gravitational motor with eccentric shaft
sergiocortazi
Post by sergiocortazi »
Hello Friends, does anyone know if there is any physical prototype similar to this design.
Do you think it has potential?
Re: gravitational motor with eccentric shaft
corzie,
It's a good idea. The "Z" is bad though; it could kill it-----------------------------Sam
Operates on the same principle as MT13.
No, it will not work.The arms folded down before they are lifted pull the wheel the wrong way, reducing the OB. The small advantage left is eaten by trying to lift each lever. Having it on an axle or not makes no difference.
