still in the pdf book aren''t they ! the MT book John has for sale .
No. 1 The horizontal line must be rather level or have a slope such that one sphere rolls toward the center from the rim, and
the others roll out to the rim from the center.
No. 2 Almost unanimously the mobilists for whom the spheres were the main principle have chosen figure for the most part
like this one; such a figure has already been encountered in various books on mathematics and mechanics, and from the figure
the mathematicians generally showed the impossibility of perpetual motion, just as though one could not bring forth a better
figure as evidence. In particular, Jungnickel, in his almost peculiar book titled Key to Mechanics, pages 243, 246 and 247, has
presented three such machines and intended to prove and enforce the impossibility of perpetual motion. Sturm also uses this
figure, and even the late Leopold uses it in his Machine Treatise, of which he prepared 8 sections but did not complete
because of his death.
No. 3 Several mobilists have supposed that they invented the thing when they chose curves and double curves at that- for the
spheres, as the accompanying figure shows. Here is seen not only the outer sphere- compartments but also a separate inner
component with long curves. It was thought with utter certainty that one could induce movement by this means. If one only
makes completely unbiased calculations, then one finds the opposite to be true. Thus it is not even necessary to build a model.
No. 4 Here the lines curve a great deal and are made up of half circles. It was imagined without doubt that movement could
be obtained in this way; but the former invention and the latter are the same thing. Granted! One finds out through calculation
and on paper, on one side somewhat more than on the other side, that a superior weight equalizes; observe! Thus there will
always be stability and no mobility; why? Answer: because the friction, owing to the machine's own weight and heaviness,
eats away all the supposed superior weight; sufficiently understood.
No. 5 Here the thing again has double curves like No. 3 and is only slightly different. This one runs the same way as that one;
nevertheless, I have come across this same fantasy in the work credited to people who were of renown and who truly
possessed much mathematical knowledge.
No. 6 Some mobilists have done something special by letting the spheres run out of the wheel into a channel at the edge of
the wheel. Because they did or knew nothing other than what is merely recorded here, the thing can run no differently from
what this figure leaves one to believe and conclude.
No. 7 Here it first appears as though movement should inevitably result, for the curved lines which convey the spheres from
the light side outward are attached very close to the axle, and at the edge of the wheel runs the same formation as in the
previous illustration. However, if one counts the spheres on the light side and then those on the heavy side and calculates the
force accordingly, then the situation is readily shown and proven to be completely different from one's first impression, as it is
said: great people err, too: they weigh less, then nothing.
No. 8 Here the spheres fall somewhat higher and sooner onto the thing and then lie more on the heavy side than they did in
the previous figure, but one must also note: when as many of the spheres lie at the light side, further out, toward the edge, an
equilibrium is caused as in the two previous illustrations..
No. 9 Because one has learned that little is to be accomplished with the sphere-wheels like those just now seen in the figures
and diagrams, one speculates on another principle, namely: on weights! In all places where I have found weight-figures, these
weights are seen to be simple and nothing is attached to the belts or chains. Such is the case with Leupold, but nothing is to be
accomplished with his thing unless one acts out of my connectedness principle; but here I do not yet wish to show or discuss
the figure for the time being.
No. 10 This is exactly the previous model, except that the weight-poles are more curved and longer. The principle is good, but
the figure is not yet complete until I delineate it much differently at the appropriate place and indicate the correct handle and
construction.
No. 11 This figure is doubled, as one can see, and the form does not involve much, but there is more in it than meets the eye,
as will be seen when I pull back the curtain and disclose the correct principle at the appropriate place, as mentioned
previously.
9/11/2020 Portal:MT - BesslerWiki
https://www.besslerwheel.com/wiki/index ... =Portal:MT 3/7
No. 12 This only shows the present and previous weight-principle in passing: one is able to discern somewhat below here at
A and downward that the weights do not hang very far out but lie nearer the center, and, moreover, upon revolution the
weights do not fling out very much to the side and cause a great shaking.
No. 13 This is a new weight-invention, with no belts or chains but each weight is separate and free except that each has an
interval arm C with which it forms an angle, and on the cylinder hangs a figure which has below a weight in the shape of a
half-moon and above a small wheel B over which the arms C sweep and lift themselves up at D. This invention would be
very good for running if not so much friction were present or someone was available up by D to always lift up the weight
with lightning speed.
No. 14 This invention is somewhat speculative, and the internal cross-tensions with the weights are movable; therefore, when
the weights raise up one another, the cross-tensions are pulled up with their weights at the same time. What is objectionable
about this model, what to learn from it and how it can and may be used, will all be treated later.
No. 15 This ratchet-wheel derives from the previous model, except that the tensions are somewhat longer and have an
additional special weight at the external ends. From this drawing alone, however, nothing of the prime mover's source can be
seen or deduced although the figure shows the superior weight.
No. 16 This model shows how the weights are connected and how they raise the internal spheres at A up and around. The
accompanying special figure shows how the edge of the wheel appears at the tensions when it is opened.
No. 17 Some speculators have gone further still and have imagined lifting up certain weights and effecting operation through
several springs, and in this instance the figure has a good and large appearance. An acute mind will readily see and grasp
what to make of this thing.
No. 18 This is the previous spring-model, and it seems to be good, but seeming is different from being. In the meantime, the
principle should not be disdained or entirely disregarded, for it says more than it shows. I, however, will show more than
speak of it at the appropriate place.
No. 19 This figure may be called a mere demonstration. There are nothing but levers with weights at the front ends of the
levers, and if they are not very useful, they are also not harmful most of the time. A good friend, however, was violently
injured by them. I cannot discuss it further. He endured more than I can mention here.
No. 20 Here the previous levers work somewhat more peculiarly and raise up special weights and turn outward to the over
balance. For this reason side A is always heavier, my friend supposed but I denied. I then reminded him to harness the horse
in front.
No. 21 This figure has hanging levers A which are internally applied to the cross-poles at B and thus side C becomes lighter;
if, however, the lowermost lever is not periodically raised up out of its position and into C, as has already happened at C in
the illustration, it remains in its old position.
No. 22 This lever-thing appears to be good. From A in the center hang the large levers B. Small wheels are fastened at C,
over which pass cords to the lever-weights D, which are thereby drawn up and thus the side at E becomes heavier. I have
misgivings about many of the scrawls in the figure, and I will not yet make the rest of my thoughts known.
No. 23 This is the principle from 21 and is rightly called improved: A are hanging levers on the ends of which, B, is a small
lead or iron wheel instead of the weight. Side C appears to be the heaviest, and the weight-wheels B are supposed to lift
themselves around at Din a circular channel, by which means side E becomes lighter periodically. Contemplation and
consideration reveal what can happen here.
No. 24 This invention ought not to be scorned. It consists of separate levers with weights. Between the weights are small iron
poles with hinges. The poles fall inward when the levers close. There is something one must learn first before one can grasp
and correctly understand the good quality of the invention.
No. 25 This is the previous model except for some differences. It is sketched with longer poles. There is something
misleading about the diagram, for the poles, when coming out, must not project so far out but must bend somewhat further
inwardly. There is more to it than one supposes; one must study the diagram extensively.
https://www.besslerwheel.com/wiki/index ... =Portal:MT 4/7
No. 26. This is somewhat different from the previous model, but it can be described simply: A are levers which are
interrupted at B and equipped with weight-wheels at C. The weight-wheels run in a channel E and are attached to the cords D.
As the diagram shows, one side is heavier than the other. Behind this problem one looks for an augmented problem.
No. 27 This is the previous model slightly larger and altered: A are the levers interrupted at B and having a heart-weight at C,
and D are the straps, or cords, and chains. It needs no further, lengthier explanation. This view shows what the thing might do
if several things of this sort were placed next to one another along an axle-shaft.
No. 28 In this figure, A is a wheel with cogs almost like a balance wheel in a clock. In the center of the axle at B are orderly
arms. At C is a side lever which raises the above long weight-pole E by means of D. On this pole is a thrust-lath F which, by
the double movement of two wheels G and H, forcefully pushes the cogs of wheels A 4 times with each revolution. Thus the
thrust upon the edge of the wheel should be much stronger than the force which the arms on the axle require. The rest is left
to speculation.
No. 29 This is the previous principle except for one small change. A is the main wheel. B is the cylinder with 2 arms. C is an
arm of a large Winkelhaken [Literally, "angle-hook," this German word was used in the printing trade to mean "justifier" or
"composing stick." -Translator's note.] which is movable above at D and at E pulls a cord F. F turns a small wheel G from
which a weight hangs below at H. On G is a catch I which thrusts twice into the cogs of the large wheel with each revolution
and thus should cause the movement. At this point one should be able judge what to do with this thing or what to make of it.
No. 30 This is another lever invention. A is a figure of a half transverse-wheel. B are the main levers. C are small lifting arms
on the axle which are pressed down under a small wheel D. At the center, E, of this small wheel, over a tiny wheel, by means
of a cord at F, through a chain G the large arms are raised up, the lowermost up to the axle and the other up to H. In the
subordinate figure one sees the levers project onto side 1; thus the side at K is seen to be heavier, and that at L, lighter. The
hand at M indicates, for best understanding, the pressing down of the lifting lath, which raises the large lever. Whether this
invention is good and whether the lath at E below the small wheel can be forced, pressed and raised up may be judged by
those who know about friction.
No. 31 This is a figure with two reversed long levers A at the ends of which are weights. The levers are connected to the
center of the axle at B by means of a cord which raises the upper levers C C. By means of the cord D the lower levers E are
raised toward the axle. There is more to this invention than the mere drawing, which only presents or indicates the problem.
The rest is left to commentators to make of the thing what they will.
No. 32 This is a combination of the two previous figures. What is intended by it is easily understood. A is the wheel's center
under which the laths B incline and the lever C is raised by means of a cord D. This invention or figure has a good external
appearance, but one must look at the end of description No. 30.
No. 33 This is exactly the previous model, except that instead of the central bevel-wheel it is equipped with doubled long
levers by means of which the short levers A are brought up to the superior weight and the center B is brought down. It is not
necessary to speculate much on this figure, for the diagram itself says what it will do.
No. 34 This model is easy to understand from the figure. Here A presents the machine in profile. At B are 2 long levers with
weights suspended from the ends C. The levers are lifted toward the center by cords at D, which lift the upper weights E over
small wheels up and outwards, and by other cords at F which lift the lower weights G up and inwards. At this point the reader
is free to speculate as he pleases and to explore his thoughts on the matter.
No. 35 This is precisely the previous model, and only the 2 side-wheels, which lie horizontally, are to be observed, one needs
no letters or explanations because the drawing itself clearly shows how the thing is constituted. Deliberation or judgment is
left to the mind of each reader.
No. 36 The intent of this figure is clearly expressed. AA shows the 2 connected long levers with weights. At BB the levers
swing a weight-lever D from below up to E by means of a chain over 2 wheels. The secondary drawing shows a distant view
of the thing. Each reader must infer as much as he can.
No. 37 This invention belongs among Nos. 14,15 and 16. It is inserted here only because it slipped past the beginning. AA are
movable levers on a belt, each of which has an oval disk fastened to it on the heavy side where the lever is attached. Other
oval disks can be drawn to the first disk or pulled away from it by the known method. These disks should be considered a
problem rather than an axiom
https://www.besslerwheel.com/wiki/index ... =Portal:MT 5/7
No. 38 This is based on the previous principle but instead of oval discs it has stork's bills or student- forceps. At A the stork's
bills pull apart from one another, and at B they draw together to C by means of the levers D and E; this side is therefore the
heaviest. There is more to this invention than there is to the previous one, but here is not the place to show the correct
application of the stork's bills.
No. 39 This is a very special style of the stork's-bill invention. Side A is heavy. At B, over wheels, the following area C is
raised up to E. At D the figure is contracted, and the corresponding side is lighter.
No. 40 This is a somewhat different stork' s-bill invention. The weight-levers A pull up figures B –which have the joining
point at C- and also pull up the weights D by means of the poles E. The figures correspond in the center at F; thus it becomes
light at G and heavy above at the superior weight. Whoever thinks it proper can construct these figures on an axle.
No. 41 This is yet another stork's-bill model. It is not necessary first to explain the letters. There is only this to mention: the
present horizontal application of the stork's bills is always better than the machine with the vertical application, which
constantly has more friction. I can assure the reader that there is something special behind the stork's bills. Whoever knows
how to construct them will note that the figures sketched here are not exactly the correct artistic application.
No. 42 This is another application of the stork's bills. The figure is so clear that I omit explanation of the letters. The side
figure F indicates how it would look if one were to multiply the internal structure.
No. 43 This shows the perpetual stability machine of the well-known Professor Mangold at Rintein. He alleged it to be a
motion machine, and he sought to hoax your highness, the landgrave of most blessed memory. However, as a wise prince you
soon sent him away and knew that my motion machine was the better one. This figure speaks for itself and requires no
explanation; it tells us that it would run readily if only it had feet and legs.
No. 44 The sphere-method is reintroduced here. The problem shows 2 wheels: A is the main wheel, the axle of which has a
gear at B. B drives the somewhat larger wheel C at point D. At side E are spheres which fall out of side G at point H below
and into wheel C at point I and then out of C again into A at point F. This problem looks good, but as sketched it does nothing
special as long as no other application is present, for the wheel A must revolve several times before C revolves a single time.
Thus not enough spheres move from the former into the latter.
No. 45 This is the previous invention, except that the one wheel C is much smaller than A. The explanation of the remaining
letters C [sic], D and E are indicated by the figure itself.
No. 46 This special sphere invention has a vertical screw. A is a wheel with sphere which below at B fall out into a channel C
and run into the screw at D. The spheres in the screw climb up to E, then out and into wheel A again at F. At G on wheel A is
a gear which drives a pole of 2 wheels, one at H and another at I, and the screw-wheel below. The screw-wheel drives a large
crane-wheel at K and should pull up a bucket at L; M shows a large perpendicular. Whoever knows about friction can judge
this machine.
No. 47 This is a sphere machine which uses stork's bills. The wheel A carries the spheres. The hook (or curved implement] B
reaches down to C and moves the beam of a balance. At D, the two ends of the beam, the stork's bills are pulled so that the
spheres are ejected above at E and grasped at F. The two sets of stork's bills are connected to each other over the small wheels
at GG. An equilibrium causes the spheres to be ejected at L. At H the spheres fall into the wheel A, and at I they fall out
again. Afterwards, at K, the spheres are swallowed and lifted up again. I submit the rest of this machine to the judgment of
the wise, who might elucidate the problem.
No. 48 This is a sphere invention having a paternoster with pockets. A is a wheel. As the pocket-patemoster C raises the
spheres, it passes over B, the axle of the wheel. At D the spheres are ejected into a channel. At E the spheres fall into the
wheel, and at F they are ejected again into the paternoster. Here, an insufficient number of spheres is carried to the wheel A
by means of the paternoster. The principle is good, but this figure will bring about no mobility by itself until completely
different, additional structures have been provided.
No. 49 This is the previous model except that the pocket-patemoster is taller and larger. A is a large wheel. B, the axle of the
wheel, moves by means of a chain which reaches up to the paternoster at C. At C the spheres are ejected into the large wheel.
Below, at D, they fall off the wheel and are swallowed into the paternoster. The figure makes the thing utterly intelligible, and
an average intelligence can grasp the effect of this machine.
https://www.besslerwheel.com/wiki/index ... =Portal:MT 6/7
No. 50 This is a special pocket-patemoster. A is the upper axle. BB are the hollows with spheres. C is an internal piece which
prevents the paternoster from collapsing on itself. At D above and below this paternoster passes over the axles. On the right
side E the spheres run out, and on the other side, they run in. For the mobilists who believe in this model, I note: side E is
heavier and one would suppose that it would inevitably cause operation, but the thing remains in status quo.
No. 51 This is a perpendicular invention which is meant to maintain motion by means of oscillation. A is a perpendicular with
stoppers, or stop-cones, at the top which catch in a small wheel B. A fastens onto the wheel E. D show the perpendicular per
se with stop-cones. H is a horizontal perpendicular, or beam of a balance. H moves by means of the curved implement I on
the one side and the perpendicular F at G on the other side. Motion by means of the oscillation of H is expected, but the
invention is wisely criticized.
No. 52 The present invention or speculation is to be found at the place of an eminent man. I was not a little surprised at the
imagination involved in it. A is a balance wheel, and B is its axle. Clappers, or mallets, on B strike the wheel C, which should
thereby move. At D are wheels which, by means of a cord, should move the upper axle B and set a perpendicular going at E. I
will only say the following: no wheel is moved through strong blows, for paddles would sooner dash it into 1000 pieces, and
it would be utterly destroyed with bullets, as is sufficiently known.
No. 53 This is a perpendicular model. A is a lever with a weight. At B the lever has stop-cones which should move the axle at
C by means of a small wheel with 2 arms. The arms should raise the pole D by means of the lath. D should move a
Winkelhaken ["angle-hook"] above, and this angle-hook should move another angle-hook by means of pole E. This latter
angle-hook should move the pole F which should raise the main lever A. G is a beam of a balance and should accomplish all
the raising. I saw this fantasy along with many other such devices recorded in a machine book at the home of a learned friend,
but I did not see the effect.
No. 54 This is simply a demonstration of how one might raise the large lever of the previous model by means of stork's bills.
The letters are self-explanatory.
No. 55 [sketch only]
No. 56 bellows
Wind Machines
No. 141 5. Children's game in which there is something extraordinary for anyone who knows how
Portal_MT - BesslerWiki.pdf
(136.87 KiB) Downloaded 172 times
thx4
Post by thx4 »
Not very cool for JC, ... I'm not surprised.
A++
Banned
Post by Banned »
Where were the notes removed from ?
ArchCalc
Post by ArchCalc »
From here Hope this link works.
http://www.orffyre.com/mt.html
I didn't know Bill had the comments on his page.
Trev
Post by Trev »
Post by John Collins »
I’m cool with the notes being published here, but if you can acknowledge me as publisher/editor, I’d appreciate it.
I followed a link on Bills site advertising my version of MT, (thanks Bill) weirdly it takes you to something quite strange, I’m not sure why, it seems to have the right web address which is www.free-energy.co.uk and yet it takes you to something which looks as though it has the right address but the link is not right. It provides a list of links to every subject under the sun! But perhaps it might be wise not to click on the links. If you’re in touch with Bill can someone let him know so he can change the link? Thanks.
