Terragravitic Induction
Re: Terragravitic Induction
Perhaps in this neglected spot is laid
Some heart once pregnant with celestial fire;
Hands, that the rod of empire might have sway'd,
Or wak'd to ecstasy the living lyre.
Line 46 of Elegy Written in a Country Churchyard
Well with your return visit to the Reported Dog house of a forum. Your pregnant paws finds some are still barking.
P.S. Interesting you have selected a poetry style of Elegy normally used too lament for a deceased person.
Poetry is also helpful were a person is building up connections between the left and right brain.
Yes indeed.
They do have the same instantaneous kinetic energy in the end
But they do not have the same cumulative kinetic energy.
The low road mass, L has received more energy from the
cycloid slope reaction than the high road mass H has
received from the straight line slope reaction.
Showing this with maths is beyond my pay grade but I see it can be
demonstrated graphically by dividing the slopes into small cells and
adding up the contribution each cell makes.
It will be found that the total reaction energy input
is greater for L than for H.
Now if we return L up the H straight line slope
to the starting point, we have generated an energy surplus.
We have a closed circuit for L with a surplus of energy.
We have induced energy from the slope reaction with the gravitational field acting as a catalyst.
I'm just posting this image to check that I have remembered how to do it. 8-)
As you can see it show two pendulums, one following the other and released for a small angle.
I suppose on might call it a sub 360° degree pendulum.
I shall be discussing its relevance in subsequent posts.
Terragravitic Induction ??
This is the text from your first post. Which some people could consider a load of bollocks.
I of cause would not; but I am weird anyway.
Have a go at breaking this sentence down into it's meaning.
'gravitational force' is a phrase 'gravitional energy' is a misspelling and a mixing or 'gravitation force' and 'potential energy'.
There is 'Precession' but again that is not energy. Kinetic Energy and the inertial mass in a gyroscope results is precession.
Have you got any understanding of gyroscopes after all these years?
A 2nd derivative is 'acceleration' and the 3rd derivative is a 'jerk'.
However precession is a mix on three 2nd derivative motions.
This thread starts on weak foundations.
P.S. There is no reference to 'Terragravitic Induction' anywhere on the internet except in this thread.
Congratulations
Re: Terragravitic Induction ??
Thank you. :-)
Howdy, Scott!
I suppose once someone finds this terragravitic unicorn, half the world is going to say, "I knew that!" & the other half is going to say, "hey, that's my idea!"
I predict terragravitic turmoil. Chaotic chaos. Is there any other sort?
Thank god Scott is back and took care of that filthy talking menace. In order to help reimburse Scott for his time in cleaning up this filth, I made a donation.
Regarding your message WC, is this more subtle hints as to the fabric of the wheel?
It almost seems as if nothing in MT nor the toys page has anything to do with the solution.
too frustrating too post
Unfortunately, the sorcerer's apprentice is at present in OZ jet skiing with his brother so you will just have to use your imaginations.Senax wrote: ↑Sat Sep 02, 2023 5:58 pm
Consider a whole host of pendulums, each given just enough energy to go over the top and rotating in the same direction, clockwise say.
As can be seen from the above pair they will be spaced out at 6 o'clock
and crowded together at 12 o'clock.
We can think of a group of pendulum bob "molecules" as like the molecules in a engine cylinder being alternately compressed and expanded as they rotate around the central axle.
To transfer this energy to the structure of the wheel via the pendulum shafts we need some kind of crank shaft. Fortunately Bessled had provided this by enlarging the narrow iron axle into a large wooden cylinder. A pendulum shaft attached at a suitable angle to this cylinder will provide torque to rotate the wheel.
A compound shaft mechanism needs to take the bob weights through an elliptical path with the major axis from 10.30 to 4.30.
This is a guess based on the assumption that the Pop Keenie wheel worked.
Terragravitic Induction??
Senax wrote: ↑Mon Sep 04, 2023 9:56 am To transfer this energy to the structure of the wheel via the pendulum shafts we need some kind of crank shaft. Fortunately Bessled had provided this by enlarging the narrow iron axle into a large wooden cylinder. A pendulum shaft attached at a suitable angle to this cylinder will provide torque to rotate the wheel.
I am not seeing or imagining this 3rd derivative precession at right angles.... 3rd derivative Precession Energy since it is generated at right angles ...
You are talking about the pendulum's inertia pulling on a crank at the lowest part of it's arc.
Terra [land] gravitic [gravity] Induction = Mass of Earth causing gravity inducing acceleration.
P.S. Did you clear this dangerous RAAC concrete when you were working in your materials testing department?
It has been hinted this foam like concrete had asbestos-fiber and salt in contact with the steal reinforcement bars.
Re: Terragravitic Induction??
You should have put a date on that second quote.agor95 wrote: ↑Mon Sep 04, 2023 10:50 amSenax wrote: ↑Mon Sep 04, 2023 9:56 am To transfer this energy to the structure of the wheel via the pendulum shafts we need some kind of crank shaft. Fortunately Bessled had provided this by enlarging the narrow iron axle into a large wooden cylinder. A pendulum shaft attached at a suitable angle to this cylinder will provide torque to rotate the wheel.I am not seeing or imagining this 3rd derivative precession at right angles.... 3rd derivative Precession Energy since it is generated at right angles ...
Just as 2nd dev can be generated in line or at right angles (acceleration towards the centre)
So also 3rd dev can be generated at right angles to circular motion or in line with circular motion as in the case of the pendulum when the circular speed of the pendulum increases.
As for my work as a Principal Scientific Officer in the Structural Division of BRE it comes under the Official Secrets Act.
Please don't derail the thread.
- eccentrically1
I thought the thread was about a ball arriving first down a cycloid slope before a diagonal one.
https://drive.google.com/uc?export=view ... Ywo5x0p5Le
That was an introduction to the subject of more energy being generated from the cycloid curve thaneccentrically1 wrote: ↑Mon Sep 04, 2023 12:44 pm I thought the thread was about a ball arriving first down a cycloid slope before a diagonal one.
from the straight line decent by the action of Terragravitic Induction.
