Math
Da Ewe
Math
Post by Da Ewe »
This is fairly basic so I expect everyone to understand it. When 2 weights on an 8 weighted wheel swing downward
so they'll have force, when traveling from sin30 to sin 60 and from -sin30 to -sin60 we can say cosine instead. Then
those weights are moving from 2 xcos60 to cos30.
The average in degrees is 45. The average of (.5 + .866)/2 = 0.683 and not sin or cos45 = .707. Close enough. When
considering a perpetual wheel and not something like Milkovik's double oscillating pendulum, the 2 weights away from
0º or 90º (sin vs cos) have about 1.4 times the net force of 1 weight.
What is the weight approaching and/or passing x sin0º or x cos90º doing? Easy math to consider.
Da Ewe
Re: Math
Post by Da Ewe »
If f = ma is considered, then if we use a 4m diameter wheel, ob can be 0.5m.
Then 2.5 is 55% of 9.81m/s. That ob weight can be expected to accelerate at
5.45m/s. That's the Idiot's Guide to Moment of Inertia.
This is the basis on how to consider a mechanical wheel. Once the PKE is known
then it can be considered how work, timing and when a weight is moved to its ob
position.
Of course the weight approaching BC (bottom center) has torque just as the weight
approaching TC (top center) is resistance. Understanding math simplifies things,
And this is where knowing algebra helps.
This is because then a person would know a simple way of factoring a problem like
this. Then variables could be modified to determine the best function of the given
parameters. Then this would allow for construction of such a device. And this is if
discussing math is allowed.
The parameters could be considered using trigonometric identities. And with
radians, they can allow you to know the length of an arc segment but not the
torque over time generated. That's when f(x) = ∆y/∆x could be used as
f(x) = ∫∆y/∆x which the integral allows you to set limits.
An example of limits is cos30º and cos45º. Then the change in function could be graphed.
And with a wheel, then the different limits could be factored as a net result. This is just too easy.
And because there is resistance, a net loss of torque could be factored as well. Then this
would allow for a model to be made to determine the efficiency of an actual working build.
And "if" my invention works, I think this would show how many wheels would provide the
smoothest curve when generating power.And a phase converter should allow for its output
to be cleaned up so to speak.
Da Ewe
Re: Math
Post by Da Ewe »
With math, it can show where a change in force occurs. And this means that a pendulum's swing
can be factored all the way through its motion from one side to the other. How does this compare
to its counterbalance?
Re: Math
Bored chemist wrote: Still waiting for the OP to show that this
"Lifting One Weight Higher Than Another Drops"
actually happens
Da Ewe
Re: Math
Post by Da Ewe »
WaltzCee wrote: Sat Mar 25, 2023 2:13 am
actually happens
I used to believe in Jesus. As it turned out, Christians were like the people in this forum.
There was a time when ideas and math were discussed. Faith doesn't allow for that. And
while Bessler was a Freemason and a Christian, rlortie and ab hammer are also both
Christians.
While you are quoting both engineers and scientists, that statement ignores conservation of momentum.
An example is the Earth cannot cause the Moon to orbit it faster than its own spin on its axis. Yet it does
accelerate the Moon in its own orbit around the Earth.
Is the Moon orbiting the Earth perpetual motion? It isn't. It's an example of conservation of momentum.
I think this is math I can do. The issue here is when the Moon orbits the Earth slower than what
v = sqrt (Gm/r).
Why the Moon's orbital velocity would disagree with this gets into more science. Would you care to discuss
this? This in a way violates g = Gm/r^2 and its angular potential. The equation stated is for linear acceleration
towards the mass creating gravity.
So to simplify, what would you and your friends like to discuss?
Re: Math
Da Ewe wrote: If this works I will tell Europe that bored chemist said that I have sinned and have fallen short of the glory of God.
Re: Math
So we can get to know each other, what countries and languages have you guys learned and what countries hve you lived in and have visited?
Have ewes blessed humanity? Yes, with syphilis.
and the plagues keep coming.
Da Ewe
Re: Math
Post by Da Ewe »
I think people in none English speaking countries will view this as fascism.
As has been said in the media, Ukraine is fighting Russia for the U.S. And
this after the U.S. waged 2 wars that lasted for 20 years in the Middle East.
And I was talking about my being consistently attacked in this forum and
even at work in the U.S. It is interesting that this forum appears to view Bessler
as a fraud. And when the forum says it is about Bessler's work, that has not
happened except to ridicule it.
And yet when both Amy Pohl (John Collins granddaughter) and myself are 100% disabled,
John Collins supports his friends attacking me just as orpheus.org does. People will wonder
why is this allowed when I am 1/2 Norwegian.
And as has been said, I haven't been killed like Christopher Bergen https://metro.co.uk/2019/10/04/dad-acci ... -10862450/ whose father-in-law killed him for wishing him
Happy Birthday in Norwegian. Now because Christopher Bergen is dead he has a right to complain.
Just have to love the logic behind this. It doesn't matter what we do but only how you respond. Why
no charges were filed against Christopher Bergen's father-in-law. I mean the father-in-law knew who
Christopher Bergen was so why shoot him? Because he spoke in Norwegian.
Bessler's Wheel Solved!!
the syphilis infested ewe wrote:What do you think? It's what I receive in my inbox. Could you imagine creating a model from hundreds of research papers? Kind of why I think I figured out Bessler's Wheel.
Good boy James. Atta boy!!
@All, I guess time will tell if I am right or not. As far as both Bessler's Wheel and my experiment goes, I'm guaranteed to fail if I don't try.
I guess time has a sock in it.
Da Ewe
Re: Bessler's Wheel Solved!!
Post by Da Ewe »
WaltzCee wrote: Sat Mar 25, 2023 4:57 pm
I think people will find it strange when everyone in here wants me banned for working at Bessler's Wheel
because I'm not serving pure English speakers. And even if I built Bessler's Wheel for you guys, you guys
would say that's not Bessler's Wheel.
And Walt, I think real Nazis would be proud of some of you guys.
a lunitic boasts & wrote:p.s., it is nice being able to say that a psychiatric hospital found me to be a sane person and yet the tag suggests that I am not. I think I will agree with professional psychiatrists on this one.
we need a second opinion.
Re: Math
People will wonder
nords men are typical hillbillies, and due to low levels of breeding stock tend to procreate within family units.
It wouldn't be surprising if James looks very similar to an uncle or older cousin.
I have to see a DNA test results before I'd believe he was a noweenie*ian
He acts like one yet anyone can put on an act.
Da Ewe
Re: Math
Post by Da Ewe »
I think people will wonder why hate speech is tolerated in here but not pursuing Bessler's Wheel. And in the end that will become a part of Bessler's and orpheus.org's legacy.
Negate Inertia.
hear, here, a bit more wheel talk.
This is my theory, do the math!!
As far as perpetual motion goes, it's actually leveraging mass into motion which is realized as torque. Bessler's Wheel uses a neat trick. When the wheel rotates, a line wraps around stationary disc. This increases the distance between the fulcrum and its weight. Technically speaking the only worked performed is rotating the wheel. And you'll disagree with that. w = m*d, right? For the line attached to the weight to perform work, its length needs to change between point A (fulcrum) and point B (weight).
And Newton (1687, First Law of Motion) did say that an external force can change a body's motion. In this instance, resistance is a force. It negates inertia.
